Old 11-14-2007
kmacbeatle kmacbeatle is offline
Newbie
kmacbeatle is on a distinguished road
Unbalanced Spring reverb for vocals.
I have a Furman RV-1 reverb that I want to put in my vocal chain for recording. It only has unbalanced inputs and outputs. Will i get the same problems putting a mic signal through it that i would putting a mic signal through a guitar pedal? will i have impedance issues? If my chain looks like this, will I be okay?
Microphone>preamp>preamp's unbalanced output into reverb unbalanced input> reverb's unbalanced output into compressors unbalanced input> compressor's balanced output into the balanced input of audio interface
Thanks so much!
Old 11-14-2007
MOFO Pro MOFO Pro is offline
Opinions are like SM-57s
MOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond repute
Shouldn't be a problem... not at all... with the chain as described
It's not just the signal chain... It's the hands that touch it
Old 11-15-2007
RawDepth's Avatar
RawDepth RawDepth is offline
1K Silver Member
RawDepth has a reputation beyond reputeRawDepth has a reputation beyond reputeRawDepth has a reputation beyond reputeRawDepth has a reputation beyond reputeRawDepth has a reputation beyond reputeRawDepth has a reputation beyond reputeRawDepth has a reputation beyond reputeRawDepth has a reputation beyond reputeRawDepth has a reputation beyond reputeRawDepth has a reputation beyond reputeRawDepth has a reputation beyond repute
My advice would be to not add any reverb or compression while tracking. Because, if it turns out that you don't like any part of it, you can't undo it. A lot of people add those effects to the tracks later as needed.
You may want to consider this. There are no rules in recording, but there sure is common sense reasoning.
___________________________
________________________________________
Old 11-15-2007
TexRoadkill's Avatar
TexRoadkill TexRoadkill is offline
Audio Bum
TexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond repute
Unless you want a super wet reverb sound you probably want to put the compressor before the reverb. But like Raw Depth suggested it's safer to record clean and add effects in the mix.
Old 11-15-2007
Freudian Slip's Avatar
Freudian Slip Freudian Slip is offline
Source Of Confusion
Freudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond repute
Yep. Why be stuck with it when you can add it later.
F.S.
"If Congress can do whatever in their discretion can be done by money, and will promote the General Welfare, the Government is no longer a limited one, possessing enumerated powers, but an indefinite one"
James Madison: the father of the Constitution
spring reverb rdfuze Recording Techniques 7 03-21-2005 10:51
Stupid Reverb Questions NL5 Mixing / Mastering 23 03-11-2005 15:15
Fixing spring reverb in Peavey? Bodhisan Guitars and Basses 2 02-22-2003 11:12
Spring reverb ??? cjacek The Rack 18 01-30-2003 19:24
manual for Orban Spring Reverb RockaBill The Rack 2 03-06-2002 13:49
