Go Back   Home Recording > Equipment Forums > Guitars and Basses
Reply    Audiofanzine Guitar Guitar News Guitar Medias Guitar Tests Guitar Articles Guitar User Reviews Guitar Classifieds Ads
Old 11-20-2007
jndietz's Avatar
jndietz jndietz is offline
The Way It Moves
jndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond repute
Decisions, decisions — Half-stacks or combos?
Long story short:
I own a Marshall cabinet (the cheapy) and a ValveKing 100 watt head. I love how it sounds, I hate moving it around and its almost entirely way too loud for the venues we play at. I'm considering selling ValveKing head and buying a ValveKing 212 and putting the Celestions from the Marshall in the 212 combo. It would be easier to move around, and although it may still be loud, it probably won't be as loud as the half-stack.
Or do you guys have any other suggestions on 212 combos in that price range with two channels? I heard the VK 212 combo sounds great with different speakers in it. I thought about a Fender Twin... I think that would get too pricey for me.
Just looking for some advice here, thanks guys.
I play lead guitar for a rock band called Indecision based out of Omaha, Nebraska. Check us out here
Old 11-20-2007
Sloan's Avatar
Sloan Sloan is offline
Force of Nature
Sloan has a reputation beyond reputeSloan has a reputation beyond reputeSloan has a reputation beyond reputeSloan has a reputation beyond reputeSloan has a reputation beyond reputeSloan has a reputation beyond reputeSloan has a reputation beyond reputeSloan has a reputation beyond reputeSloan has a reputation beyond reputeSloan has a reputation beyond reputeSloan has a reputation beyond repute
The Valveking 2x12 is still 100 watts. Unless you need that much headroom, try something with a little less wattage.
Also, check out Peavey's Classic series - all of the classic i've tried have sound really good. I have a classic 20 and delta blues here right now (not mine) and i've been getting a lot of great sound from them just straight up. I used to own a classic 30 and it was great - also takes to pedals very well.
sloanstewart.com
Old 11-20-2007
Obi-Wan zenabI's Avatar
Obi-Wan zenabI Obi-Wan zenabI is offline
Force of Nature
Obi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond repute
+1 on the lower wattage --or rather saner wattage-- peaveys. You shouldn't need anything over 30 tube watts until you're playing Giants Stadium. I have a 100 Watt ampeg 212 that I am pretty certain I will *never* use for anything other than a bass amp.
A valveking combo will be just as overpowering through two nice 12's as it is through your marshall, for all intents and purposes.
Traynor makes some fine tube amps. Genz Benz makes some great ones. You'll probably have better access to try out the Peaveys, however. You can never go wrong with peavey if you play any kind of rock. So maybe stick with what you know.
Stacks make more sense with Bass Amps since you need 100 tube or 300 solid state watts to even play bar gigs. Weight really becomes a factor, which is why I sold my best bass combo off. But 30 tube watts will rock your school auditorum or bar or wherever, so a combo makes sense. Especially with two tens or two twelves.
And you don't *need* two channels. Some basic drive or boost or distortion pedal and a simple touch of the volume knob should get you what you need.
HMMMM..... I'm wondering if there are tube substitutions to bring back the power of your VK head... then you could just swap out your cab for an avatar 212 or something.
I don't need no stinkin' sig.
Old 11-21-2007
Sloan's Avatar
Force of Nature
That's a really good idea and something that isn't mentioned very often. Instead of shelling out the cash for a new amp if you already like the one you have, why not try lowering the output with different tubes and speakers.
I've seen those THD yellowjacket things that let you use different tubes, but I don't know enough about tube types to give any credible information.
sloanstewart.com
Old 11-21-2007
Thurgood Thurgood is offline
Force of Nature
Thurgood has a reputation beyond reputeThurgood has a reputation beyond reputeThurgood has a reputation beyond reputeThurgood has a reputation beyond reputeThurgood has a reputation beyond reputeThurgood has a reputation beyond reputeThurgood has a reputation beyond reputeThurgood has a reputation beyond reputeThurgood has a reputation beyond reputeThurgood has a reputation beyond reputeThurgood has a reputation beyond repute
Smile
My. 02. I prefer seperate head and cabinet. That way you can mix and match cabinets. I do own a Classic 30 combo which I really like. 30 watts is pretty loud but nonetheless, I take great please using my Dsl 100 into a 4x12. Too loud for most venues but fun nonetheless. Once again the flexibility of seperate head and cab is great. You shoulnd't automatically think high (100 watt) head; get a small head and a seperate cab, say a 1 or 2x12. Also the separates are easier to tote around.
Old 11-21-2007
cusebassman's Avatar
cusebassman cusebassman is offline
Freakin' sweet
cusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond repute
You could also get a 2x12 cabinet, put the preferred 12s in it, and get a power attenuator. Never done it myself, just another thought, and it would spare you having to switch heads, or go completely combo.
Honestly, I'd suggest that simply because a 2x12 cab isn't going to weigh a ton, and a head by itself is portable. I have a Fender Blues DeVille, which has a 65 watt all-tube head, as well as 4x10" speakers built into a combo. It is barely "portable", hehe
Originally Posted by Ford Van
I AM RIGHT
Old 11-21-2007
Mr. C Mr. C is offline
Senior Member
Mr. C has a reputation beyond reputeMr. C has a reputation beyond reputeMr. C has a reputation beyond reputeMr. C has a reputation beyond reputeMr. C has a reputation beyond reputeMr. C has a reputation beyond reputeMr. C has a reputation beyond reputeMr. C has a reputation beyond reputeMr. C has a reputation beyond reputeMr. C has a reputation beyond reputeMr. C has a reputation beyond repute
How about keeping the cab and buying a Peavey Classic 30 or 50 head? Just a thought.
