Go Back   Home Recording > Equipment Forums > Drums and Percussion
Reply    Audiofanzine Drum Drum News Drum Medias Drum Tests Drum Articles Drum User Reviews Drum Classifieds Ads
Old 01-01-2008
skiz skiz is offline
Senior Member
skiz has a reputation beyond reputeskiz has a reputation beyond reputeskiz has a reputation beyond reputeskiz has a reputation beyond reputeskiz has a reputation beyond reputeskiz has a reputation beyond reputeskiz has a reputation beyond reputeskiz has a reputation beyond reputeskiz has a reputation beyond reputeskiz has a reputation beyond reputeskiz has a reputation beyond repute
how much of your snare sound should be coming from your overheads?
hey all
im a noobie to the homerecording stuff and i just want to know, how much of your actual final snare sound should come from the overheads? i ask this because my snare mic doesnt pick up that fat or great a sound no matter how i mic it. using an audix I-5 on it. The snare sound that comes from the overheads is much louder and better and natural sounding but im desparately trying to get a better and fatter sound from the snare mic its self
just wondering what everyone thinks of this
Old 01-01-2008
timthetortoise timthetortoise is offline
MADE OF SANDALWOOD
timthetortoise has a reputation beyond reputetimthetortoise has a reputation beyond reputetimthetortoise has a reputation beyond reputetimthetortoise has a reputation beyond reputetimthetortoise has a reputation beyond reputetimthetortoise has a reputation beyond reputetimthetortoise has a reputation beyond reputetimthetortoise has a reputation beyond reputetimthetortoise has a reputation beyond reputetimthetortoise has a reputation beyond reputetimthetortoise has a reputation beyond repute
What I've always tried to achieve is a balanced image of the kit from the overheads, and letting the other mics simply supplement that sound. It seems to render a beefy drum sound as well as give a nice stereo spread. However, getting a good tone from your snare mic makes a big difference and it sounds like you may need to work on either your mic technique or the tuning of the snare itself. Good luck!
http://www.myspace.com/sundrone
Old 01-01-2008
Senior Member
im really happy with the sound of the snare to my ear, just not recorded really. so i guess i need to toy with mic placements and everything too and have tried quite a few with no real success. perhaps im micing too close to the skin?
also the reason i asked the main question really is that if your snare mic is only supplementin the overheads, doesnt that make EQing the snare to your liking a bit of a mission? as the overheads will have the raw sound?
Old 01-01-2008
MADE OF SANDALWOOD
I usually use the top side of the snare to up the punch/beefiness of it, and do most of the actual EQing (getting the crisp snap sound) on the bottom snare mic. However, the overheads should contain the snare sound that you want (assuming you're miking from the top). Isolation of cymbals from everything else in overheads is a relatively pointless endeavor, as you are going to usually lose a lot of what the kit actually sounds like.
Old 01-01-2008
Senior Member
yeah im micing both top and bottom with audix I-5s
what do you think of these mics?
yeah i can definitely see what you mean about the overheads because they definitely give the kit a more natural sound thats a lot closer to what ones ear would pick up in the room.
do you think my room also might have an impact on how thin the sound is? i have sound deadening pads up on all the walls and the ceiling. Im not sure what kind of rooms are the best to record in. i can take them down to make the room a bit more live and was wondering if this would help at all?
Old 01-01-2008
Senior Member
also i was just wondering if i should roll off the lower end in the overhead condensers?
Old 01-01-2008
Rimshot's Avatar
Rimshot Rimshot is offline
Force of Nature
Rimshot has a reputation beyond reputeRimshot has a reputation beyond reputeRimshot has a reputation beyond reputeRimshot has a reputation beyond reputeRimshot has a reputation beyond reputeRimshot has a reputation beyond reputeRimshot has a reputation beyond reputeRimshot has a reputation beyond reputeRimshot has a reputation beyond reputeRimshot has a reputation beyond reputeRimshot has a reputation beyond repute
I just figured out your problem
You're mic'ing the top and the bottom of your snare with two different mics and you're not reversing the signal on the lower mic? Try taking the bottom mic out, and try it. Are you still getting a poor signal from the snare? If it is much better then you need to reverse the signal on the lower mic. This can often be done on a more sophisticated mixer (Unfortunately I don't have one of those) or my option is that you can get a phase reversal plug that you use like any adapter right on the mic cable.
