Go Back   Home Recording > User Forums by Brand > Don't Fear The Reaper
Old 11-05-2007
Pitseleh Pitseleh is offline
Junior Member
Pitseleh has a reputation beyond reputePitseleh has a reputation beyond reputePitseleh has a reputation beyond reputePitseleh has a reputation beyond reputePitseleh has a reputation beyond reputePitseleh has a reputation beyond reputePitseleh has a reputation beyond reputePitseleh has a reputation beyond reputePitseleh has a reputation beyond reputePitseleh has a reputation beyond reputePitseleh has a reputation beyond repute
Help!
I'm using a Mackie 1202-VLZ3 mixer hooked up to my delta 1010LT's 3-4 input from the Mackie's ALT 3-4 outputs. I've been using Reaper as my DAW and everything was good, but a couple of days ago Reaper just stopped getting any signals from anything.
The Mackie shows its getting a singal from my mic, and the Delta's digital mixer shows its getting a signal, but Reaper won't. I checked the inputs on reaper and it's the correct ones. I don't know what other setting that would be causing this problem.
The only thing i've really done else besides the usually is download some free vsti programs and fruity loops and messed around with those. I'm not sure if any setting I changed on those indirectly changed something in Reaper. help me out please!
thanks
Old 11-05-2007
pipelineaudio's Avatar
pipelineaudio pipelineaudio is offline
Official Shill as of 7/07
pipelineaudio has a reputation beyond reputepipelineaudio has a reputation beyond reputepipelineaudio has a reputation beyond reputepipelineaudio has a reputation beyond reputepipelineaudio has a reputation beyond reputepipelineaudio has a reputation beyond reputepipelineaudio has a reputation beyond reputepipelineaudio has a reputation beyond reputepipelineaudio has a reputation beyond reputepipelineaudio has a reputation beyond reputepipelineaudio has a reputation beyond repute
Whats driver are you using in the options\preferences\ audio\devices?
Also make sure the "enable inputs" box is checked, and that the range is correct
Old 11-05-2007
IronFlippy's Avatar
IronFlippy IronFlippy is offline
Dedicated To My Member
IronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond repute
Sometimes it takes a couple minutes for Reaper to recognize input. It happens to me every now and then. I suppose I should post over at the Reaper forums...
I can't listen to that much Wagner. I start getting the urge to conquer Poland.
Old 11-05-2007
Junior Member
I'm using the M-Audio Delta ASIO drivers
the correct range is there and the enable inputs is checked
i went away for a couple of minutes but the armed track still didnt get any signal.
Old 11-05-2007
Rokket's Avatar
Rokket Rokket is offline
Sgt Floyd Pepper
Rokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond repute
If you are getting a signal from the mic, mixer and M-Audio, check the connection from the M-Audio to your computer. Perhaps you have a bad cable...
The hardest part of being a bartender is figuring out who is drunk, and who is just plain stupid.
Old 11-05-2007
is reaper set to release the audio driver when not the active application?
Disable that for a bit and see what happens
