Reaper 16 tracks at once?
Hello,
I want to record 16 tracks at once with 2 Presonus Firepods. Will Reaper do this? I doing it well with Logic 5 (which is great) but it is a bit unstable. Also I'd ideally run it on a old Sony Vaio 700Mhz laptop with an external usb hard drive. The Firepods won't work with the laptops mini firewire port, but I thought I could get a pcmcia firewire card and see if that worked.... any thought? Downloading Reaper now...! |
There are no track limits in Reaper, so try it & see...
You'll need to setup your device by going to the Options -> Preferences menu in Reaper when you first run it. Then go to Audio Devices on the left. And select the input ranges in the dropboxes. |
You might struggle on a PC that old but give it a try!
[generic spam/complaint/troll response] |
![]() Knock yourself out
DrummyQ VST New! Kompound Drums Vol 1 Sample Building Kit REAPER Merchandise REAPER Chat |
Wow - Go big or go home, hey Pipey ?
I try to keep mine under 20, but there are the nutters with the 200 track count stuff using reaper
Hey pipeline, I've been meaning to ask you..... how do I get the MP3 Render to work with Reaper ? What do I have to download ? |
Stick this dll in your c:\program files\reaper directory
I know its a PITA but its either that or charge everyone five bucks or whatever they want for the distributable
Was there supposed to be a link ?
Thanks man.
It's not a PITA to install this. It's a PITA to go without this !!! Now if you'll excuse me, I have some MP3's to mix down to.... |
#12
Worked like a charm.
Thanks again pipeline. |
#13
tascam 1804 self-built amd 4000+ system gateway m285-e core 2 duo tablet pc m audio sp-5b's reaper v1.8x |
#14
I don't know for sure, but I think it's because of the power needed. 4-pin firewire ports can't power the units.
#15
i did some research and its only power issues, i'll just have to use wall warts (phew)
| Mixing strategies for stereo tracks? | petimar | Mixing / Mastering | 8 | 05-29-2008 13:20 |
| Could be leaving Sonar for Reaper | therage! | Don't Fear The Reaper | 5 | 09-18-2007 20:36 |
| Just another thread! | Gorty | Roland, Boss, VS Series Forum | 314 | 08-27-2007 04:39 |
| need help with V tracks on BossBR8 | soundmaster | Roland, Boss, VS Series Forum | 10 | 01-31-2006 18:31 |
| Hiding and showing tracks | tombuur | Cakewalk / Sonar Forum | 1 | 08-05-2004 13:07 |