The reason that this is happening is that you are sending two signals simultaneously that are occurring on two different ends of the curve and they are canceling each other out. It's like having two signals of the same frequency placed in the same place on your mix, instead of intensifying the signal, they cancel each other out.
You're using a relatively simple mic set-up, so I might just cut out the lower snare mic all together. I've gotten to a point where I'm recording my kit (six piece with lots of cymbals)
with a total of 4 mics. A coincidental stereo pair of matched small diaphragm condensers as overheads, a small dynamic instrument mic on my snare and a really good kick mic. The overheads pick up the whole kit nicely and have a good sound to the cymbals and hi-hat and then I can punch up the snare and kick when I need. Your room has to be good and you're good to go.
"There is no expedient to which man will not resort to avoid the real labor of thinking."
-Sir Joshua Reynolds
Old 01-01-2008
Senior Member
no i am reversing the phase of the bottom mic so i know thats not the prob
as far as a "good room" goes, what should i look for in a good room? my room is pretty much dead as i have deadening pads up on all the walls and ceiling but i can take them down as needed
Old 01-01-2008
Greg_L's Avatar
Greg_L Greg_L is offline
Gregois Le Bloodshit
Greg_L has a reputation beyond reputeGreg_L has a reputation beyond reputeGreg_L has a reputation beyond reputeGreg_L has a reputation beyond reputeGreg_L has a reputation beyond reputeGreg_L has a reputation beyond reputeGreg_L has a reputation beyond reputeGreg_L has a reputation beyond reputeGreg_L has a reputation beyond reputeGreg_L has a reputation beyond reputeGreg_L has a reputation beyond repute
What the hell is a deadening pad? Blankets and stuff?
Don't get too caught up in the O/H's providing the main sound of your kit. That mantra only applies if your room, kit, and tuning is really good. If any one of those is off, and the room almost always is, you'd do better to mix the close mic's in more. I personally prefer to use the close mics for most of my snare sound. It works because my room isn't optimum for drum recording. Also, make damn sure your O/H's are set up properly. Out of phase O/H's will fuck up everything.
Originally Posted by 60's guy View Post
Yeah! I'm a worthless fuck.
Originally Posted by The Ghost of FM View Post
Greg L is a real cool musician who offers great mixing advice in the mp3 clinic
Old 01-01-2008
Senior Member
they just one meter by one meter frames that i made and have sound insulating material in them. like sound wool. use them to deaden the room for band practice so that the sound dont bounce around and get less feedback frm the PA
got about 30 of em on the walls n ceiling
Old 01-01-2008
hipskind hipskind is offline
Newbie...and proud of it
hipskind has a reputation beyond reputehipskind has a reputation beyond reputehipskind has a reputation beyond reputehipskind has a reputation beyond reputehipskind has a reputation beyond reputehipskind has a reputation beyond reputehipskind has a reputation beyond reputehipskind has a reputation beyond reputehipskind has a reputation beyond reputehipskind has a reputation beyond reputehipskind has a reputation beyond repute
Or perhaps not close enough? Not there, so I can't be sure. I've always found close mic placement to produce a fatter sound than positioning the mic further away, which usually equals a thinner, more distant sound.
Yeah, I'd say you'd get a little less control over your mix that way, but the real question is: do you like the snare sound coming from the overheads? If you do then it doesn't matter as much. There's always going to be some level of blend between the overheads and the close-miked sound. Also, you could EQ the overheads somewhat similarly if you felt you needed to--no law against that--and see if the adjustment doesn't change the sound of your cymbals too much, though that can be dicey territory. But that's the beauty of mixing (especially in the digital domain): try it and see!
