Old 11-23-2007
tc4b's Avatar
tc4b tc4b is offline
boom, BAP! Boom boom BAP
tc4b has a reputation beyond reputetc4b has a reputation beyond reputetc4b has a reputation beyond reputetc4b has a reputation beyond reputetc4b has a reputation beyond reputetc4b has a reputation beyond reputetc4b has a reputation beyond reputetc4b has a reputation beyond reputetc4b has a reputation beyond reputetc4b has a reputation beyond reputetc4b has a reputation beyond repute
who has the most broke-dick monitor stands?
Come on, I blew my budget on drywall and paint and a million other things, I'm tapped and need monitor stands. Who has the most cheap-ass monitor stand solution?
Old 11-23-2007
gullfo's Avatar
gullfo gullfo is offline
Dedicated Member
gullfo has a reputation beyond reputegullfo has a reputation beyond reputegullfo has a reputation beyond reputegullfo has a reputation beyond reputegullfo has a reputation beyond reputegullfo has a reputation beyond reputegullfo has a reputation beyond reputegullfo has a reputation beyond reputegullfo has a reputation beyond reputegullfo has a reputation beyond reputegullfo has a reputation beyond repute
you could stack some cement blocks (12"x12"x2") to the desired height, put a 1/2" layer of heavy carpet foam on top and bottom, and then put your monitors on that. cover the stack with cloth to neaten it up. the block will provide a stable base with low resonance and the compressed foam on the bottom will isolate the stand from the floor, and the top foam - monitor from the block. use spray or contact glue to stick the blocks together - enough so they won't slip easy. you could use just about any block to get the height and mass - its not critical unless you're an audiophile.
Glenn
fossile music
Old 11-23-2007
mshilarious's Avatar
mshilarious mshilarious is offline
Faithful Departed
mshilarious has disabled reputation
4" PVC pipe cemented to shelving, plywood, whatever you got, and a can of spray paint. Maybe some 3M pads on the top & bottom.
Old 11-23-2007
tc4b's Avatar
Nice, I might try that. It also fits in with how much spare time I have for construction!
Old 11-26-2007
Roguetitan's Avatar
Roguetitan Roguetitan is offline
The Poly Grip Kid
Roguetitan has a reputation beyond reputeRoguetitan has a reputation beyond reputeRoguetitan has a reputation beyond reputeRoguetitan has a reputation beyond reputeRoguetitan has a reputation beyond reputeRoguetitan has a reputation beyond reputeRoguetitan has a reputation beyond reputeRoguetitan has a reputation beyond reputeRoguetitan has a reputation beyond reputeRoguetitan has a reputation beyond reputeRoguetitan has a reputation beyond repute
Check this place out I saw some DIY monitor stands there.
Until This Day
Old 04-25-2008
tc4b's Avatar
Just thought I'd post an update. I ended up buying a door for $10 and making it into a desk using some 2x4's I had in the garage. It's not a very deep desk, but it's 7' wide, so no need for stands now.
Old 04-25-2008
NL5's Avatar
NL5 NL5 is offline
Unpossible!
NL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond repute
Dammit - I was gonna show off my $10 set of stands!
They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. -B.F.
Old 04-25-2008
WhiteStrat's Avatar
WhiteStrat WhiteStrat is offline
Go Speed Racer, Go!
WhiteStrat has a reputation beyond reputeWhiteStrat has a reputation beyond reputeWhiteStrat has a reputation beyond reputeWhiteStrat has a reputation beyond reputeWhiteStrat has a reputation beyond reputeWhiteStrat has a reputation beyond reputeWhiteStrat has a reputation beyond reputeWhiteStrat has a reputation beyond reputeWhiteStrat has a reputation beyond reputeWhiteStrat has a reputation beyond reputeWhiteStrat has a reputation beyond repute
Well I wanna see 'em. Show 'em off!
Old 04-25-2008
MadAudio's Avatar
MadAudio MadAudio is offline
Damned if I do
MadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond repute
Homemade unfinished pine stands.....
Newest endeavor: Playing drums in a live band version of 7 Door Sedan's music.
"Do yourself a favour just shut up, read up then put up." --muttley600
Old 08-10-2009
gcapel's Avatar
gcapel gcapel is offline
boom box recordings
gcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond repute
***Resurrection Post***
Where should the monitors be vertically in regards to your ears? Mid point of the tweet and cone?
Old 08-10-2009
CIRO's Avatar
CIRO CIRO is offline
Capitu´s brother
CIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond repute
This is (at least here...) the point I have the flattest response in the mids (400-3k) and great stereo image.
Up or down 1" or a bit more for the bass balance may be necessary, though.
Ciro
'Moby Dick' Drum Solo Cover PokerDude422 MP3 Mixing Clinic 2 06-29-2006 20:49
I broke my cord on my electribe Hollywood26 Keyboards and Sound Modules 0 09-30-2005 05:54
Is my gate broke? Wireneck The Rack 2 02-23-2004 11:28
your ears or your dick? Jacobsy Songwriting, Singing & Vocals 0 09-30-2003 20:19
