Old 01-13-2008
snellular5's Avatar
snellular5 snellular5 is offline
neil young whore
snellular5 has a reputation beyond reputesnellular5 has a reputation beyond reputesnellular5 has a reputation beyond reputesnellular5 has a reputation beyond reputesnellular5 has a reputation beyond reputesnellular5 has a reputation beyond reputesnellular5 has a reputation beyond reputesnellular5 has a reputation beyond reputesnellular5 has a reputation beyond reputesnellular5 has a reputation beyond reputesnellular5 has a reputation beyond repute
need help fixing this problem
hey i have a little studio in my basement, one room that i do everything in, its about 7ft by 13ft and 7ft ceilings
i wanted to soundproof it as wenever i use mics in there i get alot of roomnoise on the tracks, like very noticable white noise.
wat would be the best idea for soundproofing and how should i do it.
any help is greatly appreciated
peace
Old 01-13-2008
Rod Gervais Rod Gervais is offline
Force of Nature
Rod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond repute
peace
First,
you are talking about 2 very different things here in the same breath......
soundproofing iis to stop outside noise from coming in - and to keep your sound from going outside............
Room noise (on the other hand) has nothing to do with sound proofing - and (as a matter of fact) will get worse the more you isolate the room.
So is the problem room noise - or the outside world?
BTW - just for the record here - typically a white noise sound would suggest to me (generally) a dirty signal chain - a problem with ground.......... a problem with dimmed lights on the same leg of power as my gear.........
I can't think of any room noise that I would describe the way you have.......
You might be barking up the wrong tree here.......
Rod
Old 01-14-2008
snellular5's Avatar
neil young whore
ah
ah my bad, i dont mind about sound leakage i guess i meant acoustically treat the room, but ya hmm ill check out wat u said bout the signal chain
thanx for the help
Old 01-15-2008
Dani Pace's Avatar
Dani Pace Dani Pace is offline
Why 2K?
Dani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond repute
I tend to think of "white noise" as almost a hiss more than a hum. Hiss can often be reduced by cutting some of the high frequencies, lowering the treble on amps and cutting the gain a little on preamps. You might also be picking up something like air movement noise from a heat/ac vent, or computer cooling fan, mics tend to pick up little noises that we don't notice untill we play back a recording.
The more I learn, the more I realize how much I don't know. http://www.soundclick.com/sixfeetover
Old 01-15-2008
Spikeh's Avatar
Spikeh Spikeh is offline
Gear Junkie
Spikeh has a reputation beyond reputeSpikeh has a reputation beyond reputeSpikeh has a reputation beyond reputeSpikeh has a reputation beyond reputeSpikeh has a reputation beyond reputeSpikeh has a reputation beyond reputeSpikeh has a reputation beyond reputeSpikeh has a reputation beyond reputeSpikeh has a reputation beyond reputeSpikeh has a reputation beyond reputeSpikeh has a reputation beyond repute
The input gain on your mixing desk / preamp may be set too high...
Old 01-19-2008
snellular5's Avatar
neil young whore
thanx
thanx for all the help guy taken them all into consideration
Old 01-19-2008
Force of Nature
Please give us a follow up on what solved the problem.
Rod
Sonar 4-5 "Random" problem (tough one) Thrawn Cakewalk / Sonar Forum 2 08-20-2006 14:18
Protools LE bouncing/recording/playback problem skibummer Digital Recording & Computers 19 08-04-2006 10:51
clicking and popping... a very common problem... drummersteve Recording Techniques 15 11-12-2005 16:59
Major Computer Problem Tekker Digital Recording & Computers 22 09-03-2005 07:00
PA9 Multi-track playback synch problem JimKelly_in_wa Cakewalk / Sonar Forum 0 05-31-2003 16:51
