Old 12-20-2007
mattkw80 mattkw80 is offline
Newbie 4 EVA
mattkw80 has a reputation beyond reputemattkw80 has a reputation beyond reputemattkw80 has a reputation beyond reputemattkw80 has a reputation beyond reputemattkw80 has a reputation beyond reputemattkw80 has a reputation beyond reputemattkw80 has a reputation beyond reputemattkw80 has a reputation beyond reputemattkw80 has a reputation beyond reputemattkw80 has a reputation beyond reputemattkw80 has a reputation beyond repute
Break-in tubes ?
Do Tubes' need to be "broke-in" ?
I thought I read some where that tubes need to run for about 100 hours before they're running their best.
(Not 100 hours straight, but 100 hours OF USE)
Old 12-21-2007
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
There's a lot of back-and-forth on that... Me? I run a piece for several days (constant-on) after new tubes are installed.
One of several reasons that I try my best to avoid tubes wherever possible... I'm not "anti-tube" by any stretch - But if I can get what I'm looking for without them, I'm a slightly happier dude.
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
Old 12-21-2007
cusebassman's Avatar
cusebassman cusebassman is offline
Freakin' sweet
cusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond repute
It certainly decreases startup time, and is a pain when you want to put up a tube mic that you would normally let "warm up" for a good 30 minutes - 1 hour.
It may have been due simply to the fact that I have heard this before, but when I bought my Rode K2, I swapped the tube out for a NOS Telefunken tube that, as far as tubedepot said, had never been used. When I turned the mic on and let it sit for an hour, it still had a rather sizzly top-end, but after leaving it on for a day or two (I believe it was 2), that sizzle went away.
I don't know if its my brain trying to justify the added cost of the nicer 6922 or what, but it did seem to make a difference letting it "burn-in" a bit. Again, this comes with the stipulation that it might just be my imagination
Originally Posted by Ford Van
I AM RIGHT
Old 12-21-2007
Newbie 4 EVA
Thanks for the response guys.
I think I'll let this stuff run a few days, just in case.
Old 12-21-2007
dementedchord dementedchord is offline
Psychotic State alumni ch
dementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond repute
a techs perspective... no real advantage to burn in.... and why does it matter??? you start to use it it's "burning in"... but it aint a bad idea to warm up a piece for 1/2 hr before useing to let the temp kinda stabilize...
37.8% of all statistics are made up on the spot...
hey give a guy some room... people are trying to evolve here... for crying out loud...
FS: Tubes! andycerrone Free Ads for Music / Recording Equipment 8 12-21-2006 04:45
New Tubes jimballs Guitars and Basses 4 11-29-2006 15:12
Groove Tubes SUBSTI-TUBE 928-PR GONZO-X Guitars and Basses 8 11-15-2006 15:08
Blue glow in tubes... uh-oh? timthetortoise Guitars and Basses 8 11-14-2006 14:22
Tubes, tubes, tubes! Should I swap the tubes in my TSL601? Whoopysnorp Guitars and Basses 16 11-21-2004 18:23
