Go Back   Home Recording > Equipment Forums > Microphones
Reply    Audiofanzine Microphone Microphone News Microphone Medias Microphone Tests Microphone Articles Microphone User Reviews Microphone Classifieds Ads
Old 12-02-2007
Langsuyar Langsuyar is offline
Registered User
Langsuyar is on a distinguished road
Buying suggestions for camcorder preamp/microphone
I'm hoping for some purchasing advice. I need to buy a small, easily portable microphone preamp that I can carry around with my camcorder, a Canon HV20. Ideally the preamp provides its own power and has 1/4 jacks (or smaller) for input and output. My camera only accepts a 2.5mm jack for audio input in the first place, and the (cheap) microphones I own use those jacks as well (though I'm not opposed to buying a new mic with 3-pin if necessary).
Any suggestions? This is for recording interview audio in the field, so size, weight and ease of use are very important to me. Shouldn't be too expensive, either - I don't need perfect audio, just a good, loud feed.
Old 12-02-2007
kojdogg's Avatar
kojdogg kojdogg is offline
bollocks redux!
kojdogg has a reputation beyond reputekojdogg has a reputation beyond reputekojdogg has a reputation beyond reputekojdogg has a reputation beyond reputekojdogg has a reputation beyond reputekojdogg has a reputation beyond reputekojdogg has a reputation beyond reputekojdogg has a reputation beyond reputekojdogg has a reputation beyond reputekojdogg has a reputation beyond reputekojdogg has a reputation beyond repute
i'd check out naiant msh microphones- www.naiant.com
they sound great and are very inexpensive. depending on the specs of your camcorder you might be able to run one of them from your camcorder's built-in preamp. you could contact jon there and he could tell you if it will work for you.
SPACE AVAILABLE FOR RENT
Old 12-02-2007
Registered User
Thanks for the suggestion. I'll check out the microphones, but I don't think the camcorder preamp will be good enough. Tried it before (with a cheap dynamic microphone, granted) and didn't get a decent signal - way quiet. I think I'll need an external preamp.
Drum mp3 suggestions astoebe MP3 Mixing Clinic 4 01-21-2006 20:53
What to watch out for while buying tape decks? tourettes5139 Other Equipment and Reviews 2 12-11-2005 20:49
I need help with buying a new Preamp, any other suggestions??? MPLSallstar The Rack 31 09-21-2005 09:38
Any suggestions on buying an effects processor? SappyHad The Rack 21 03-21-2005 23:36
Under $150 Bass Comb Amp...any suggestions? mshea Guitars and Basses 0 11-27-2001 23:50
