Go Back   Home Recording > Equipment Forums > Microphones
Reply    Audiofanzine Microphone Microphone News Microphone Medias Microphone Tests Microphone Articles Microphone User Reviews Microphone Classifieds Ads
Old 12-02-2007
guitar junkie's Avatar
guitar junkie guitar junkie is offline
Guitar User.
guitar junkie has a reputation beyond reputeguitar junkie has a reputation beyond reputeguitar junkie has a reputation beyond reputeguitar junkie has a reputation beyond reputeguitar junkie has a reputation beyond reputeguitar junkie has a reputation beyond reputeguitar junkie has a reputation beyond reputeguitar junkie has a reputation beyond reputeguitar junkie has a reputation beyond reputeguitar junkie has a reputation beyond reputeguitar junkie has a reputation beyond repute
tube info for a MXL960
Ok so I shelled out some money for the MXL 960 and it should be here early next week, can't wait!
I know some people are taking them apart and putting a new tube in them, anybody got a link to a good tube to drop in one, that doesn't cost a whole lot of cash?
And a link to some how to tips on changing the tube out?
Never done anything like this before so help a newbi out
My various rants about digital audio and Indie music: At my blog
Old 12-02-2007
dgatwood's Avatar
dgatwood dgatwood is offline
is out. Leave a message.
dgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond repute
The NOS GE 5-star black plate triple mica (or JAN version) 5965 or 6072 (I forget which) are frequently recommended.
You might also look into tubes by Sovtek. That's the stock tube in the AT4060.
Ei has some Telefunken knockoffs that might be good for preamps. Not sure how they'd do in mics. The new Tung Sol tubes also get good reviews---again not sure how they'd do in mics.
Sent from my iPhone.
Originally Posted by Obi-Wan
If you mod me down, I will only grow stronger.
Old 12-02-2007
pylet2000 pylet2000 is offline
Junior Member
pylet2000 has a reputation beyond reputepylet2000 has a reputation beyond reputepylet2000 has a reputation beyond reputepylet2000 has a reputation beyond reputepylet2000 has a reputation beyond reputepylet2000 has a reputation beyond reputepylet2000 has a reputation beyond reputepylet2000 has a reputation beyond reputepylet2000 has a reputation beyond reputepylet2000 has a reputation beyond reputepylet2000 has a reputation beyond repute
http://www.tubedepot.com/nos-12at7-mullard.html
This store has always been good to me, and the price for a NOS Mullard is great. I'm using a NOS 12AT7 in my 960 right now, and the results are really quite good! A true 12AY7 would be better, but they are pricier tubes and the 12AT7 will work out pretty well. A little more gain and the impedance is different, but certainly better than the ultra high gain Chinese 12AX7 (even though they claim 12AT7) in there right now...
As for changing the tube, it couldn't be easier. Simply unscrew the whole bottom of the mic, slide the metal case down, and you'll see the tube right there. I unscrewed one of the rubber retainer screws to make life a little easier, then gently took the old tube out and plugged the new one in it's place. Simple! Put it back together and enjoy, it's a nice sounding mic.
Old 12-02-2007
Guitar User.
looks interesting!
I read where Harvey thinks they do fine as stock, so I will try that before spending MORE money on this mic.
Old 12-03-2007
Gus Gus is offline
Junior Member
Gus has a reputation beyond reputeGus has a reputation beyond reputeGus has a reputation beyond reputeGus has a reputation beyond reputeGus has a reputation beyond reputeGus has a reputation beyond reputeGus has a reputation beyond reputeGus has a reputation beyond reputeGus has a reputation beyond reputeGus has a reputation beyond reputeGus has a reputation beyond repute
I have not been inside a 960 but I have two v69ms.
The tube type does not matter that much with the v69m circuit because of the way it is designed. I traced a bit of the circuit and it has two 1/2s of a dual triode wired in parallel. It is setup as a gain stage :HOWEVER there is a feedback cap from plate to grid about the same value as the capsule cap making it to be a close to gain of -1 amp if I trace it right. The PCB has a fet and two transistors and a module. I did not trace anymore of the circuit
Tube noise and microphonics will be important.
Old 12-03-2007
kidvybes's Avatar
kidvybes kidvybes is offline
1K Silver Member
kidvybes has a reputation beyond reputekidvybes has a reputation beyond reputekidvybes has a reputation beyond reputekidvybes has a reputation beyond reputekidvybes has a reputation beyond reputekidvybes has a reputation beyond reputekidvybes has a reputation beyond reputekidvybes has a reputation beyond reputekidvybes has a reputation beyond reputekidvybes has a reputation beyond reputekidvybes has a reputation beyond repute
...frankly, I've been upgrading the stock tubes in my tube mics for quite some time...in the case of the 960 (or most of the Chinese tube mics) the clearly superior choice is the GE 6072 or 6072A (a 12AY7 variant)...Electro Harmonix does make a version that's still better than the stock tubes, but for a few dollars more you should still be able to find a GE version...
...the stock tubes are Chinese 12AX7 or 12AT7 versions...those, along with their Russian counterparts (Sovtek) actually test out well for microphonics, but don't exhibit the same audiophonic characteristics of the vintage NOS GE 6072 tubes...
...check eBay for "6072 tube", "6072A tube" or "JAN 6072" (military issued) and then look for GE versions (the 5-Star Triple-Mica is the "holy grail" of 6072 variations)...you should notice a bit more bottom and a cleaner top-end once the tube is swapped, although the 960 is voiced with a smoother top-end then the V69, so the difference is not as noticeable...
...the swap is easy since the mic has a socket mount for the tube...it is advised to clean the pins of any NOS tube with contact cleaner (and dry thoroughly) before mounting the new tube...contact cleaner is available at Radio Shack...
reggae souljah
Old 12-04-2007
Guitar User.
well word has it that my mic is already in town, and should be here sometime tomorrow!
Old 12-05-2007
Guitar User.
it came today a little after 1:30 in the afternoon....
I let it warm up a while, let the tube cook, until the mic kind of felt warm to the touch, and let fly with some vocals.... Mid range is more defined than anything I had before this, highs are as smooth as Harvey said they were, lows are very clean, without being very boomy.... at least in my room!
I can't wait to change over to the new studio and see how it sounds when I get everything patched in, early next week.
Two Tube Pedal DIY Projects mshilarious Guitars and Basses 23 01-26-2006 20:17
preamp comparison Peetr3 The Rack 62 12-28-2005 17:01
The General opinion on the Apex460 tube condenser mic? Luc the Tinkerer Microphones 6 09-28-2005 00:07
FS: Rode NT1000, MXL 960 Tube Mic and more!... kidvybes Free Ads for Music / Recording Equipment 7 07-10-2005 08:05
samples?: tube vs. no tube tomleblanc Microphones 2 04-26-2003 06:30
