Old 11-27-2007
Albertm's Avatar
Albertm Albertm is offline
Dedicated Member
Albertm has a reputation beyond reputeAlbertm has a reputation beyond reputeAlbertm has a reputation beyond reputeAlbertm has a reputation beyond reputeAlbertm has a reputation beyond reputeAlbertm has a reputation beyond reputeAlbertm has a reputation beyond reputeAlbertm has a reputation beyond reputeAlbertm has a reputation beyond reputeAlbertm has a reputation beyond reputeAlbertm has a reputation beyond repute
crackling
I have a constant crackling sound when recording only. When in playback its not there. Any ideas at all. thanks
Sonar 5 PE
Tascam 1082
AT3035
Old 11-27-2007
mikemorgan's Avatar
mikemorgan mikemorgan is offline
panned out
mikemorgan has a reputation beyond reputemikemorgan has a reputation beyond reputemikemorgan has a reputation beyond reputemikemorgan has a reputation beyond reputemikemorgan has a reputation beyond reputemikemorgan has a reputation beyond reputemikemorgan has a reputation beyond reputemikemorgan has a reputation beyond reputemikemorgan has a reputation beyond reputemikemorgan has a reputation beyond reputemikemorgan has a reputation beyond repute
Drivers, sample rates, IRQ's, latency slider, ram.
All these can affect soundcard performance which is definately the problem.
What hardware and software are you using?
"Who's that singing? That can't be me, I don't sound like that."
Old 11-27-2007
Albertm's Avatar
Dedicated Member
Tascam 1082
Sonar 5
1 gig ram
Sonar setting -Sample rte 44100
buffer size 92.9 play back que 2bit - drive 16 bits
i/o buffer size 2048
wdm driver
Does this help narrow it down?
Sonar 5 PE
Tascam 1082
AT3035
Old 11-27-2007
mikemorgan's Avatar
panned out
Do you have an Asio driver available for that 1082 ? If so, use that option.
Did Sonar set the 2048 sample rate during hardware acquisition or is that a recommended sample rate by Tascam? Try halving it.
The 1082 is firewire, yes? Some people get better firewire results using Texas Instruments based chipsets on pci firewire cards rather than relying on the MB firewire hardware.
Is this a new problem, or has it never worked correctly?
Old 11-27-2007
Albertm's Avatar
Dedicated Member
Thats the strange thing. I've been using for 2 years with no crackles. But I halved the rate as you said and noticed my tascam was at 64. Went up to 512. No crackles. Just to check I changed everything back and no crackles. So I don't really know why they came and went. Tascam is firewire, but was always good. Same with using WDM drivers. I think I tried Asio once and it took me backwards. Is that the way to good in the end?
Anyway, not sure why alls working but glad it is. Thanks Mike for the time. This buffer thing always baffled me. Need a good buffer theory course.
Sonar 5 PE
Tascam 1082
AT3035
Old 11-28-2007
Torpid-x's Avatar
Torpid-x Torpid-x is offline
Tonal Scientist
Location: Experimenting with your deoxyribonucleic acid
Torpid-x has a reputation beyond reputeTorpid-x has a reputation beyond reputeTorpid-x has a reputation beyond reputeTorpid-x has a reputation beyond reputeTorpid-x has a reputation beyond reputeTorpid-x has a reputation beyond reputeTorpid-x has a reputation beyond reputeTorpid-x has a reputation beyond reputeTorpid-x has a reputation beyond reputeTorpid-x has a reputation beyond reputeTorpid-x has a reputation beyond repute
I have similar problems from time to time, usually just opening the audio options dialog and (I use ASIO) clicking the ASIO panel button and closing again fixes it, the slider does not move on my system but moving it probably does the same thing on your system.
Man, Signature's are hard too!!!
anyway, here's a song
Old 12-22-2007
Jammer429's Avatar
Jammer429 Jammer429 is offline
Getting Stuff Done
Jammer429 has a reputation beyond reputeJammer429 has a reputation beyond reputeJammer429 has a reputation beyond reputeJammer429 has a reputation beyond reputeJammer429 has a reputation beyond reputeJammer429 has a reputation beyond reputeJammer429 has a reputation beyond reputeJammer429 has a reputation beyond reputeJammer429 has a reputation beyond reputeJammer429 has a reputation beyond reputeJammer429 has a reputation beyond repute
hey man most likely it is in your buffer adjust it to where it is runnin faster that should the the trick
DVD Audio Crackling with external USB M-Audio Card drathbun Cakewalk / Sonar Forum 1 10-27-2007 12:21
Crackling in the cans using a Carvin H400 Headphone amp tzer The Rack 6 09-08-2007 06:27
problems regarding crackling and loss of signal Melsi Digital Recording & Computers 3 12-17-2006 16:39
Crackling problem please help vanwykw TASCAM User Forum 0 11-28-2004 01:12
Severe crackling during audio playback- help! We Got Da Funk Digital Recording & Computers 2 05-16-2002 17:54
