Getting a new computer -- Please help
Hi Everyone,
I'm finally getting a new DAW...my poor, trusty 5+ year old Dell is just not hacking it. However, hardware is NOT my strength. Could you please check out the template DAW specs "draft" below, and let me know what you think is unnecessary, inadequate, or simply a bad idea? (I'm assuming Vista is not recommended, from everyone's comments elsewhere in the forum.) I generally record solo, one input at a time, miking vocals and acoustic guitar, going DI with electric guitar and bass, and use a Yamaha keyboard to control Reason/MIDI. I ALREADY HAVE: OLD PC: Dell Dimention 8200, Pentium 4 CPU 2.00 GHz, 1.99 GHz, 512 MB RAM Sonar Producer 6 Reason 2.5 M-Audio Delta 1010LT soundcard M-Audio DMP3 preamp M-Audio Studiophile BX5a monitors NEW DAW SPECS: AMD x2 @ 3ghz 2mb L2 [6000+] 4gb high quality low latency 1T DDR2 800 ram 256mb AMD 690G HDMI & VGA output 500gb 16mb cache SATA 3.0 x 2, /raid Clear 7.1 8ch 192Hz onboard sound 20x DVD+/-RW 420w PSU (600w SLI ready optional +$50) 4 SATA, 1 EIDE, 6 USB (4 ear 2 front), 3 PCI, 1 16x PCI-E SLI, Front audio & mic ports Windows Vista Premium included Antivirus, anti-adware, and anti-malware protection installed case details: 10 Drive bays: External Bays 5.25": 4 External Bays 3.5": 2 Internal Bays 3.5": 4 Dimensions (WxDxH): 200 x 450 x 430 mm Cooling Options: (1) 80mm tri-color side auxiliary case fan (Included) (2) 80mm back auxiliary case fan (Included) Windowed side panel 420Watt ATX12V power supply with dual fans 2 Front mounted USB ports What do you think? Replace Vista with XP32? Anything else that can be improved or reduce cost? Thanks for your help -- any advice would be HUGELY appreciated. ![]() -Mike
GarageSpin |
you might see alot better perform out your old cpu with more ram.as far as vista you should be ok with it most m-audio products are vista capable i dont know about the older software but ive got cubasesx3,sonar7,reason4,flstudio running on vista now with no problem.
I agree, more ram with your old cpu would improve the performance. I don't know about the AMD versus Intel chipset though, you'll need to check if there are any compatibility issues. As for Vista, I am using Vista Premium with Sonar 6 and a Focusrite 26IO firewire interface with no issues.
| New Digital Audio Computer Recorder | darnold | Free Ads for Music / Recording Equipment | 7 | 10-23-2005 04:17 |
| Computer Recording Question... | newatthis | Newbies | 1 | 04-23-2005 19:26 |
| Can I use my Korg D8 digital recorder with my computer? | CRISB | Digital Recording & Computers | 1 | 09-24-2001 13:04 |
| Recording Guitar Direct into my Computer | pisces7378 | Newbies | 2 | 12-20-2000 14:55 |
| Recording Guitar Directly into my Computer | pisces7378 | Digital Recording & Computers | 3 | 12-20-2000 13:31 |
