Old 11-09-2007
Ricky Denim Ricky Denim is offline
Newbie
Ricky Denim is on a distinguished road
Input Monitoring/Echo help...
I've been trying to use the input monitoring function in Sonar as i'm a pretty average vocalist and having some reverb on a performance would help me out a great deal. Im using an Audiophile 2496 card into a Alto 4 track mixer. When I select input echo on a track, I can hear the effect but it echo's/delays really bad.
I read the help file on muting the line-in input but it doesnt really make sense to me. Is there something I can do on my setup to get rid of the echo?
Thanks.
Old 11-10-2007
kgirl72's Avatar
kgirl72 kgirl72 is offline
Hiya
kgirl72 has a reputation beyond reputekgirl72 has a reputation beyond reputekgirl72 has a reputation beyond reputekgirl72 has a reputation beyond reputekgirl72 has a reputation beyond reputekgirl72 has a reputation beyond reputekgirl72 has a reputation beyond reputekgirl72 has a reputation beyond reputekgirl72 has a reputation beyond reputekgirl72 has a reputation beyond reputekgirl72 has a reputation beyond repute
Have you tried sliding the latency bar to a lower setting? I keep mine around the 4-5 milliseconds. You'll never hear an echo at that setting. You can go higher than that and still not hear a difference,
In the tools section I think, there is an audio button you select and it brings up your settings. The latency slider is on the first tab of your audio profile.
that may be obvious information to you, but if not, then hopefully it helps.
I haven't looked up your audiophile to see it's capabilities, but I'm pretty sure that it can operate on low latency.
Now if you're using asio for your driver (I don't generally) then you'll want to press the button where the latency slider is that says something like asio panel. There you can lower your buffers and it will lower your latency.
Unless there's something else going on, which I can't answer, but someone here will.
What?!
Old 11-10-2007
Newbie
Hey Thanks so much for your reply. I didnt think it would be what u suggested but damn it you were right!...i think lol.
I opened up my audiophile control panel and set dma buffer to lowest (128) and in Sonar selected buffer to fastest, which came up with 5.8ms. It made a HUGE difference. It still doesnt seem quite just right, but its definately workable.
Thanks a ton!
can a "+ 12 dBu,20 kilohm" input handle a guitar? earworm The Rack 3 05-07-2005 12:30
Hi-Z Input vs. Line Input SoonerFan Newbies 0 04-19-2005 11:18
Input level "noise" of -72dbfs? iboersma Newbies 15 02-09-2005 22:23
MR-8 input level problem solved, sort of. ivan1 Fostex Forum 2 02-03-2003 09:54
Stereo input channels...? A Drummer Mixing / Mastering 1 03-26-2001 07:44
