Battery
I've always used the factory drum sounds in Reason. and am really tired of them. I got a neptunes drum kit a while back, it had some decent sounds, but some of them I recognized directly from reason. so It wasn't a very legit kit. I also started using vynil breaks recently, and am going to continue to mess with it, but...
Has anyone here used Battery by native instruments? What did you think of it? can you run the sounds into other drum machines, software and hardware? (like, plug them into the reason drum machine). does it have rewire? any info will help. thanks.
"And Mr Ethos, to be technical, what do you really know about hip hop?" -crunkthanamug |
Battery has a large library wavs with kits made in battery format. but you can use the samples in any program that can load wav files. No rewire tho, you can use it as a plug in or stand alone. This Battery 2 i'm speaking of, i'm not up on battery 3 yet.
If your only using Reason and no other sequencer that hosts plug-ins, you're better off buying a couple nice commercial kits.
HDHM - http://www.myspace.com/kbdagrownup The Temperature Of Success Is Cold As Ice |
im running pro tools LE, also. so I could use it as a plug there?
thanks for the reply. 'preciate it.
Battery can be used as standalone or a plug in. U can use it in reaper, cubase, protools, ect... pretty much any software that supporst VST's. I use to use batter and reason 3.0 together. I ran it all from Reaper. Nicole
For Incredible Prices on Music Gear-CLICK HERE! www.myspace.com/missdjcoleycole www.soundclick.com/ccproductionsmissdjcoleycole Tool Box: (Production) Akai MPC2000 Casio CTK-451(midi controller) Reason 3.0 Reaper Records/Ton of samples |
Yes, rtas version comes with it
awesome. thank folks.
Peace... spin |
| Help!!! Replace Shure Prologue battery??? | mayim | Microphones | 1 | 03-20-2009 20:36 |
| ensoniq sq-1 how do i change this battery | rokinrandy | Keyboards and Sound Modules | 13 | 12-02-2006 14:19 |
| HR16 and SR16 battery trivia | soundchaser59 | Alesis Forum | 6 | 03-13-2006 09:47 |
| Pops and Clicks using Battery with SX | trogdor | Cubase User Forum | 0 | 05-14-2003 13:44 |
| Sonar -> Battery -> Drumkit From Hell -> advice needed | tubedude | Cakewalk / Sonar Forum | 3 | 02-25-2003 13:22 |