That depends on many factors; I, personally, have done plenty of both, i.e. leaving the overhead image completely flat, and rolling off all lows and even low-mids. I'd say the first question is: are you miking the toms? If not then you'll need all the beefy low-end you can get in your mix. If you are, and are going for an overall cleaner kit sound (as opposed to a more natural, more ambient drum sound), then you can EQ to taste on that. Try it and see how you like it.
  #12
Old 01-01-2008
mixsit mixsit is offline
Been Here, Posted That
mixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond repute
... i ask this because my snare mic doesnt pick up that fat or great a sound no matter how i mic it...
... The snare sound that comes from the overheads is much louder and better and natural sounding but im desparately trying to get a better and fatter sound from the snare mic its self
Since it's us pretty hard to separate snare tone from the 'solo vs o/h combined, what if we went down this list -where would you land..?
Snare tone is 'good and natural' in the o/h's -but not the 'fat?
Snare tone itself (and how it's hit-
The snare as a mix of o/h and snare tracks- there's never being 'exactly in phase' here, but as the primary eq'/tone source of polarity and o/h distance.
Compression to alter or extend the shape (if this 'fat isn't natural at all)- either on the kit mix' or snare tracks?
Monitoring at CathouseSound AetherAudio 'Continuum A.D. and TimePiece 'Mini
(formerly S.P. Technology
  #13
Old 01-03-2008
nreece nreece is offline
Newbie
nreece is on a distinguished road
if you are in a small room that's the main problem. comb filtering and low frequency build up are jacking up the sound that the mics capture.
Here are the things that have been successful for me in acheiving a nice snare crack in a small room.
1. Use a condensor mic in omni mode behind your left shoulder (assuming you are right handed). I use an AKG 414 with the low cut filter set to cut everthing below 160hz. this picks up a nice snare crack and will provide good overall sound for the entire kit. It also adds fatness to your kick sound. You may need to place a piece of studio foam between the Omni mic and your hi hat to tame it a bit. Make sure the foam isn't blocking the path between the snare and the mic.
Use this one mic in place of stereo overheads. Stereo OH's in a small room are just going to produce a crapy sound in most cases...especially cardioids. In your mix, pan this omni mic between 10 and 11 o'clock.
2. The I5 mic is good but not in a small room...it's too dark. go get a Sure beta 57A. It will immediately brighten up your sound. Pan this mic between 1 and 2 o'clock.
3. Mix these two sources according to the style of music you are recording.
for example, most pop music will require a 50/50 mix. For jazz, back down your top snare mic to almost nothing. For rock or any style requiring a big snare crack, turn down the OMNI slightly and boost your snare mic...40/60.
4. when mixing, you'll need to cut a lot of low end out of your mix so that your snare sound is heard. cut your top snare mic at 180hz. cutting as much as 10db is usually fine and will help define your snare sound. Also, add some high eq between 4k and 8k. use a moderate Q setting so that it covers this range but no more and no less. boost about 4 db.
5. compress the omi mic using a moderately fast attack and a medium release time at about 4:1 ratio. multi band plugs in your DAW might work better than a traditional comp. experiment with cutting some more low end on this track too. often cutting below the 200 - 300hz range works well. this makes your cymbals sustain longer without having to turn them up louder and also further enhances your snare. remember, when compressing drums, the low end gets louder so, the more you compress, the more low end you need to cut with EQ.
6. cutting all of the low end from your snare and omni tracks will clear up your sound considerably but, it also "robs" your tracks of a lot of energy. It is absolutely imperative that you pump them back up to get that crack. You need to do few things to accomplish this.
First, send your entire drum mix (all tracks) to a buss.
Second, you need to run this buss mix into a good pre-amp. this boost your signal back to a nice hot level and adds some distortion. Distortion is part of what makes your snare sound. turn up the gain on the pre-amp until you just start to hear the distortion effect, then back it off one notch.
Third, compress this mix again. some pre-amps will handle both for you.
7. you should now be getting a pretty good sound. If not, it's probably attributable to one, or both, of two things:
Pre-amps and room.
These are the two biggest limiting factors in recording drums...third I would say is mic selection.
