Old 10-28-2007
cjacek's Avatar
cjacek cjacek is offline
Analogue Enthusiast
cjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond repute
Talking Nakamichi deck flipping a cassette! You gotta see this!!
http://www.youtube.com/watch?v=z0MgJKx5Ay0
http://www.youtube.com/watch?v=lf4eR3ZkvoY
'cmon, this is cool, right?
Old 10-28-2007
The Ghost of FM's Avatar
The Ghost of FM The Ghost of FM is offline
French Mofo
The Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond repute
Those RX series decks were very cool indeed!
And to think, what made them come up with that design in the first place, was that they couldn't build an auto-reverse (rotating head) that would keep its azimuth alignment.
Cheers!
Old 10-28-2007
dementedchord dementedchord is offline
Psychotic State alumni ch
dementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond repute
that's one of two answers NAK had for tape skewing in auto-reverse decks... the other they used in one called the dragon and it automates the head stack with a servo that self adjusts...
37.8% of all statistics are made up on the spot...
hey give a guy some room... people are trying to evolve here... for crying out loud...
Old 10-28-2007
French Mofo
And the simplest answer would have been to just build a 4 track head, like all our Portastudio's had/have and then all the alignment issues would have been solved and probably cheaper too then building that fancy RX tape spinning mechanism.
Oh well.
Cheers!
Old 10-28-2007
Tim Gillett Tim Gillett is offline
Musician/technician
Tim Gillett has a reputation beyond reputeTim Gillett has a reputation beyond reputeTim Gillett has a reputation beyond reputeTim Gillett has a reputation beyond reputeTim Gillett has a reputation beyond reputeTim Gillett has a reputation beyond reputeTim Gillett has a reputation beyond reputeTim Gillett has a reputation beyond reputeTim Gillett has a reputation beyond reputeTim Gillett has a reputation beyond reputeTim Gillett has a reputation beyond repute
I dont think Nakamichi would have gone to all that trouble if they could have solved the azimuth drift problem simply with a 4 track head.
Before that Nak had pioneered physically separate (and separately adjustable) record and play heads for precise azimuth alignment between record and playback, as well as better magnetic shielding from each other. And it was they who created a dual capstan deck with capstan shafts spinning at different speeds to reduce resonances, as well as removing the need for a felt pressure pad with all its problems, including azimuth instability.
It was also Nak that later developed automatic (servo controlled) and manual azimuth correction for a front panel control.
If anyone was serious about addressing the real azimuth issues with slow speed cassettes it was Nakamichi. I'm sure they knew what they were doing in making the RX series, even if that model wasnt a raging commercial success. I think the RX deserves to be honoured for more than just its novelty.
Cheers Tim
Old 10-29-2007
jjones1700's Avatar
jjones1700 jjones1700 is offline
Learning, always learning
jjones1700 has a reputation beyond reputejjones1700 has a reputation beyond reputejjones1700 has a reputation beyond reputejjones1700 has a reputation beyond reputejjones1700 has a reputation beyond reputejjones1700 has a reputation beyond reputejjones1700 has a reputation beyond reputejjones1700 has a reputation beyond reputejjones1700 has a reputation beyond reputejjones1700 has a reputation beyond reputejjones1700 has a reputation beyond repute
Oh well.
Cheers!
You would think that Teac would have thought of that huh?
<insert witty and more appropriate comment here>
Old 10-29-2007
the problem is tape skew... as the capstan pulls the tape one direction it comes of at a very slight angle (which can be adjusted for in alignment) but when the tape reverses the skew would go the other way... so a 4 track head wouldn't be able to compensate if fixed to compensate for the first direction.... make sense???
Old 10-29-2007
jjones1700's Avatar
I see your point. Cassettes don't have the benefit of the guide system of R2R decks. It was a nice theory though.
Old 10-30-2007
jjones1700's Avatar
Woohoo!! A buddy of mine is giving me a Nakamichi MR-2 deck for mix downs. It doesn't do the whole "flip" thing, but still cool nonetheless.
Does anyone know how to slow down the recording on a dual cassette deck? PoOpBoY Analog Only 8 05-30-2000 01:22
Tascam 112 MKII Cassette Deck Manual VartRecords TASCAM User Forum 0 02-14-2000 12:23
Which cassette deck to buy Dugger Other Equipment and Reviews 2 01-05-2000 01:27
recording webcast audio to cassette deck ere1 Newbies 0 11-15-1999 01:17
How to calibrate speed on HiFi cassette deck? Dragon Other Equipment and Reviews 1 07-02-1999 11:27
