Go Back   Home Recording > Equipment Forums > Drums and Percussion
Reply    Audiofanzine Drum Drum News Drum Medias Drum Tests Drum Articles Drum User Reviews Drum Classifieds Ads
Old 12-10-2007
Highsteel's Avatar
Highsteel Highsteel is offline
Newbie
Highsteel is on a distinguished road
I need a quick opinion on a Roland TD20S-BK - V-Pro TD20 Kit
I have to decide whether to but this Roland TD20S-BK - V-Pro TD20 Kit at way less than retail and just need to know they're a good kit as its way more than I was planning on spending.
Also are they good to record with.
Highsteel
Old 12-10-2007
BentRabbit's Avatar
BentRabbit BentRabbit is offline
Drumb & Drumber
BentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond repute
See answer in your other thread
If you don't hear what the mix is telling you, you shouldn't be working on it in the first place. - John Scrip, Massive Mastering
Myspace Page
Old 12-13-2007
Scotty_C Scotty_C is offline
Newbie
Scotty_C has a reputation beyond reputeScotty_C has a reputation beyond reputeScotty_C has a reputation beyond reputeScotty_C has a reputation beyond reputeScotty_C has a reputation beyond reputeScotty_C has a reputation beyond reputeScotty_C has a reputation beyond reputeScotty_C has a reputation beyond reputeScotty_C has a reputation beyond reputeScotty_C has a reputation beyond reputeScotty_C has a reputation beyond repute
Td-20
Hi,
I don't know if it's still this, but I got a TD-20 about 3 years ago, and at the time it was the best that Roland offered. The samples in it are all very very good, they sound natural, and can be adjusted or tweaked all over the place...F'rinstance, let's say you like the brass 12" tom, but you'd like it have more presence and resonance, and also like it to be deeper. Well, you hit the trigger you have it set on, the punch the instrument button. You then change the size of the tom to something larger. You can also increase the shell depth, then you go to effects and change the room to the largest possible room. You can then go to the effects and chain up some reverb and compression, etc., etc. and etc.
The TD-20 brain has more controls on it than a japanese VCR, and it has a great sound on recordings.
The V-drum pads are good, I tend to wear out bass-drum pads on it, and wish maybe I'd bought a regular "rubber" type pad for my bass drum, but apart from that, I am pretty satisfied with it.
One thing you will find: if you are a little sloppy with your technique, this thing will force you to clean up. Otherwise it's smart and sensitive enough to catch and capture every little snafu.
I'd definitely buy the TD-20 brain again. It gives a dimension to my recording work that I'd never have working with just an acoustic set alone, and I haven't even scratched the surface of all the programming that can be done with it.
So, How Bad Do We Suck? crawdad MP3 Mixing Clinic 146 06-04-2003 14:42
Mail Order vs. Pro Store Experience littledog Other Equipment and Reviews 32 07-11-2002 16:59
AT pro 25 or shure drum mic kit? Project illicit Microphones 9 06-04-2002 15:17
Pro Tools (888 Interface, SSD, VSD) and the MOTU 2408mkII pisces7378 Digital Recording & Computers 2 04-01-2002 04:01
sound card which one is the best lets cut through the hype darrin_h2000 Digital Recording & Computers 54 05-06-2001 01:49
