RNP Burn In Time?
I just bought a new RNP ****adeptly dodges flames**** and was wondering thoughts on burn-in times. The manufacturer recs 5 minutes but I read somewhere that a burn in of 24 hours produced even better sound. Anybody out there with an RNP and thoughts on the matter of burn-in? Mine is plugged in now but I was going to try it out yet today.
![]() Besides, by the time you get done mullin' this one over...
Monitoring at CathouseSound AetherAudio 'Continuum A.D. and TimePiece 'Mini (formerly S.P. Technology |
Agreed. It's been on with two condensers hooked up (Phantom) just over an hour now. I am going to start tracking right after lunch.
Not sure why you would need to "burn in" an RNP. Tubes need a bit to warm up, but there ain't none in an RNP.
They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. -B.F. |
Burn-in in the testing sense should already have been carried out by the manufacturer.
As for improving the sound of the thing by leaving it on for a while? Make a recording having just switched it on. Then make another having had it on for an hour or so. Notice any difference? Nah, didn't think so. ![]() I use a valve pre and the valves get hot in the time it takes me to plug a mic into it. I don't go for this "burn in" nonsense, even for valve gear.
"Just give the great unwashed a pair of oversized breasts and a happy ending, and they'll 'oink' for more every time." C. M. Burns http://www.shuttleworths.co.uk/micloop.gif |
I suggest pre-heating the oven at 375 degrees for about 10 mins... then slow cook for about an hour... use a meat thermometer for more accuracy
It's not just the signal chain... It's the hands that touch it |
But it’s worth noting that you’d moved to another room. We all know how different the same mic can sound in different rooms.
+1 --I caught that too.
Though I have heard some pretty convincing aurguments for a warm-up period for some classic tube mics, makes sense...
#12
it will definitely sound better after burning. joints take longer than bongs.
#13
Just remember that excessive burn in periods lead to even longer burn out periods.
#14
I think it's been covered but burn-in time is usually done to weed out the infant mortality before shipping. This is done during the post assembly/pre-packaging stage. To put burn-in on the customer's lap would simply be a bad idea.
Some components may continue to wear due to heat but that's not going to happen in a few minutes or even a few days. If the thing is made with close tolerance and high-quaility parts, I'd be you don't hear a difference for years. If there were things like crystal oscillators and tubes, then I'd buy into it just a bit.
She's not the boss of me
#15
#16
There's a *lot* of talk out there about speaker burn in, though....
I don't need no stinkin' sig. |
#17
There's a lot of talk about cable burn in too. There's even a company that takes your cables and plugs them into a special machine which speeds up the burning in process.
And they charge money for it. I'm not even joking. God I wish I was. ![]()
#18
Huh. Would that still be 'work'..? taking peoples money to.. ![]()
#19
other than temperature stabilization I don't get the burn in of a solid state device?
usually military grade devices can perform in a wide range of conditions, which we consider high quality generally. cheaper less "quality" maybe able to withstand 400hrs in the artic levels, or in the Sahara desert heat... but most don't need that kind of quality for something that sits in a home. in mfg. a "burn-in" can be a wide range of tests, or stress type tests to quantify a specification or lack of....or in R&D to create a spec. cpu's build up heat the more they are taxed with actions..... the electrons running into each other create friction, heat.... maybe someone with component specific knowledge would explain the burn-in of the RNP? have you tried singing really, really fast to see if the fuse blows? ![]()
if it's not happening in the room, it ain't gonna happen on tape.-HG |
#20
The more expensive the new gear, the longer burn-in is required. Figure about 10 hours of burn-in for every doubling of price. So- if you replace a $10 cable with a $100 cable, that's three doublings, so you'd need 30 hours of burn-in time. ![]() |
#21
Are we supposed to feel "burnt" afterwards?
![]() burn-in.... like my a-hole burns after buying $$$$ Monster cables...ahahahaaa nevermind anything I post....thats my best advice.
#22
Yes it states temperature stabilization and some comment about hi-current. I didn't read anything other than getting the electronics to become stable and some led's turn on and off. Manual does insinuate it's better warm. too bad this thing wasn't the same price as the RNC... i wonder if its as good as the RNC is?
#23
The only piece of audio gear I can think of that might benefit from a "burn-in" might be a new set of speakers. How do you like the RNP? Was it worth the upgrade from whatever you were using before? |
#24
I'm giving you rep points for that. |
#25
This is more of warm up than a burn in.(isn't it?) Lot of studio gear works better after it warms up. This is just saying to turn it on 5 Min before you lay anything down. I've never really started laying down tracks in less than 12 min anyway, after finding the sweet spot for the mic and a couple of run troughs
before a take you should be good to ![]() |
| Time is Money....Play the odds! | Dom Franco | Songwriting, Singing & Vocals | 20 | 03-04-2008 18:02 |
| How much time???? | mikeh | Songwriting, Singing & Vocals | 6 | 09-19-2007 00:39 |
| Compression Help? | emergencyexit | Mixing / Mastering | 12 | 10-15-2005 09:44 |
| RNP ....release update? | bostonfan2 | The Rack | 27 | 09-23-2002 15:16 |
| CD-R Burn Time | Big Uigi 23 | Newbies | 3 | 01-05-2000 08:56 |
