Old 12-29-2007
light40's Avatar
light40 light40 is offline
Junior Member
light40 has a reputation beyond reputelight40 has a reputation beyond reputelight40 has a reputation beyond reputelight40 has a reputation beyond reputelight40 has a reputation beyond reputelight40 has a reputation beyond reputelight40 has a reputation beyond reputelight40 has a reputation beyond reputelight40 has a reputation beyond reputelight40 has a reputation beyond reputelight40 has a reputation beyond repute
Will my foam adhesive tear down the drywall?
I have foam panels on the wall in the vocal booth, however they are held up by small nails that are starting to tear ever growing holes in the foam panels. When I bought the foam panels they came with "313 Foam & Fabric Spray Adhesive" and I didn't use this because I am still living with my parents and they don't want the drywall to be pulled off when I move the studio somewhere else.
So, if I use the adhesive to attach the panels, will they tear away the drywall when I remove them?
The bottle offers a "temporary or repositionable bond" if I spray only the wall. Will this hold the panel but prevent me from damaging the drywall later on?
Thanks for your help,
-Alex
Old 12-29-2007
60's guy's Avatar
60's guy 60's guy is offline
9th most annoying poster
60's guy has a reputation beyond repute60's guy has a reputation beyond repute60's guy has a reputation beyond repute60's guy has a reputation beyond repute60's guy has a reputation beyond repute60's guy has a reputation beyond repute60's guy has a reputation beyond repute60's guy has a reputation beyond repute60's guy has a reputation beyond repute60's guy has a reputation beyond repute60's guy has a reputation beyond repute
-Alex
If you didn't use the adhesive in the first place...why are you asking the question post haste?
It stands to reason though that if you use any type of glue to bond your foam panesl to drywall that there could be a sticky problem when it comes to removal. Common sense sort of dictates that......don't ya think?
Old 12-30-2007
light40's Avatar
Junior Member
I'm asking now because the panels are about to fall down because the holes are getting so big. I need to find a different way to keep them on the wall.
I know that it will will be a sticky removal, I just want to know how sticky it will be.
Old 12-30-2007
mixmkr's Avatar
mixmkr mixmkr is offline
we don't need rest!!
mixmkr has a reputation beyond reputemixmkr has a reputation beyond reputemixmkr has a reputation beyond reputemixmkr has a reputation beyond reputemixmkr has a reputation beyond reputemixmkr has a reputation beyond reputemixmkr has a reputation beyond reputemixmkr has a reputation beyond reputemixmkr has a reputation beyond reputemixmkr has a reputation beyond reputemixmkr has a reputation beyond repute
glue them on pieces of paneling or quarter inch plywood, etc... and then hang it like a large picture.
Old 12-30-2007
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
The glue will ruin the drywall. It will either tear off the paper or leave a sticky residue that you can't sand off or really paint over.
If you don't like the plywood idea, try heavy construction paper.
I made the mistake of gluing these things to the wall. The walls are messed up and every time the humidity changes half of them fall down.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 12-31-2007
Supercreep's Avatar
Supercreep Supercreep is offline
Immortalizes Your Member
Supercreep has a reputation beyond reputeSupercreep has a reputation beyond reputeSupercreep has a reputation beyond reputeSupercreep has a reputation beyond reputeSupercreep has a reputation beyond reputeSupercreep has a reputation beyond reputeSupercreep has a reputation beyond reputeSupercreep has a reputation beyond reputeSupercreep has a reputation beyond reputeSupercreep has a reputation beyond reputeSupercreep has a reputation beyond repute
As suggested, glue them to cardboard or wood and then tack 'em up.
Old 12-31-2007
whyseye's Avatar
whyseye whyseye is offline
Been Here, Posted That
whyseye has a reputation beyond reputewhyseye has a reputation beyond reputewhyseye has a reputation beyond reputewhyseye has a reputation beyond reputewhyseye has a reputation beyond reputewhyseye has a reputation beyond reputewhyseye has a reputation beyond reputewhyseye has a reputation beyond reputewhyseye has a reputation beyond reputewhyseye has a reputation beyond reputewhyseye has a reputation beyond repute
Any sonic advantages or disadvantages to using foam core board?
It's costlier than construction paper, but far more rigid, and much lighter than wood....
Whyseye Sight
Old 01-01-2008
Dani Pace's Avatar
Dani Pace Dani Pace is offline
Why 2K?
Dani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond repute
Forget the tacks or small nails. Mount the panels with screws and use a washer on both the front and back side to prevent the foam from tearing.
The more I learn, the more I realize how much I don't know. http://www.soundclick.com/sixfeetover
Help with Foam gbondo9 Studio Building & Display 0 09-06-2007 14:02
Dwarfs studio pt. 2 dwarf Studio Building & Display 9 07-22-2006 13:54
Cheaper Alternative to Acoustic Foam? phatmass Studio Building & Display 2 05-19-2005 11:53
What spray adhesive for foam tiles? StanS Studio Building & Display 7 01-10-2003 15:06
Foam Acoustic Wall Treatment... I really need help! pisces7378 Studio Building & Display 5 01-09-2003 15:05