Pre-amp suggestions: JLM audio TMP-8. This pre gives a big fat warm and somewhat aggressive sound. it's about 2k from JLM audio. I love mine. you'll find it at jlmaudio.com. Be sure to order both sets of limiter plugs with the unit. These allow you to record straight into a DAW while still leaving headroom for EQ.
Focusrite Red 5. This pre is about the same price but only has 4 pre's instead of 8. Excellent clean pure sound. great for pop,rock and jazz. probably too clean for certain types of music that require more attitude from the drums.
Pre-amps will make a huge difference.
Room: if you are in a small room on carpet, you won't get that snare sound you are looking for. concrete floor or wood floors are best. use as small a rug as you can get away with just to keep your kick from creeping away from you. A hard floor and a soft ceiling is a good combination. Treat a drywalled ceiling with some foam spaced at fairly close intervals accross the ceiling. treat an open rafter ceiling with standard fiberglass insulation. just "spot" treat the walls with foam anywhere you have a drum or cymball nearby...especially if your hi-hat is close to a wall. no more foam is needed. too much foam is not good. If you can afford it, buy some bass traps for the corners. Auralex makes affordable kits, and real-traps makes the high dollar professional units.
Finally - the last thing that makes a good lively snare sound is reverb. In a small room, this is almost impossible to acheive using room mics or digital reverb units. The best method I've come accross is to use "Drumagog" and the Steven Slate Z4 room sounds. You can purchase both from drumagog.com. The way I use it is to place drumagog in an effects bus and load the z4 sample. Turn the mix to 100 percent. Then, key this sound by turning up the effects send knob on your snare drum track. This will give you a high quality room sound to add to your snare track. If you add a compressor pluging to the z4 track, it makes a very nice big reverb sound that you can turn way up in the mix.
Let me know if this helps.
  #14
Old 01-03-2008
Newbie
1. Use a condensor mic in omni mode behind your left shoulder (assuming you are right handed). I use an AKG 414 with the low cut filter set to cut everthing below 160hz. this picks up a nice snare crack and will provide good overall sound for the entire kit. It also adds fatness to your kick sound. You may need to place a piece of studio foam between the Omni mic and your hi hat to tame it a bit. Make sure the foam isn't blocking the path between the snare and the mic. this works best if your kit is centered in the room.
2. The I5 mic is good (I own one) but not in a small room...it's too dark. go get a Sure beta 57A. It will immediately brighten up your sound. Pan this mic between 1 and 2 o'clock. Use the I5 on one of your toms...killer!
Pre-amps and room.
  #15
Old 01-04-2008
RAMI's Avatar
RAMI RAMI is online now
www.ramirami.com
RAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond repute
........please......................someone.
  #16
Old 01-04-2008
Yes?
12345
  #17
Old 01-04-2008
Rimshot's Avatar
Force of Nature
I just have to say this...........
Why is it that some of the simplest old recordings done of the great jazz drummers of the past had such great sound? I doubt very much that they used such sophisticated and complicated mic set-ups as we are talking about............. just an observation.
Maybe they put more concentration on the dynamics of their playing?
  #18
Old 01-04-2008
Greg_L's Avatar
They used samples!
  #19
Old 01-04-2008
Newbie
Yes, it's true that the drummer is the biggest factor in getting a good sound...not the gear or recording techniques. But, let's not under estimate how good the rooms, equipment, and engineers are in most professional studios. Even the great "old" jazz recordings were done in bigger rooms than most us will ever have the chance to record in. Most people don't realize just how much of an advantage this is. In addition, the mics were better, the consoles were killer, the signal processing was awesome and the engineers had enormous talent. Just because they were recorded 50 years ago doesn't mean these people weren't top notch professionals. Couple this with the ability of a guy like Buddy Rich or Louie Belson and you end up with one Hell of a recording.
The issue here is to help a guy like Skiz get a good sound, in his own home studio, with whatever level of talent he/she has.
Skiz, I suggest you try some of these techniques for yourself. I'm quite confident your sound will improve "big time". Mine has improved significantly over the years and I'm no where near as talented or accomplished a drummer as the great jazz players of yester-year.
