Akai's reel-to-reel 'Sound On Sound' function
Can anyone explain the concept behind the 'Sound on Sound' function that Akai built into their reel-to-reel tape machines? I'm using an Akai 4000DS and would like to use it as a primitive multi-track tape recorder.
According to the user-manual of a similar model, the 'Sound on Sound' function lets you "..accumulate as many seperate recordings on a single track as is desired." (reference: http://www.obsoletemedia.com/tapedec...KAI-page12.htm) Following these user-manual instructions though i've not had any luck with the function. Can anyone talk me through it? Thanks. YDR |
Sounds to me like some sort of a "Bouncing" option. The way the manual words it is a little confusing. They almost make it sound as if you can record seperate "tracks" to a single track. That's not possible. A track is just 1 track. Pretty sure it's some kind of "Bouncing" function. The manual looks as if it explains the process of the procedure. Try it out and let us know.....
![]() Cheers, A |
If I'm correct, you can record on one track (say the left, for example) and listen to the right channel, which would have previously recorded material on it. Basically, instead of recording on two channels at once, it gives you the option of recording on one at a time with simultaneous playback on the other track.
<insert witty and more appropriate comment here>
I dunno. You got me. It does say though "The third and subsequent recordings are made in the same manner as the second by switching track selector switch to 1-4 and 2-3 and swapping the mic back and forth between the L and R inputs"
Probably not worded exactly as I've written it, but something like that. |
According to a experienced engineer here in Norway, on Tandberg recorders, the "sound-on-sound" feature allows you to bounce one track to another, while overdubbing with a microphone or instrument.
The overdub will play back slightly delayed, due to the distance between playback and recording heads. |
This is correct. If I remember right that deck has a simul-sync function so you will not have the delay.
I like Miles Davis and I like violins, but right now I need a Telecaster with Don Mare DonOcasters through a Deluxe Reverb turned up to 10 - almost a John Hiatt quote |
| line level Shifter +4 and -10 | walters | Recording Techniques | 24 | 06-02-2005 17:02 |
| Hypersonic What? | tangerine | Recording Techniques | 24 | 05-17-2005 07:38 |
| From experience - What is the best Sound Editing/Recording Software? | radiogold | Digital Recording & Computers | 12 | 02-18-2005 03:54 |
| A Controversial Article ? | smellyfuzz | Mixing / Mastering | 9 | 10-30-2001 12:54 |
