Slow Audio Playback...Entire System
Hello...
All of a sudden all of the audio applications on my PC (SONAR, WaveLab, Windows Media Player...everything) are playing files at a very slow speed (sounds like they're playing at approximately 1/2 the normal speed.) I understand this is probably a sample rate thing, but does anyone have any idea what might be causing it? I've reinstalled my AI's drivers (Echo Audio Layla 24/96), but that didn't work. Need help. Thanks, mark4man Dell Dimension 8250 | Windows XP | Intel 850E Motherboard/Chipset | Intel P4 2.53GHz CPU (512 KB L2 Cache, 533 MHz FSB) | 1024 MB PC1066 RDRAM | Maxtor DiamondMax 9+ 80GB Secondary HD / Single Volume (Audio Data only) | Echo Audio Layla 24/96 | Universal Audio UAD-1 DSP Powered Plug-In System | KRK Rockit RP-8 Studio Reference Monitors | SONAR 5.0.2 | WaveLab 5 |
Your sample rate on your sound card is set incorrectly. Go into the console and fix it. You need to shut off all computer sounds so that your sound card does not switch to a low quality sample & bit rate when your computer decides to beep at you or something. That should keep the problem from coming back again. playing a 44.1k sampled song at a different setting is just like changing the speed on a record player. Good Luck F.S.
"If Congress can do whatever in their discretion can be done by money, and will promote the General Welfare, the Government is no longer a limited one, possessing enumerated powers, but an indefinite one" James Madison: the father of the Constitution |
thanks freud...
Forgot all about the Echo Console (to be honest...I actually lent my Layla 24/96 to my lead guitarist, for his project studio...& this is all happening on his machine.) I'll let him know...thanks again. MF |
No problem
F.S.
| my audio is skipping during playback ...help? | daveymul | Cakewalk / Sonar Forum | 2 | 04-02-2005 13:03 |
| The Mic Test Thread! | Rhythmschism | Microphones | 41 | 04-30-2004 12:23 |
| Difference between SEND and INSERT in cubase | Gabriel Sousa | Digital Recording & Computers | 4 | 01-27-2003 12:48 |
| Audio Breaking up on playback & Recording | dvs recordings | Newbies | 3 | 02-02-2002 18:27 |
| Playback Monitor system | magoo | Studio Building & Display | 3 | 08-14-2001 08:13 |
