Old 11-12-2007
ugga ugga is offline
Newbie
ugga is on a distinguished road
Patchbay or Splitter?
Hi, I'm newbie in this forum, so hello to everybody.
I'm planning a PA routing and i have one question.
I want to set up system, when i can record gigs with MOTU in my computer and mix them as well with analog mixer.
So i have chosen YAMAHA 24/14FX, but it doesn't have a DIRECT OUT jack outputs and i have never used Patchbays, so here's my question:
If want to route guitar, for example, both to my live mixer and MOTU, can i use BEHRINGER ULTRAPATCH PRO PX3000 Patchbay to split my signal in 2 parts and send one to my mixer and one to my firewire interface?
Does patcbay works as well when +48V Phantom power is used in my mixer?
I hop you understood my problem and thanks to everybody who can say something about that.
Old 11-12-2007
pandamonk's Avatar
pandamonk pandamonk is offline
Three Thousand and Counting
pandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond repute
I understand, but no a patchbay doesn't work like this. Why not get a different mixer?
Old 11-12-2007
technominds's Avatar
technominds technominds is offline
Force of Nature
technominds has a reputation beyond reputetechnominds has a reputation beyond reputetechnominds has a reputation beyond reputetechnominds has a reputation beyond reputetechnominds has a reputation beyond reputetechnominds has a reputation beyond reputetechnominds has a reputation beyond reputetechnominds has a reputation beyond reputetechnominds has a reputation beyond reputetechnominds has a reputation beyond reputetechnominds has a reputation beyond repute
Ok, I think I understand what you are trying to achieve.
A patchbay can be used to split a signal, but your signal will not be amplified yet.. and if using phantom powered mic's they wont have any power to run them.
The best way to get 24 channels of audio back out of your mixer is to use the inserts, infact... I think that may be the ONLY way you could get 24 channels out of your desk to your MOTU.
A patchbay wont help you at all.
Old 11-12-2007
Newbie
My funds probably are going to be quite limited.
Can i use splitters like this? - thomann.de/gb/t-racks_split-it.htm
sorry for crapy link, but forum script says that i have to make at least 5 posts....
Old 11-12-2007
pandamonk's Avatar
Actually. That mixer has insets. These can be used like direct outs. The only problem i can see, is that you may wish to use them for FX. But it may still be possible. http://www.thomann.de/gb/t-racks_split-it.htm that'd work, but inserts will too.
Old 11-12-2007
Force of Nature
got there first
Old 11-12-2007
Newbie
Yes, i had the same idea, so if i pick up the signal in insert, split it with patchbay and one of splitted signals goes back trough compressor, for example, and other one goes to Motu, it will work, yea?
Old 11-12-2007
Force of Nature
Is your compressor a seperate rack compressor or is it the built in FX?
What you will need to do, for each channel;
Use an insert cable which gives you one IN jack and one OUT jack.
You would need to use a splitter (or patchbay) to split the out into two, one will feed back into the IN and the other will go to your MOTU.
As for FX, will you want to record the FX and use them live?
Old 11-12-2007
gcapel's Avatar
gcapel gcapel is offline
boom box recordings
gcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond repute
The mixer should have inserts. So if your using a balanced 1/4" cable, plug it in the insert jack only halfway. Plug the other end into the MOTU and there ya go.
The insert acts as a loop. You can go in and out of the signal path via tip and ring. The Ring on the mixer insert is the send, and the tip is the return. So plunging in the plug half way makes the tip the send to accomadate your MOTU.
I think I'm right on this.
EDIT.... read previous reply, I did not read the question fully. This reply will connect staight to a DAW.
Old 11-12-2007
Force of Nature
This is correct, but I think you lose the signal back to the mixer. You have to use a proper insert cable and split, then send back.
Old 11-12-2007
Newbie
Yes, i'm planning to use separate compressor on each of drum channels.
It would be good to have a option to record drums with and without effects, but i'll deal with it, and of course i know what is inserts for, but somehow i didn't realized that i can do it with inserts.
So, for example, i'm going to record only bass drum, so it goes into my microphone input, then it goes out trough insert, splits in to parts. One of them goes to compressor and goes back to insert return, other one goes to motu and records nicely in cubase.
  #12
Old 11-12-2007
Force of Nature
Thats right, but remember that your MOTU signal will not be compressed.
Depending on the compressor, you may want to go about it this way:
Microphone > Compressor > Splitter;
Split A - Mixer
Split B - MOTU
TM
  #13
Old 11-12-2007
Newbie
Split A - Mixer
Split B - MOTU
TM
Yea, but that isn't a big problem to put compressor between insert and motu..
So, thank you very much.
  #14
Old 11-12-2007
pandamonk's Avatar
got there first
You did. haha
  #15
Old 11-13-2007
Roguetitan's Avatar
Roguetitan Roguetitan is offline
The Poly Grip Kid
Roguetitan has a reputation beyond reputeRoguetitan has a reputation beyond reputeRoguetitan has a reputation beyond reputeRoguetitan has a reputation beyond reputeRoguetitan has a reputation beyond reputeRoguetitan has a reputation beyond reputeRoguetitan has a reputation beyond reputeRoguetitan has a reputation beyond reputeRoguetitan has a reputation beyond reputeRoguetitan has a reputation beyond reputeRoguetitan has a reputation beyond repute
active DI balanced out to mixer, unbalanced out to MOTU
Until This Day
  #16
Old 11-13-2007
mixsit mixsit is offline
Been Here, Posted That
mixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond repute
Doesn't the Motu have direct monitoring -go there first, line out back to the mixer?
Monitoring at CathouseSound AetherAudio 'Continuum A.D. and TimePiece 'Mini
(formerly S.P. Technology
  #17
Old 11-13-2007
Force of Nature
What about Preamps?
  #18
Old 11-13-2007
Roguetitan's Avatar
The Poly Grip Kid
What about Preamps?
preamp out> MOTU out> Mixer in
Until This Day
  #19
Old 11-13-2007
What about Preamps?
Yeah. Not sure, but I thought he was looking at splitting the mics.
  #20
Old 11-13-2007
timboZ's Avatar
timboZ timboZ is offline
Band-Aid®
timboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond repute
What about this.
http://www.musiciansfriend.com/produ...tor?sku=154021
WARNING:
THIS POST DOESN'T CONTAIN ANYTHING HELPFUL
http://www.myspace.com/veritasrs
__________________________________________________________________________________________________
  #21
Old 11-14-2007
Adam P Adam P is offline
stuck in the money pit
Adam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond repute
If you already have the patchbay, do it like this:
Insert sends to the top row of the patchbay on the back. Set the patchbay channels to be half-normalled. Connect the bottom row on the back of the patchbay to the insert returns. Take lines out from the top row on the front of the patchbay to the MOTU. Since its half-normalled, inserting lines into the top row on the front won't break the connection.
The Flight | Odd Number Recording
my patchbay doesn't have a switch to goto Half normalled..open... earworm The Rack 3 3 Weeks Ago 11:17
Please Help: Connecting Neutrik Patchbay to AW16G!! MITCHM2005 The Rack 6 11-01-2007 12:06
Help! I'm in Patchbay Hell Ginazgifs Analog Only 6 08-12-2006 19:09
Signal flow/ Patchbay/ RNC's (2) Pro Tools User The Rack 1 09-18-2004 22:05
midi patchbay trickeries L'espion Noir The Rack 5 11-08-2002 11:00
