Go Back   Home Recording > User Forums by Brand > Don't Fear The Reaper
Old 11-16-2007
GreenDank GreenDank is offline
Dedicated Member
GreenDank has a reputation beyond reputeGreenDank has a reputation beyond reputeGreenDank has a reputation beyond reputeGreenDank has a reputation beyond reputeGreenDank has a reputation beyond reputeGreenDank has a reputation beyond reputeGreenDank has a reputation beyond reputeGreenDank has a reputation beyond reputeGreenDank has a reputation beyond reputeGreenDank has a reputation beyond reputeGreenDank has a reputation beyond repute
Possible to adjust all volume sliders at once?
I'd like to grab all the volume sliders of my tracks and bring them all down by the same amount such that I can eliminate a track going in the red (and then have some more room to play with if it's cranked to the max), but then use the master to bring the whole thing back up to just under the red, ya know?
Is it possible to select them all and move them up and down by the same exact amount?
THANKS
Musak
Old 11-16-2007
Dedicated Member
I think I just answered my own question looking at the wiki help. Apparently just hold control and select all tracks, then use up/down arrows to adjust? The tracks seem to not all move at once, but looking at the numbers it appears they do in fact get adjusted the same amount, but the sliders aren't necessarily (visually) synched up.
Musak
Old 11-16-2007
dementedchord dementedchord is offline
Psychotic State alumni ch
dementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond repute
another way to do this would be to make a sub group that contains them all...
37.8% of all statistics are made up on the spot...
hey give a guy some room... people are trying to evolve here... for crying out loud...
Old 11-19-2007
TexRoadkill's Avatar
TexRoadkill TexRoadkill is offline
Audio Bum
TexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond repute
Not quite the same thing because you could still be overdriving the sub group input.
Old 11-19-2007
agreed .... that's possible...
Old 11-20-2007
kubeek's Avatar
kubeek kubeek is offline
Dedicated Member
kubeek has a reputation beyond reputekubeek has a reputation beyond reputekubeek has a reputation beyond reputekubeek has a reputation beyond reputekubeek has a reputation beyond reputekubeek has a reputation beyond reputekubeek has a reputation beyond reputekubeek has a reputation beyond reputekubeek has a reputation beyond reputekubeek has a reputation beyond reputekubeek has a reputation beyond repute
No that isnīt possible, reaper does all inside calculations in 64 or 32bit floating point, so it is virtually impossible to overdrive a subgroup.
But it certainly is possible to overdrive plugins that arenīt capable of floating point.
Originally Posted by walters View Post
i'm not getting that Polish mastering sound why is that?
Running an amp at Max?? Disco_Dave Other Equipment and Reviews 12 09-15-2007 09:18
Volume Envelopes in Sonar HS 4 vs CW9 EddieRay Cakewalk / Sonar Forum 0 05-27-2006 13:01
Volume Control? Foxdog175 Recording Techniques 8 06-25-2004 09:30
Help, Volume adjust and Dynamic Range, sound cards? Layla24 Booda Digital Recording & Computers 1 01-14-2004 20:45
Need help setting windows volume levels... Keyz316 Digital Recording & Computers 1 12-19-2002 12:57
Copyright Đ 1995-2008 Audiofanzine except where noted. All Rights Reserved.
