Old 12-28-2007
ofajen ofajen is offline
Daddy-O Daddy-O Baby
ofajen has a reputation beyond reputeofajen has a reputation beyond reputeofajen has a reputation beyond reputeofajen has a reputation beyond reputeofajen has a reputation beyond reputeofajen has a reputation beyond reputeofajen has a reputation beyond reputeofajen has a reputation beyond reputeofajen has a reputation beyond reputeofajen has a reputation beyond reputeofajen has a reputation beyond repute
Yamaha AW1600 question: mix automation via scenes?
So, I'm trying out this Yamaha AW1600 and generally having a good time with it. However, the manual gives little discussion to creating and using "scenes". I'm assuming that since all parameters can be saved in a scene, that one can automate mixing somewhat by just programming scene changes throughout a song. However, there really isn't any explanation of how to do this in the manual. When you push the "scene" button you can move through three pages: library, recall safe and pc table. The manual doesn't mention what pc table is but it seems to map a sequence of scenes to scene library entries. Can anyone help me out here with how to program scene changes into a mix, or let me know if this can't be done? Thanks!
Cheers,
Otto
Mixing secrets by sonusman s_o_n_u_s_m_a_n Mixing / Mastering 261 05-14-2009 19:26
Yamaha Pro Mix 01 and S4 jazzbass12 The Rack 0 02-20-2006 05:07
Using Yamaha Pro Mix 01 with M-Audio Omni I/O: Best setup advice needed jonmatthews The Rack 2 10-30-2004 16:07
Wave PAZ weighting (or general Analysis) EQ / Mix question also Genelec question caseybasichis Mixing / Mastering 6 10-18-2004 20:04
Signal Patching in Yamaha MG10/2 - Monitor Mix? sleepnotwork The Rack 13 06-01-2004 20:35
