How To Make This Sound
Hey guys,
I was wondering what I would need to do with my keyboard to make this kind of noise. The sample is at http://yamaha.com/yamahavgn/CDA/Cont...05100,00.html# Click on the "Media Clips" link under the featured keyboard and listen to "7 Synth Zone" Notice how the notes tend to gradually change pitch like a "slur" instead of a regular note with attack. How do I do this?? Would I need a specific type of keyboard?? Thanks a ton. |
like that groove
sounds like a pitch change from the joystick controller itd be pretty easy to record the midi notes in a piano roll view in your sequencer and tweak out the pitch bend to a similar sound dont they give you the midi information for those songs along with your keyboard? demo songs |
I think it's a voice/soundfont but I don't have it on my keys. ://
Sure, you have it. The pitch bend wheel needs to be set to +12.Play the note then move the wheel up. There is probably a utility button, hit that then look for pitch bend and raise the number to 12.
myspace |
Guys, this is called portamento. It's found on most synths and keyboard. It determines the amount of slide from one note to the next (the portamento knob usually lets you control the speed at which this happens). Depending on your synth, it might only happen when you play one note while you haven't released the previous note yet, or from any note to the next. This is sometimes also called "glide".
This keyboard doesnt have portamento. it is a programmed pitch bend. It SHOULD be a portamento and that would be the preferred way to get the sound, but I'm pretty sure this keyboard cant do it.
My mm6 doesnt have portamento either, and it is truly baffling as to why they left it out, but they did. The only way he will get this sound is by using the pitch bend and setting it to an octave.
myspace |
Ohh, is there any way at all to add portamento on my keys??
Maybe a soundcard or anything?? ![]() EDIT: Also, the YPT 400 isn't my keyboard. My keyboard is the YPT300. And I'm pretty sure there's a way to add portamento, I'm just not sure how. I read the online manual for my model and there is something about MIDI coding for Portamento. http://yamaha.com/yamahavgn/Documents/psre303_en.pdf Page 77 Last edited by alovetodiefor; 12-15-2007 at 09:39.. |
myspace |
Alright, I have a UX16 so yeah.
The key is figuring it out.
Hmmm, I just looked at the mm6 implementation, and amazingly portamento is not listed Anyhoo, if you use a program like Sonar, you can add midi envelopes to externally control things like sustain and portamento.
myspace |
Well, I own Cubase.
Do I need to hook up my keyboard to my computer every time I want to use portamento?? |
| Mixing secrets by sonusman | s_o_n_u_s_m_a_n | Mixing / Mastering | 261 | 05-14-2009 19:26 |
| Would a PCM91 or similar transform my music | hemmick reef | The Rack | 9 | 01-27-2007 08:25 |
| To make your old stereo speakers more suitable for monitoring. | Boray | Roland, Boss, VS Series Forum | 33 | 01-21-2003 03:26 |
| 10 hours of studio time... | marcccc | Recording Techniques | 15 | 06-03-2001 10:18 |
