Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 12-11-2007
vVShellShockVv vVShellShockVv is offline
Junior Member
vVShellShockVv has a reputation beyond reputevVShellShockVv has a reputation beyond reputevVShellShockVv has a reputation beyond reputevVShellShockVv has a reputation beyond reputevVShellShockVv has a reputation beyond reputevVShellShockVv has a reputation beyond reputevVShellShockVv has a reputation beyond reputevVShellShockVv has a reputation beyond reputevVShellShockVv has a reputation beyond reputevVShellShockVv has a reputation beyond reputevVShellShockVv has a reputation beyond repute
Question please help, I Have No Sound From My Monitors..
I just bought the m-audio fast track pro and I connected my monitors to is cause Im trying to listen to my music from my yahmaha hs50m monitors but I do not recieve any sound out the monitors..but I do get sound from my built in laptop speakers...can anyone tell me what I may be doing wrong and how I can fix it??
thanks for the time...
Old 12-11-2007
Phuturistic Phuturistic is offline
Junior Member
Phuturistic has a reputation beyond reputePhuturistic has a reputation beyond reputePhuturistic has a reputation beyond reputePhuturistic has a reputation beyond reputePhuturistic has a reputation beyond reputePhuturistic has a reputation beyond reputePhuturistic has a reputation beyond reputePhuturistic has a reputation beyond reputePhuturistic has a reputation beyond reputePhuturistic has a reputation beyond reputePhuturistic has a reputation beyond repute
Did you make sure the monitors were turned on? Sometimes when I'm looking for my glasses I forget that their on my face.
Old 12-11-2007
Junior Member
yes they are turned on and yes i have the volume up and yes the fast track is also turned on..
Old 12-12-2007
oDD's Avatar
oDD oDD is offline
Problem to your solution
oDD has a reputation beyond reputeoDD has a reputation beyond reputeoDD has a reputation beyond reputeoDD has a reputation beyond reputeoDD has a reputation beyond reputeoDD has a reputation beyond reputeoDD has a reputation beyond reputeoDD has a reputation beyond reputeoDD has a reputation beyond reputeoDD has a reputation beyond reputeoDD has a reputation beyond repute
Do the monitors have built in amplification? Or do you need to connect them to an amp?
Old 12-12-2007
altitude909's Avatar
altitude909 altitude909 is offline
Best Advice Ever: RTFM
altitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond repute
Your sounds are routed through the wrong sound interface.
Open your control panel, select sounds/multimedia, select the audio tab, select the fasttrack as the prefered audio playback device.
"Default is the value selected by the composer overridden by your command." - Roland TR-707 Manual
Old 12-12-2007
RAMI's Avatar
RAMI RAMI is offline
www.ramirami.com
RAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond repute
Conider yourself licky.
There's some horrible crap coming out of mine.
Confused about calibrating and placing monitors aznwonderboy Newbies 3 01-27-2007 00:09
Stupid Reverb Questions NL5 Mixing / Mastering 23 03-11-2005 15:15
Surround Sound Monitors Low Country The Rack 12 04-11-2003 20:44
Live Mixing Problems... MiXit-G Mixing / Mastering 11 04-07-2003 05:17
How to go from Delta 1010 to Monitors for best sound quality? Jedman Mixing / Mastering 22 03-10-2003 01:38
