Old 01-16-2008
axeman_ukl axeman_ukl is offline
Dedicated Member
axeman_ukl has a reputation beyond reputeaxeman_ukl has a reputation beyond reputeaxeman_ukl has a reputation beyond reputeaxeman_ukl has a reputation beyond reputeaxeman_ukl has a reputation beyond reputeaxeman_ukl has a reputation beyond reputeaxeman_ukl has a reputation beyond reputeaxeman_ukl has a reputation beyond reputeaxeman_ukl has a reputation beyond reputeaxeman_ukl has a reputation beyond reputeaxeman_ukl has a reputation beyond repute
insulation ?
now in the walls of a isolation booth can you use the 6" thick insulation (alot cheaper than the 30-50 mm thick compressed insulation) ?
if the stud wall was 12" thick to allow for two layers of the insulation would this give you the same as a stud wall say 6" thick with the compressed insulation or would they be the same ?
Old 01-16-2008
gullfo's Avatar
gullfo gullfo is offline
Dedicated Member
gullfo has a reputation beyond reputegullfo has a reputation beyond reputegullfo has a reputation beyond reputegullfo has a reputation beyond reputegullfo has a reputation beyond reputegullfo has a reputation beyond reputegullfo has a reputation beyond reputegullfo has a reputation beyond reputegullfo has a reputation beyond reputegullfo has a reputation beyond reputegullfo has a reputation beyond repute
depends. if the insulation is for treatment, then compressing it will help but the rigid insulation will still be more effective. if its to dampen the walls internally, then don't compress it too much as you just want to dampen the panels and avoid resonances in the air cavity.
Glenn
fossile music
Old 01-16-2008
cusebassman's Avatar
cusebassman cusebassman is offline
Freakin' sweet
cusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond repute
What is your general location, axe? I've got about 1 1/2 rolls of R-19 6.5" fiberglass ins. that I am lookin to get rid of. Shipping would be pretty pointless I suppose, but its worth a shot to ask
Originally Posted by Ford Van
I AM RIGHT
Old 01-16-2008
Rod Gervais Rod Gervais is offline
Force of Nature
Rod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond repute
Axe,
if the wall was 12" think you would get quite a big bang for your bucks - the added air space would be a big benefit.
In the 6" wall you really would not gain anything by adding the compressed insulation -
The compresseed insulation (by this I assume you refer to the rigid insulation typically used for room treatments) usually ends up with a loss in LF TL values - not a gain. High frequencies are never a problem in comparison. The same applies if using rockwool.
Rod
Old 01-16-2008
Dedicated Member
leeds ,england
Old 01-16-2008
Dedicated Member
Originally Posted by Rod Gervais View Post
Axe,
Rod
so would the 12" thick wall take out lower frequancies better than the 6" wall with the rigid insulation
its more a for a drum isolation booth in the celler 8*8*6 feet the other walls are brick and the floor in concrete
i am after a room that will minamise sound escaping but give a good enviroment to record in.
Old 01-16-2008
Force of Nature
Axe,
Yup.........
It's this way - any time you incease the air spring (wall thickness) you increase isolation at all frequencies.........
Also - installing rigid insulation in any wall is bad - use the fluffy fiberglass.......
Rod
Old 01-16-2008
60's guy's Avatar
60's guy 60's guy is offline
9th most annoying poster
60's guy has a reputation beyond repute60's guy has a reputation beyond repute60's guy has a reputation beyond repute60's guy has a reputation beyond repute60's guy has a reputation beyond repute60's guy has a reputation beyond repute60's guy has a reputation beyond repute60's guy has a reputation beyond repute60's guy has a reputation beyond repute60's guy has a reputation beyond repute60's guy has a reputation beyond repute
Axe,
Yup.........
Rod,
Isn't this also along the same design principles that bass traps and mid absorbers are based on.... utilizing sealed layers of mass to air ratios?
Not sure I worded that correctly.
Old 01-17-2008
Force of Nature
Originally Posted by 60's guy View Post
Rod,
Guy,
sealed traps work on that principle - yes.......
but the walls are working a bit differently in the sense that the purpose of the insulation is to damp the surface.
With a sealed trap you are looking to absorb the sound - and with a wall you are looking to reflect the sound.
If you place insulation up against the panel on a sealed trap it won't work.
In the case of an isolating assembly If you don't put it against the drywall - you will TL value will not be as high.
I hope that helped..........
Sincerely,
Rod
Going to Home Depot later, insulation or not? undrgrnd studio Studio Building & Display 3 11-06-2007 07:24
Bare insulation as room treatment? mcolling Studio Building & Display 7 10-05-2006 09:08
yet another insulation question... mixmkr Studio Building & Display 2 08-31-2006 08:57
Insulation In Double Wall Construction CPL Studio Building & Display 6 03-24-2006 02:06
Question about Acoustic Insulation ob Studio Building & Display 4 08-16-2002 13:11
