Old 12-11-2007
mikeon mikeon is offline
Newbie
mikeon is on a distinguished road
Mixer Insert-Direct out question...
I was reading around the net and found out that the insert point can be used as a direct out, to send individual channel output to the sound card, but the mixer I'm planning to buy, the Yamaha MG 10/2c has only 2 insert points so ill be able to send only 2 individual output tracks, is that true ? Is there any way I can send 4 individual tracks which my delta 44 supports with this same model? Or should I spring for a higher model... Please let me know...
Old 12-11-2007
cusebassman's Avatar
cusebassman cusebassman is offline
Freakin' sweet
cusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond repute
Well, you might be able to do the following with some mild control trickery and wiring...
Send the signal from channels 1 & 2' insert jacks, respectively, to inputs 1 & 2 on the Delta. Then, turn down their master volume knobs (big white ones at the bottom) - as far as I know, you will still get the signal out the insert jack (since it *should* be way before its channel fader). Then, for tracks 3 and 4, pan them hard left & right, and use the L&R main outs of the board to go to Delta channels 3 & 4.
That's about the best I can suggest, as it appears your auxiliary bus is a single mono channel.
Originally Posted by Ford Van
I AM RIGHT
Old 12-11-2007
Newbie
Oh so that would do the trick eh ? I was thinkin of maybe going for a higher spec MG 12/4 which has 4 inserts and ALT 3/4 but i'm on a budget and if this works 100 % then...
Old 12-11-2007
Elton Bear Elton Bear is offline
Unregistered Abuser
Elton Bear has a reputation beyond reputeElton Bear has a reputation beyond reputeElton Bear has a reputation beyond reputeElton Bear has a reputation beyond reputeElton Bear has a reputation beyond reputeElton Bear has a reputation beyond reputeElton Bear has a reputation beyond reputeElton Bear has a reputation beyond reputeElton Bear has a reputation beyond reputeElton Bear has a reputation beyond reputeElton Bear has a reputation beyond repute
Yeah it'll work. I do the same with my Behringer Eurorack desk atm.
The faders are just used for monitoring (I don't record the main outputs), all the signal is PF, controlled with gain.
Kicking it lo-fi:
POS computer
Cubase SX2
M-Audio Delta 1010LT
ART Studio V3 Tube MP
Behringer Eurorack Desk
AKG C3000B
Shure SM58
Shure SM57
Sennheiser e818 S II
Ashton DMP-100 drum mics
Direct out from mixer insert to record willthethrill The Rack 11 03-20-2009 22:51
Direct out from Mixer Insert to Recording Interface willthethrill The Rack 0 03-25-2006 21:23
question about tascam m312b mixer puttinitonwax Analog Only 15 02-26-2006 10:51
Thinking of buying a mixer, one question. blazingstrings Mixing / Mastering 3 01-28-2006 01:26
smaller mixer with 4 or more direct outs? sk8ingsnowman Other Equipment and Reviews 8 04-25-2003 14:31
