Old 12-21-2007
punkin's Avatar
punkin punkin is offline
Univalve & Avatar Speaks
punkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond repute
Unhappy Delta 1010LT Driver Update went badly. Any help would be appreciated.
I purchased a lightscribe capable CD/DVD burner this week. The unit was bundled with NERO 7. After installing it and realizing that NERO is a HUGE resoure hog, I deleted it. After deleting, it scragged all three of my audio card divers (1 each SoundBlaster and 2 each Delta1010 LT). I reinstalled my SounBlaster Drivers which recoved the use of that card however, when I attempted the same for my Delta1010 LTs...not such a positive turn out.
I deleted the card from my hardware manager, uninstalled the Delta apps then followed up by cleaning out the remaining folder. After that, I ran Registry Mechanic just to be sure it was all clean then followed up with a reboot.
Upon reboot, the system "realized new hardware" in the form of a "multi-media audio controller". I went to the M-Audio website, downloaded the latest Delta1010 LT drivers and performed the install. Still no joy.
Currently, I have in my hardware device manager under "Other devices" a "?! Multimedia Audio Controller" and under "Sound, video and game controllers" a "Delta 1010LT". When I open my Delta Control Panel, no audio cards are found. In the device driver under the Delta Card, the "general tab" it states that this device cannot start (Code 10).
Anyone with any ideas? I've deleted the card several time...several, I've also downloaded and installed several older driver version just to be sure that it wasn't a problem with the latest release. I sure would like to get this back up and running.
I have sent emails to M-Audio and no responses so far and currently even yet while I type, I've been on hold/in-que with on the support line (for about 1 Hr., 15 minutes now).
She's not the boss of me
Old 12-21-2007
axeman_ukl axeman_ukl is offline
Dedicated Member
axeman_ukl has a reputation beyond reputeaxeman_ukl has a reputation beyond reputeaxeman_ukl has a reputation beyond reputeaxeman_ukl has a reputation beyond reputeaxeman_ukl has a reputation beyond reputeaxeman_ukl has a reputation beyond reputeaxeman_ukl has a reputation beyond reputeaxeman_ukl has a reputation beyond reputeaxeman_ukl has a reputation beyond reputeaxeman_ukl has a reputation beyond reputeaxeman_ukl has a reputation beyond repute
try this goto you device manager disable both the 1010 cards.
install the latest drivers
reboot the pc
undisable the audio cards one at a time,windows should find them and install the drivers.
then reboot
then do the other
i say this because you are ment to install the drivers before fitting the cards to the pc
Old 12-21-2007
punkin's Avatar
Bingo!
I tried your idea but it seemed to go "half-way". The cards were redisovered but still a dis-association with the drivers. I couldn't point them to the new drivers. Your idea inspired me to try one more thing.
Here's what I did;
Uninstalled "Delta" from the Add-Remove Programs
From hardware manager un-installed the cards
Powered down the PC
Removed the cards
Rebooted the PC
Reinstalled the Delta Drivers
Powered down the PC
Reinstalled the cards
And WOO-HOO! I'm back up and running!
I was getting nervous...M-Audio tech support is only open Mon-Fri and I was betting they'd be lightly staffed (IF at all between Christmas and New Years). I've got a couple session parties this weekend and I was really sweating it!
Man, again, thanks for the support on this one
Thanks for the shout back! THanks!
delta 1010lt or Aardvark pro lx6 royharper3220 Digital Recording & Computers 2 06-04-2004 12:13
Problem with Music Creator 2003 and Delta 1010LT Sippy Cup Cakewalk / Sonar Forum 9 11-14-2003 16:48
Is Delta 1010 worth $200 more than Delta 1010LT? Jedman Digital Recording & Computers 18 03-04-2003 20:14
Delta 1010LT and output rcarruth Digital Recording & Computers 0 02-05-2003 12:32
Shure SM58 & Delta 1010LT triple cubic Digital Recording & Computers 2 01-29-2002 17:41
