Go Back   Home Recording > Equipment Forums > Guitars and Basses
Reply    Audiofanzine Guitar Guitar News Guitar Medias Guitar Tests Guitar Articles Guitar User Reviews Guitar Classifieds Ads
Old 01-14-2008
BeniRose BeniRose is offline
Senior Member
BeniRose has a reputation beyond reputeBeniRose has a reputation beyond reputeBeniRose has a reputation beyond reputeBeniRose has a reputation beyond reputeBeniRose has a reputation beyond reputeBeniRose has a reputation beyond reputeBeniRose has a reputation beyond reputeBeniRose has a reputation beyond reputeBeniRose has a reputation beyond reputeBeniRose has a reputation beyond reputeBeniRose has a reputation beyond repute
Bass weak in the high notes
I have a problem with this bass I tracked. I have two channels, one's direct in and one's room mic'd, but both of them seem to be lacking any real volume on the higher notes. When the bassist hits the lower notes, it pounds through my sub (even when I turn my sub off, it's audible through just my 5" monitors) but when he hits the higher stuff, it practically disappears. I'm trying to tweek the EQ to bring out the higher notes, but I'm not sure what frequencies I should be aiming for, or if that's even the proper solution. Any and all ideas would be appreciated. Thanks!
Old 01-15-2008
fuzzrhythm fuzzrhythm is offline
Senior Member
fuzzrhythm has a reputation beyond reputefuzzrhythm has a reputation beyond reputefuzzrhythm has a reputation beyond reputefuzzrhythm has a reputation beyond reputefuzzrhythm has a reputation beyond reputefuzzrhythm has a reputation beyond reputefuzzrhythm has a reputation beyond reputefuzzrhythm has a reputation beyond reputefuzzrhythm has a reputation beyond reputefuzzrhythm has a reputation beyond reputefuzzrhythm has a reputation beyond repute
I have the same problem with my bass. I figure if re-recording is not an option, some compression could help you even out the difference between the lower notes and higher ones.
if you can re-track, try messing with the pickup height to kind of even things out a bit? or have the bass player be more conscious of this and try play a little more evenly
Old 01-15-2008
pikingrin's Avatar
pikingrin pikingrin is offline
My mom says I'm cool.
pikingrin has a reputation beyond reputepikingrin has a reputation beyond reputepikingrin has a reputation beyond reputepikingrin has a reputation beyond reputepikingrin has a reputation beyond reputepikingrin has a reputation beyond reputepikingrin has a reputation beyond reputepikingrin has a reputation beyond reputepikingrin has a reputation beyond reputepikingrin has a reputation beyond reputepikingrin has a reputation beyond repute
Or you could possibly try some cutting in the lower frequencies of the EQ. There have been threads on here that have been (loosely) related to this, in which there were some mentions of a low cut around 60hz. Try pulling out the lower frequencies to bring out the highs some. There should be a way to do it to where it doesn't interfere with the mids from the guitar/vocals/drums. It should only take a little experimenting with the EQ to make everything audible (but still sit well in the mix).
Edit: I'm pretty sure if you did a search in the Recording Techniques section you would probably find a load of information relating to your issue.
GFCG Member No. 000 016
SD:5058
My music...
Last edited by pikingrin; 01-15-2008 at 01:49.. Reason: Check out the Recording Techiniques forum
Old 02-01-2008
steve.h's Avatar
steve.h steve.h is offline
Somewhere Out There...
steve.h has a reputation beyond reputesteve.h has a reputation beyond reputesteve.h has a reputation beyond reputesteve.h has a reputation beyond reputesteve.h has a reputation beyond reputesteve.h has a reputation beyond reputesteve.h has a reputation beyond reputesteve.h has a reputation beyond reputesteve.h has a reputation beyond reputesteve.h has a reputation beyond reputesteve.h has a reputation beyond repute
I'm not sure if this might help or be related, but even string/note loudness is a quality many upper-scale basses have, and most lower-scale ones don't! It's hard to make all of the strings sound even when their mass/tension is so different.
www.myspace.com/ironthrones - my sweet metal band
www.myspace.com/stevehenningsgard - my recordings
Old 02-02-2008
Whale Bone Whale Bone is offline
Senior Member
Whale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond repute
Three things come to mind:
1- What EQ'ing is being done to the bass, if any. In particular, is there an active EQ on the bass itself? I've heard many players (I used to be one), and tried much gear that scoops the mid-range severely because it sounds good alone. This doesn't, however work in a mix. I found that the bass often has to sound a little harsh or brash with the mids to sound right in the mix. Make sure everything's flat. Maybe even boos the mids as an experiment. I've also had a couple basses whose preamps just didn't cut no matter what I did.
2- When I play with a pick, I sometimes notice the G string sounds thinner than with my fingers. Solution: see No. 3
3- Is it the higher strings whose high notes are disappearing? Try either changing fingerings to play the same figures higher up the neck on lower strings (may or may not yield a good sound for the application), or checking the angle of the pickup(s). Though pickups are supposed to be set level, I've angled many of mine to favor the high strings, i.e. raise the highstring side of the pickup, to get a good balance.
Good luck.
Old 02-03-2008
rayc's Avatar
rayc rayc is offline
L'ancien escargot
rayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond repute
Everything said so far is pretty food. The bassists tendency to EQ scoop is a common thing these days.
All I can offer in addition to the above is a fair sized EQ pinch at 3khz.
Cheers
rayC
soundclick, unearthed, mspace & utub
Mix Contest #9 Perdicament MP3 Mixing Clinic 297 02-06-2007 13:47
how do you sing high notes properly? fuzzychoir Newbies 17 07-12-2005 12:32
Bass Compression Question jeffoest Mixing / Mastering 1 11-25-2004 08:35
aardvark direct pro user.... Advice on recording DI Bass needed Rassoodocks Digital Recording & Computers 3 06-21-2003 18:18
Record some FAT Tool Like Bass notes for me! homeuser Guitars and Basses 6 01-31-2003 08:00
