I tried to import a .wav file into a song, and it showed up as offline. When I right clicked on the properties tab, it said "This wave file is not PCM or floating PCM"...
Whatdafuck is that? Is there a codec or plugin I need in reaper to use these files? It's a bunch of sound effects and movie quotes that I like to put in my songs from time to time, and I don't want to delete them and find something else that fits. Take too much time, which I don't have.
The hardest part of being a bartender is figuring out who is drunk, and who is just plain stupid. |
Wrong forum?
![]() Think I'll try the 'puter forum and see if someone there can help my dumb ass.
Weird, reaper will import a LOT of types of sound files
Come to reaper chat if you can, I'd like to get to the bottom of this
DrummyQ VST New! Kompound Drums Vol 1 Sample Building Kit REAPER Merchandise REAPER Chat |
I asked this in the computer forum. I was told it was an old file encoded mp3 even though it has a .wav extension. I have a converter. I'll convert them to .wav so I can use them.
Update: the converter worked! I will have to convert about 400 files now, but at least I found a solution.
what an awful realization, that files you thought were waves are actually compressed.
I can't listen to that much Wagner. I start getting the urge to conquer Poland. |
But that doesn't remove the artifacts mp3s create, which is the point I was trying to get at. Oh well, it works for you, that's what matters.
If they truely are mp3's then just change the extension to mp3, reaper will handle mp3's right besides 16 bit wavs or 24 bit wavs, in the same mix. Well its worth a try before you convert all those files when it just may be a extension issue.
In a letter to his daughter, the MCP expressed unhappiness over the eagle as the symbol of America, he wanted the Tron guy. Equipment G.F.C.G. # 000 035 |
And I don't know how to change the extension... ![]()
Changing an extention is easy. Just rename the file from "filename.wav" to "filename.mp3" It's that easy.
| Cubase SX mixing output levels question | Gabriel Sousa | Mixing / Mastering | 7 | 01-31-2006 03:32 |
| DSD Vs PCM from the Head Engineer at Phillips | BigRay | Other Equipment and Reviews | 0 | 12-08-2005 09:00 |
| The Pace of PCM Digital Audio? | mark4man | Digital Recording & Computers | 1 | 06-12-2004 11:28 |
| floating floors | jonothon | Studio Building & Display | 4 | 12-31-2002 09:43 |
| Lexicon PCM vs. MPX what exactly is the difference? | JOAT | The Rack | 9 | 02-23-2002 21:32 |
