Bogen amps and plugin transformers?
Anybody here tried the Bogen tube amps that go for cheap on Ebay?
It is tempting to pick one up to use for a guitar amp. Also, I found a local place that is selling Bogen mic input transformers dirt cheap. I have looked at one up close and it seems like a nice quality unit. The model number on it is TM-200A and it has a 9 pin base. Searching the web doesn't turn up any specs at all. I found a schematic of a Bogen amp that shows the pinout of the transformer and another place is selling them for $76 each. From another source I learned that the part # indicated the primary impedance - 200 ohms. From what I have read regarding specs of some Bogen PA equipment it looks common for their mic inputs to have a 50hz to 20K frequency response. Another spec sheet I found was for their 600 ohm line matching transformer which had the same frequency range. The accompanying graphs showed a decent looking response curve too. Is it worth using this to build a cheap preamp?
If you could see crime in a mans face we wouldn't have any mirrors - H. Bogart Somnium7 Somnium7 on MySpace |
Sorry to dredge up an old topic but I thought some folks might be interested.
What if I were to tell you that you could buy a transformer input discreet transistor preamp with a discreet transistor compressor/limiter, a passive EQ made with inductors and a discreet opamp output driving a fat OPT for roughly $10 - $20? ![]() ![]() ![]() Would you think I was hitting the pipe too much? ![]() I mean, shit, we're talking about the channel strip of the Gods here. There's no way you can get all that for so little. Right? ![]() I think you can. I will attempt to prove it too. Bear with me for a week or so and I will give you all the gritty details. I am waiting for a certain package to arrive. I'll let everybody know the model number and schematics and such then... ![]()
Sounds intriguing.
«:: «::B::» «::E::» «::C::» «::K::» ::» "Where in the hell are the red M&M's?" ~My Lil' Sister, 1976 |
I'm basing alot of this on mostly speculation at this point. I have done some dissecting of curbside trash items and looked at lots of schematics and spec-sheets but have yet to hear a sound.
Sooooo, we shall see. I have found something containing all the cool shit I mentioned earlier but have no idea what it sounds like yet. Stay tuned ![]()
crap you know about the stereo repair shop off Northern Blvd. in Flushing, NY too? I swear! ![]() Quote:
Yeah, I should go out more, but, then the problem is, that I'll pick up anything and everything with a wire or a switch in it ..heh heh, and there'is three dimensional limit in my cave.
So, I use eBay and craigslist, this way at least a few bucks due combined with the pack of inconveniences privide some reasonable level of restriction on my "activities". ![]() here's "your" (who ever may "apply") chance, ![]() http://cgi.ebay.com/Bogen-model-CDM-...mZ230228518385 Never been there, but I dig the 'Place Name', ******** OK, Keep On Playing On and Around: ![]() |
That repair shop was a little Korean place on 136th St. and they were always throwing good stuff out. They would take a blowtorch to parts to keep people from restoring the stuff. One day I went in there with a Korean friend of mine as a translator and after that I got dibs on things before the torch hit 'em ![]()
nop.
I'm a guy, frequently searching eBay for "Bogen Mixer" 'keyword' ![]() I amctually always 'hunting' specifically for MX6-A (s) - little things with goods , used them as hearts and livers for THIS and THIS ![]() I have a 'dream' to build 4 (or maybe 8) channel two bus all tube mixer. It would be a major project, if ever ..grrrrrrr ![]() |
Just so you know I have 3 Bogen TM-200 input transformers if you need them. I paid almost nothing for them so I'll trade for anything of use to me - I have a very long list (parts).
I also have schematics for the pinout of the trannies as well as the zobel network they require.
#12
sell them on eBay, let people have fun
, then re-invest the cash asap ![]() ******** OR!!!!!!!! ..., just keep them. You never know what idea may fall on your head tomorrow after the storm and you may want to "inject them" somewhere they have never been nor ever dreamt of being". - "Where are my trannies?! Where are my trannies!!!!" heh heh ![]() |
#13
Mike,
here's link to the project I have in my "save folder", I've found it while ago when I was working on my first bogen tube preamp/mixer thing. In case you have not seen this page before. This is for MXM tube mic pre/mixer, you may find it interesting to look through: http://www.clarkhuckaby.com/BogenMod/MxmMain.html |
#14
I've got 3 Bogen tube mixers with stock transformers. They're worth every dime (well, at about $120 certainly) and they really make your guitar and bass tracks come alive. They have a reasonably good amount of head room, the only issues with my MXM-As is that the power supply needs to be rebuilt, which isn't a horrible undertaking as the Photofacts are readily available for cheap.
Pat Boone's Farm is a band that loves obscure tube amps, electric 12 string guitars, and vinyl: http://www.myspace.com/patboonesfarm Cavetone Records is our wonderful vinyl-only label. http://www.cavetone.com |
#15
Never played with the Bogens but I do have an Altec 1567a which is probably similar. It's a high-quality all tube PA preamp from long ago with 4 mike preamp inputs, all with high quality plug-in transformers made by Peerless, plus a 5th high-Z input all mixed into a master section which has bass and treble controls and a master output. It has a transformered, 600 ohm output. I paid a tad over $200 for the thing. Good stuff! I use it as a single preamp or for tracking drums in mono with a few mikes.
Cheers, Otto |
#16
It's nice to be home from my business trip at last. Just about everything I ordered in the past week has arrived except my Bogen CT-35 Acousta Master!
![]() I was hoping to dink with it this evening and add something engaging to this thread - so instead enjoy this clip: ![]() http://www.youtube.com/watch?v=INS24...eature=related Now you may see the schematics... http://www.angelfire.com/vt/audio/bogen_ct_1.gif http://www.angelfire.com/vt/audio/bogen_ct_2.gif
#17
Mike, check this out, this may be a 'somewhat identified not-so-flying object' of your interest : http://cgi.ebay.com/prokit-6-channel...mZ330220781781
maybe not, but it got some 'stuff' ![]() |
#18
I am currently drooling over this: http://cgi.ebay.com/ws/eBayISAPI.dll...MEWA:IT&ih=003 Very tempting since it's so close to where I work ![]() ![]() ![]() I only wish it had more mic channels... Believe it or not I am STILL waiting for the damn Bogen amp to arrive... ![]()
#19
Mike, by "got some stuff" I mean the "stuff" to be taken out of what ever "circuitry" there may be, and stuff to take off the shafts, off the plates and off anything that holds something , heh heh ...
![]() so it went for thirty bux plus "from me to your door" service fees ... that's what I call a 'nice deal' for a DIYer, well, sort of. ******* wow, that Collins looks sharp ![]() I was watching this junker for some time, but it's a bit too far from where I'm and it rather quickly was transformed from a "nobody cares $9.99 deal primary" to a "WWF event secondary", well, sort of. |
#20
![]() Quote:
![]() In that light I say buy any solid state with transformers gear you can get your hands on while you can still find it at bargain basement prices. Oh yeah the Bogen amp finally arrived today. I'm looking forward to seeing if this baby will live up to my expectations ![]()
#21
Bogan is a derogatory term in Australia - derived from the annoying & rather meaty Bogan Moth & used to refer to thsoe who's lifestyle & tastes are suburban, inclined toward mullet (hair not the fish) & about as radical as confederate flag waving baptists.
To my mind, that's a bunch of OK as I'm a "westie", wear flannelette, denim & have a funny haircut - mind you my politics isn't so much redneck as red (I'd rather be red than dead!). |
| Pre Amps? | gabereding | Newbies | 6 | 04-12-2005 10:15 |