Old 11-21-2007
Treeline's Avatar
Treeline Treeline is offline
Don't Give Him Coffee
Treeline has a reputation beyond reputeTreeline has a reputation beyond reputeTreeline has a reputation beyond reputeTreeline has a reputation beyond reputeTreeline has a reputation beyond reputeTreeline has a reputation beyond reputeTreeline has a reputation beyond reputeTreeline has a reputation beyond reputeTreeline has a reputation beyond reputeTreeline has a reputation beyond reputeTreeline has a reputation beyond repute
Small is good! If you need volume stick a mic in front of the combo and run it through the PA. Big amps are like drunken elephants - go where they want and make lots of noise but everyone else in the band has to accommodate them.
Originally Posted by chrisharris View Post
I love Treeline. He's so polite when he's cutting a hole in your abdomen and pulling your intestines out to play air guitar with.
Old 11-21-2007
MrStitch's Avatar
MrStitch MrStitch is offline
Senior Member
MrStitch has a reputation beyond reputeMrStitch has a reputation beyond reputeMrStitch has a reputation beyond reputeMrStitch has a reputation beyond reputeMrStitch has a reputation beyond reputeMrStitch has a reputation beyond reputeMrStitch has a reputation beyond reputeMrStitch has a reputation beyond reputeMrStitch has a reputation beyond reputeMrStitch has a reputation beyond reputeMrStitch has a reputation beyond repute
Call me the ignorant fool, but couldn't you just turn your amp down? Or is there a sweet spot on the volume knob that you like, where the sound quality is just 'perfect'?
Rockstar Karaoke
Old 11-21-2007
jndietz's Avatar
The Way It Moves
When I turn it down, I lose my tone.
Old 11-21-2007
JPXTom's Avatar
JPXTom JPXTom is offline
Bizzle Studio...Guy.
JPXTom has a reputation beyond reputeJPXTom has a reputation beyond reputeJPXTom has a reputation beyond reputeJPXTom has a reputation beyond reputeJPXTom has a reputation beyond reputeJPXTom has a reputation beyond reputeJPXTom has a reputation beyond reputeJPXTom has a reputation beyond reputeJPXTom has a reputation beyond reputeJPXTom has a reputation beyond reputeJPXTom has a reputation beyond repute
Get an attenuator, and if you dont like the size of ur 4x12, get a 2x12 cab. Heres the THD Hot Plate..while it may be expensive, it'll save you from buying a whole new rig:
http://www.musiciansfriend.com/produ...tor?sku=481283
  #12
Old 11-22-2007
Toker41's Avatar
Toker41 Toker41 is offline
Better Than You
Toker41 has a reputation beyond reputeToker41 has a reputation beyond reputeToker41 has a reputation beyond reputeToker41 has a reputation beyond reputeToker41 has a reputation beyond reputeToker41 has a reputation beyond reputeToker41 has a reputation beyond reputeToker41 has a reputation beyond reputeToker41 has a reputation beyond reputeToker41 has a reputation beyond reputeToker41 has a reputation beyond repute
Mesa Dual Rectifier Rectoverb 2x12 combo. You won't find a more versatile or better sounding amp, unless you go to the Mesa Road King combo. Don't mess around with Peavey's or any of that other limited tone stuff. You can usually find a Rectoveb 2x12 for around $1000 on ebay. They are built like a brick, so the worry about buying a used lemon is taken out of the mix. You can buy a lesser amp, but will end up chasing your "perfect" tone to the tune of thousands of dollars. Don't mess around, and end up buying a dozen amps before you find the "right one". Just buy the Mesa. You can change the tubes from 6L6's to EL34's without having to have it biosed if you want a dirtier "Marshall" type overdrive instead of the Mesa crunch. OR if you go with the Mesa Road King you can switch back and forth between the 6L6's, and EL34's via foot switch, or combine the 2. The Road King also has both a parallel, and in-line effects loops. Mesa's are still hand made, and if by an outside chance you do have a problem, when you call for support you get an actually live tech that is on the floor building amps (just try to get support from Marshall).
Here is a link to a Mesa Tremoverb (pretty much the same as a Rectoverb).
http://cgi.ebay.com/MESA-BOOGIE-DUAL...QQcmdZViewItem
" I'm a joker, I'm a smoker........."
My recordings:
Toker's Music
  #13
Old 11-22-2007
ermghoti ermghoti is offline
1K Silver Member
ermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond repute
Pull a pair of tubes out of the VK. Instant 50w head.
  #14
Old 11-22-2007
legionserial's Avatar
legionserial legionserial is offline
Dead
legionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond repute
"Introduce a little anarchy. Upset the established order, and everything becomes chaos. I'm an agent of chaos.
Oh, and you know the thing about chaos? It's fair..."
  #15
Old 11-22-2007
NL5's Avatar
NL5 NL5 is online now
Unpossible!
NL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond repute
Randall MTS 2X12 combo. Most versatile amp on the planet...........
Or, if you can swing the extra dough, get the preamp and combo amplifier that can switch between el34's and 6L6s.....
They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. -B.F.
I cut an event exactly in half based on sample rate, but it's not exactly halved,wtf? MistaMash'dup Cubase User Forum 3 02-11-2005 10:16
Half Stacks for Value skaltpunk Guitars and Basses 3 11-08-2001 12:53
