Delay problems
Hey guys. I'm having a delay problem when I try to record a track on Sonar 2.2. Whenever I dont have the track armed to record, I have a solid signal through my sound card (an audigy yes, but I'm currently in the market for a firewire unit.) Is there somewhere in Sonar that I can go to fix this problem? When I strike a chord on my guitar i get the initial signal, plus an echo, even though I dont have any delays set.
"Your sound is in your hands as much as anything. It's the way you pick, and the way you hold the guitar, more than it is the amp or the guitar you use."--Stevie Ray Vaughn |
Try muting the original signal in the audigy mixer to eliminate the annoying double sound, then you'll have to go to Options->Audio and play around with the latency slider.
1. Don't expect much from Audigy if your monitoring with plug-ins (if not, turn monitoring off and just use Audigy mixer to monitor). 2. Choppy sound means you went to low with the slider. 3. If you mess things up and can't get it working again, use the wave profiler button, I think it lives right there with the slider, not sure. |
thanks man, that fixed the problem!
| Delay spillover | jools230575 | The Rack | 0 | 07-09-2005 17:09 |
| Live Mixing Problems... | MiXit-G | Mixing / Mastering | 11 | 04-07-2003 05:17 |
| digital delay problems. | martin | Newbies | 1 | 08-04-1999 00:52 |
| large delay is causing sync problems | busboy | Cubase User Forum | 6 | 06-30-1999 11:01 |
