Need advice for Layla20 problem
Hoping someone can help with this problem: have a layla20 that has worked superbly for 8 years. Recently moved it from it's original computer (Win98/Sawplus) to my new computer (XP pro/SawStudioLite). Installed the latest driver (6.11 beta). Sound is terrible...static/distortion. Tried every buffer setting combination possible...best is 6 buffers/512 samples...but still the sound is unusable. Have tried Purewave, WDM and ASIO modes...all with the same results. This Dell dimension 8400 has a built in sound driver (Sound Max). Please advise and THANK YOU!
Wish I could help you. I run wdm drivers on my layla 24's. I never get issues that way.
I've tried asio and purewave but they seem more glitchy. I personally always disable the stock sound card and make the echo my default card. I also always disable computer sounds so the computer won't send 8 bit low sample rate sounds through the card. I am not familiar with your editing software. I would swap out any cables to double check that you dont have a coincidence going on. Make sure that there are no settings in yout echo console or in your editing software that exceed the bit and sample rate of your card. You might also try reinstalling the drivers if all elses fails. Maybe go to a previous driver release. Good Luck. F.S.
"If Congress can do whatever in their discretion can be done by money, and will promote the General Welfare, the Government is no longer a limited one, possessing enumerated powers, but an indefinite one" James Madison: the father of the Constitution |
I will say, over the last 8 years I have had TWO Layla20's bite the dust on me. HOWEVER!! I now own a Layla3G. btw... the beta drivers you are using are all that are available for XP, if I am not mistaken. |
I agree also. For my Mia I do use the ASIO drivers for out's 1-6 and WDM for 7 and 8, which I've made Windows' default audio device. The WDM drivers helped some issues for playback with various other programs.
How do you like that 3g. I have a Layla 24/96 and wondered if it would be a step up or down. As for the Layla 20 question, I had to have someone else put my soundcard in, so I can't help much. Wish I could!
What?! |
ps...I also prefer the wdm drivers to the asio drivers on mine.
What?! |
You can also use this one from Radio Shack if you don’t want to wait. http://www.radioshack.com/product/in...tId=2062582&cp It could be other issues as well, but this is one to be aware of. ![]()
«:: «::B::» «::E::» «::C::» «::K::» ::» "Where in the hell are the red M&M's?" ~My Lil' Sister, 1976 |
The 3G has two built-in pres which I've found very usable. YMMV and I've read some gripes about them, but IMO they're pretty clean and have decent gain. For built-in pre's, they get the job done. I've been using ASIO drivers with the 3G and it's been pretty stable. Haven't tried the WDM/KS drivers - not sure if they would better or not than ASIO. |
| Cubase LE or PreSonus Firepod Problem? | Confusitron | Cubase User Forum | 2 | 10-31-2005 18:44 |
| What's wrong with this song? Phase problem? | gravehill | Mixing / Mastering | 20 | 05-31-2005 04:47 |
| problem with amp | donkeystyle | Guitars and Basses | 8 | 04-08-2005 15:57 |
| a problem with bass guitar signal | trispectrum | Recording Techniques | 11 | 02-04-2005 12:51 |
| Seems like I got a soundcard problem... | Beathoven | Other Equipment and Reviews | 2 | 12-11-2001 07:56 |