  #20
Old 01-05-2008
Elton Bear Elton Bear is offline
Unregistered Abuser
Elton Bear has a reputation beyond reputeElton Bear has a reputation beyond reputeElton Bear has a reputation beyond reputeElton Bear has a reputation beyond reputeElton Bear has a reputation beyond reputeElton Bear has a reputation beyond reputeElton Bear has a reputation beyond reputeElton Bear has a reputation beyond reputeElton Bear has a reputation beyond reputeElton Bear has a reputation beyond reputeElton Bear has a reputation beyond repute
There's a lot to be said for the oldskool engineers, with no solo button on the desks, for example, they had to know what compression, EQ, etc. etc. to add to each sound when they had a whole track playing back at them, and a lot of the time they had to record straight to tape with no fallback.
No 'fix it the mix' 'coz there wasn't a mix (as such)!
Kicking it lo-fi:
POS computer
Cubase SX2
M-Audio Delta 1010LT
ART Studio V3 Tube MP
Behringer Eurorack Desk
AKG C3000B
Shure SM58
Shure SM57
Sennheiser e818 S II
Ashton DMP-100 drum mics
  #21
Old 01-05-2008
[snip]
I don't mean to hijack this thread, but hey, nreece, thank you for all that information! I have a drum room right now with which I've had some similar issues. I've been wondering if I've deadened the room a bit too much, and I think I probably have. I've struggled with getting the snare sound bright and lively enough--and obviously don't want to go totally over the top with EQ (i.e. 10+ db high-shelf, etc...). I think I'll need less "absorption" and more "diffusion".
Also, I appreciate your suggestions for good drum mic preamps. Have you (or anyone) had any experience with the API 3124? I've had my eye (and ear) on this one for a while.
  #22
Old 01-05-2008
Newbie
Hipskind,
I'm glad to help. I've been reading recording forums for years now and it's places like this that have helped me immensely. As for your room having too much absorbtion, It's quite possible that this is contributing to your lack of a quality snare drum sound. I made the same mistake myself when I built my jam room. I converted the 3rd stall of my garage into a small studio and treated the entire thing in fibrous sound board from Home Depot. It turned out to be way too dead. over time I've "livened" it up using pine boards. Pine is a good reflective source but still warm.
Back then the floor was covered in rugs which was further deadening my sound. Now days I only use a small rug, only big enough for my throne, kick, and hi-hat stand. This allows all my drums, especially snare, to sound more lively in the mix.
As for the API pre, I have never used one but would love to. I'm sure they are killer. Many many pro recording have been made with these. The new BFD acoustic drum module from FXpansion was tracked using API's and the sound is really good.
Despite not having first hand experience with the API pre's I will say this about pre's in general. They make a huge difference....I mean huge! Don't listen to people who say otherwise. I was using a Mackie 1604 board for years and was told that the preamps were good so I didn't think they were limiting my sound in any way. I was wrong. When I switched to the JLM TMP-8 I was blown away by the improvement in my sound, instantly...with no other changes to my other gear. good pre-amps help you transition from that typical small room crappy sound (muddy, woofy, inarticulate) to more of that spacious and dynamic sound that we all hear on the radio and want for our own recordings. Now days I only use my Mackie board for monitoring but it isn't in the signal path between my mics and recorder. it just adds to much low end and isn't very 3 dimensional.
If you could do 5 things that will make a dramatic improvement I'd say do these first:
1. get some good pre-amps (API's, JLM audio, focusrite Red5, Universal Audio, Neve, all make pre's in the $2k range that will make a huge difference. Personally I think the JLM TMP-8 is the best bang for your buck. It costs about $1,850 for 8 preamps. that's less than $250 per pre and they sound excellent. You can mic your entire kit. Check out jlmaudio.com. Joe Malone, the owner, builds custom mods of Neve consoles, API pres etc. and really knows his stuff. He will also chat with you personally by email. They are based in Australia so it takes about a week to a week and a half to get your order but it's worth it.)
