Old 12-16-2007
neomnj neomnj is offline
Registered User
neomnj is on a distinguished road
acousitc guitar recording room
Hello,
My name is vinny, and im new to all recording. i do alot of music with my accoustic guitar and all is done in 1 take with my voice and guitar. i have 2 closets in my room. 1 of them is in the corner of the room. i wass going to extend it but then i decided im going to make it a small recording room. its going to be a 6'x6' booth. my main question is does size really matter? as well as what kind of door or entrance can i make. i figured i can use 3/4" mdf for walls so im not having to make any permanent modifications to my house. im simply looking for some guidance in the right direction for what id like to do. if im completely wrong please let me know.
thanks for any help in advanced
-vinny
Old 12-17-2007
tmix tmix is offline
1K Silver Member
tmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond repute
Vinny,
If all you are going to do is record voice and acoustic, I would not worry too much about building up mass to sound proof your room. It is probably sound proofed enough as it is. However, what you will want a room that has been acoustically treated to sound good to your mics.
Doing that in a small space like a 6 x 6 closet basically means deadening it completly because the room is too small to use its own sonic signature of size, it will sound small and boxy.
However if you create the closet to be dead and then stick your noisey equipment in there and then treat and record in the main room I think you will be happier because it will also give you a room worthy of mixing in.
Tom Menikos
T-Mix Studios
Mansfield Texas
WWW.tmixstudio.com
Old 12-17-2007
Registered User
my room is to loud, im a computer tech and the only room i can do it in has about 8 computers running all the time so it hard to get a good recording, give me a size that would be better? i can probly cut the room in half by adding a wall to it and using the computer side to mix i also have a basement but its totally unfinished and i cant really afford to have it all finished right now. i can look into doing a section of it for a small recording room i have a drum set down there too that i use but i really dont use them in my music often.
Old 12-18-2007
gullfo's Avatar
gullfo gullfo is offline
Dedicated Member
gullfo has a reputation beyond reputegullfo has a reputation beyond reputegullfo has a reputation beyond reputegullfo has a reputation beyond reputegullfo has a reputation beyond reputegullfo has a reputation beyond reputegullfo has a reputation beyond reputegullfo has a reputation beyond reputegullfo has a reputation beyond reputegullfo has a reputation beyond reputegullfo has a reputation beyond repute
why not build an enclosure for the computers? depending on the size, you may be able to fit them in a standard 19" rack on their sides. just build (buy?) the enclosure with fans inside to draw off the heat and keep the noise to a minimum. on the wall nearest the fan output, put an absorber panel to cut any reflected fan noise. this should reduce the noise in the room significantly and make the bigger room suitable for recording.
here's an isocabinet i use for my dell 4400 pc (on side) and 2 adats.
Glenn
fossile music
Old 12-18-2007
Registered User
i did that to them already, most of them have to stay out because im constantly either working on them or moving them around, its my work room so when i have a clients computer (or multiple computers) its just easier to keep it out.
Old 12-19-2007
gullfo's Avatar
Dedicated Member
i guess it boils down to choices... you want a work room for noisy computers, or you want a recording studio for acoustic instruments... unless you isolate one or the other, it doesn't seem compatible... a small room for acoustic instruments will sound bad.
Glenn
fossile music
Would a PCM91 or similar transform my music hemmick reef The Rack 9 01-27-2007 08:25
Please Help Noob (me) Switch from Plug-in Reverb to Hardware undermind The Rack 24 01-19-2007 10:20
Tips on recording semi-acousic guitar Steal Sessions Recording Techniques 5 01-14-2005 02:34
The size of the room you are recording in... photoresistor Recording Techniques 6 03-03-2004 07:31
Live Mixing Problems... MiXit-G Mixing / Mastering 11 04-07-2003 05:17
