Old 12-26-2007
Slowjett Slowjett is offline
Force of Nature
Slowjett has a reputation beyond reputeSlowjett has a reputation beyond reputeSlowjett has a reputation beyond reputeSlowjett has a reputation beyond reputeSlowjett has a reputation beyond reputeSlowjett has a reputation beyond reputeSlowjett has a reputation beyond reputeSlowjett has a reputation beyond reputeSlowjett has a reputation beyond reputeSlowjett has a reputation beyond reputeSlowjett has a reputation beyond repute
Event 20/20.. Just not cutting it. Add a sub, or new monitors?
Hey guys!
It seems like I cant hear the bass in my active event 20/20's. They sound fine, it seems like the bass just isnt where it should be, like its db's lower. Im wondering if I should sell these and get new set or monitors. Or if I should get some sort of active sub to add on to supplement. What are your opinoins?
I do mostly acoustic rock type of music. Mostly acoustic instruments and electric bass. Not a lot of drum kits.
Thanks so much,
Josh
Old 12-26-2007
Massive Master's Avatar
Massive Master Massive Master is online now
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
It's probably your room...
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
Old 12-26-2007
Force of Nature
I've considered this, but the fact remains that when I mix with my "B reference" set of monitors (basic stereo system - Bose cube speakers placed on top of my Events, with a Bose Sub under the desk) it sounds great, but I know Im not getting it all. Its just for stereo reference. Plus aren't nearfields supposed to not depend as much on the room? The room is irregularly shaped and has an arched typed of ceiling. I'm pretty sure I'm hearing whats coming from the monitors and Im missing the low end. I should A/B some mackies or somthing (go to Guitar center and get a rental set ).
Old 12-27-2007
It's more likely that you're hearing exaggerated and hyped bass from the Bose speakers.
Oh come on now - Inaccurate and skewed low end from Bose? What's next?!?
Old 12-27-2007
COOLCAT's Avatar
COOLCAT COOLCAT is offline
2.5K Gold Member
COOLCAT has a reputation beyond reputeCOOLCAT has a reputation beyond reputeCOOLCAT has a reputation beyond reputeCOOLCAT has a reputation beyond reputeCOOLCAT has a reputation beyond reputeCOOLCAT has a reputation beyond reputeCOOLCAT has a reputation beyond reputeCOOLCAT has a reputation beyond reputeCOOLCAT has a reputation beyond reputeCOOLCAT has a reputation beyond reputeCOOLCAT has a reputation beyond repute
Walk around your room while the music plays and see if you can find your low end.
if it's not happening in the room, it ain't gonna happen on tape.-HG
Old 01-30-2008
Force of Nature
Well your right, I found the low end does increase when I do a bit of walking around. What should I do about it?
-Josh
Old 01-31-2008
talontsiawd talontsiawd is offline
Dedicated Member
talontsiawd has a reputation beyond reputetalontsiawd has a reputation beyond reputetalontsiawd has a reputation beyond reputetalontsiawd has a reputation beyond reputetalontsiawd has a reputation beyond reputetalontsiawd has a reputation beyond reputetalontsiawd has a reputation beyond reputetalontsiawd has a reputation beyond reputetalontsiawd has a reputation beyond reputetalontsiawd has a reputation beyond reputetalontsiawd has a reputation beyond repute
My friend has 20/20's and the bass seems to be fairly loud imo. I thought they were a bit bass heavy to be honest. I think room treatment never hurts. I personally like using a sub as well though. I do not mix with a sub though, i just reference it as well as turn it on when i'm actually tweeking sounds at a low frequency. I find this to be a great way to go when you have little control over the room. I personally would not invest in new monitors just for lowend because i don't think you will get what you want. If you want to upgrade to something nicer for other reasons, sure, but not just for that.
Old 02-01-2008
Whale Bone Whale Bone is offline
Senior Member
Whale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond repute
I can believe it's a room issue. I have Event TR-6s that sounded incredible in my last house in a smallish, but sufficiently non-reflective room. When I moved however, I lost all my bottom end. I would've never believed the room made that big a difference.
I've seen multiple threads around here with tips or links to tips on prep'ing rooms. Eliminating corners and breaking up parallel surfaces, i.e. walls. Check in recording techniques forum.
how much would you pay for second hand EVENT TR8 monitors ? earworm Mixing / Mastering 9 08-12-2004 05:17
Event TR8 Monitors? Picker Other Equipment and Reviews 3 07-18-2003 16:43
Event 20/20 Toy Room Free Ads for Music / Recording Equipment 0 07-17-2003 22:31
Do Event 20/20 monitors match Samson Servo 260? VartRecords Newbies 1 01-13-2000 07:47