2. remove some of the deadening in your room and add diffusion
3. use 1 overhead or rear mic, condenser, in omni mode vs. 2 spaced cardioids for overheads. go for more of a mono sound in a small room and keep your mic(s) lower to the ground as opposed to up high. the OMNI mode makes for a much better cymball sound and adds way more ambiance to your mix than cardioids. They also do not add low end frequency to your mix due to proximity effect.
4. run your final stereo drum mix back through the same preamps again after you've done all of your EQ and signal processing to liven it up...this is a huge key! A little compression here will also make your drums sound punchy.
5. tune your snare drum tighter than you might normally like to hear it. this will result in less low frequency being thrown around in your room. It might sound a little weird to your ears at first but, when you play back your recording it will sound fine. Also, don't deaden that snare too much with muffling or rings or things like that. those deadringers (small plastic ring 14 inches in diamter and about 1 1/2" wide) sound cool but don't record well in a small room. what I do is to take a deadringer and cut it so that it's only about 2-4 inches long and lay it on my snare head up next to the rim. this deadens the wild ass transients just slightly but otherwise leaves that open snare sound in tact. I've also had better luck with metal snares than wood in a small room.
Have fun.
  #23
Old 01-05-2008
Thanks man! I really appreciate all of your insight. I always suspected that good (really, really good) mic pres were a big ingredient to a good drum sound, even when some people told me otherwise. Right now I'm in the middle of a home purchase, so I'm afraid the APIs will have to wait...
Thanks again.
-Tom
  #24
Old 01-10-2008
Senior Member
hey nreece,
just wanted to ask what you thought of the set up im using,
im recording digitally with a presonus firepod in cubase. im using a shure beta52a on the kick, 2 marshall MXL-604s as stereo overheads, and an audix I-5 on the snare and audix I-5 on the batter side of the kick for more attack when using double pedal.
yeah the room im recording in isnt huge and is carpeted and also been deadened a bit. i took the pads i had on the walls down and its helped a lot but still strugglin a bit. maybe because i left the pads on the roof up? My friends cottage has recently become available and the main room in it is pretty large and has tiled floors and just a normal ceiling. How do you think this room will do? i duno about the tiled floors i would prefer them to be wood but just wanted to see what you thought of this.
also if i did record in the tiled room, where abouts in the room would be good to set the kit up? in the middle? closer to a wall? what do you think?
any way just wanted to see what you thought of this.
  #25
Old 01-10-2008
frott frott is offline
Newbie
frott has a reputation beyond reputefrott has a reputation beyond reputefrott has a reputation beyond reputefrott has a reputation beyond reputefrott has a reputation beyond reputefrott has a reputation beyond reputefrott has a reputation beyond reputefrott has a reputation beyond reputefrott has a reputation beyond reputefrott has a reputation beyond reputefrott has a reputation beyond repute
Try a "snare mic" test.
Take a bunch of mics and set them up all around the snare. On the edge, hanging over it in the middle, on the shell, etc.
Listen to them all, find the best one.
I was forever using a standard position that I'd seen so many places that I just took for granted as being "correct" of an inch or so above the rim pointed towards the middle. I too was getting more snare out of the overheads and just figured I'd use the close mic to get the pop sound.
But then after doing this test, I found that literally hanging the mic above the middle of the snare 1 or 2 inches got a huge, great sound. Never mind the whole "impossible to actually hit the drum like this." ;P From there I just found a good spot.
Also look up the recorderman/glyn johns setup. Hanging your overhead directly over the snare a few feet, with your other overhead the same distance away over the drummers shoulder pointed at the snare, with a direct snare mic getting those high pops.... powerful.
Alan... No Stephen Paul Mic? DJL Microphones 249 07-27-2007 23:47
Would a PCM91 or similar transform my music hemmick reef The Rack 9 01-27-2007 08:25
Choosing a sound card for newbies! MichaelM Newbies 30 03-11-2006 21:25
Trying to get the perfect snare sound... which snare should I buy??? pisces7378 Drums and Percussion 2 08-16-2004 06:02
SMOOTH, HOMOGENOUS, EXCITING mixes... Is it possible??? Mercuri Recording Techniques 69 12-07-2002 20:05
