Protecting solder joints (superglue?)
When making solder joints in electric guitars (i.e. connecting wires to POTs, etc.) would it be a good idea to "coat" the joint with something that would prevent oxidation? First thing that came to mind is superglue.
Thanks!
I am a musician trapped in a lazy bum's body
dont really think it's an issue but there used to be some stuff called tweak just for that purpose... used to carry it in my audiofool retail days... i think caig may make something similar...
37.8% of all statistics are made up on the spot... hey give a guy some room... people are trying to evolve here... for crying out loud... |
Use a good quality solder and do the joint right, and there should be no troubles. You can DeOx the joints every couple of years if you want, but I wouldn't bother unless there was a problem. |
![]() thx!
oooohhh forgot that superglue is a cyanide based chemical... good call MSH...
You could always give a wrap or 2 of electrical tape over the top of the pot. That would add some protection and is easy to remove when needed.
Make your solder joints correctly and you won't need to protect them. |
Here's what I look for in a good solder joint:
1. No "balling" up. 2. The solder should melt into/onto the surface of the wires/contact. So all of the metal is a continous-smooth-flow look to it. If it's done right, there should never be a need to do it again. But it's easy to undo when it's time to swap components. The only problem I routinely have with soldering is overheating something and melting part of the pot/connector ![]() I'm getting better - but not perfect. |
it's a matter of practice and a variable temp iron helps....
2 words
candle wax. |
#12
I may be wrong. But I believe solder does not oxidise. Ive never seen oxidation on solder joints. Ive seen harden flux on joints that were not cleaned after the soldering process. And I've seen dirty solder joints because the pieces were not cleaned prior to soldering process. But never oxidation
#13
Not even sure you can still get it, but do not use an acid core flux such as plumbers might use. I've been using Kester rosin core solder for many years and never had a problem with oxidation or corrosion.
#14
Mike |
#15
corrosion will not occur unless the copper is exposed to damp weather. The inside of a guitar is protected against the elements however applying wax on the exposed soldered joint will help to prevent the possibility of any loose bare connections causing a short (not very common but it can happen) for a spliced joint on a wire always slide a piece of shrink tube up on the wire before soldering then you can slide the tube up on the splice and shrink the tube on the joint. ![]() |
#16
#17
A couple more things about soldering and copper printed circuit boards....
- Silicone RTV adhesives and sealants are handy to use when you want to fasten parts or wires to PC boards. Some RTV's use acetic acid as a curing agent and can over time corrode and destroy wires and copper raceways on PC boards. The acetic acid RTV's can be recognized by a strong smell similiar to vinegar. Don't use them. - If you're really concerned about your electronics possibly being exposed to harsh environments, you can paint it with a "conformal coating". This will protect circuit boards against moisture, corrosion, and other harmful agents. Makes it damn difficult to do repairs also. http://www.mgchemicals.com/products/4223.html Totally would be a waste on the inards of a guitar, but if it makes you feel better...... |
#18
wow, i may have unleashed the wrong can of electronic worms
![]() guys, i'm done installing new pickups. no superglue ![]() i gave it my best, but only had a fairly thick iron tip + narrow control cavity, so i don't know how good those joints are. at least it works. i will likely re-gut the wiring later on anyway, and when I do, I'll do all the soldering before installing the pots, so I'm not cramped down there. and with the right solder tip. thanks for all your responses.
#19
. What a nightmare. Technique, good materials and that's it. Too cold an iron and the joint may crack and create intermittent joints, too hot and the wire, the board or the eylets will burn/melt or lift traces from the board.If you're joining two wire ends use some shrink tubing.
She's not the boss of me
#20
id use shrink tubing as punkin mentioned.. but i think that might be a little overboard.. id spend the time and energy into the quality of the solder joints
also if your doing any circuit debugging its nice to have a clear view of your layout... glues and tubing will just make things more difficult in the future |
#21
| Does anyone know how to solder cables? | Sagar | Studio Building & Display | 53 | 11-16-2007 22:28 |
| 34B Capstan Motor Lube and Cold Solder Joints | R. D. Davis | TASCAM User Forum | 4 | 08-24-2005 20:09 |
| OK, so I dusted off the ol' soldering iron... | Michael Jones | Studio Building & Display | 42 | 12-14-2003 21:48 |
| Soldering Cables | scottn5388 | Other Equipment and Reviews | 21 | 03-26-2003 11:26 |
| making cables! quick solder help pt 2 | lilcapn | Microphones | 15 | 10-05-2002 18:05 |
