Thinking of building an analogue desk
Today I acquired an empty console, it's big enough for an 18 channel mixer. Does anyone know where i can get information on building a mixing desk?
Cheers; Jered. |
Once I move into a different place, I'm going to draw up and build a nice desk/workstation for all of my gear. Now if it ever materializes or is going to be worth a flip remains to be seen.
![]() Good luck on your project. ![]()
<insert witty and more appropriate comment here>
http://homerecording.com/bbs/showthread.php?t=180912
You can start there, also at prodigy-pro.com/forum they might have some useful schematics. A mixer channel strip is a lot of work, and it's going to be expensive. The design work alone for the PCB could take a very long time, especially if you don't have experience with that. You should budget about $100 per channel in parts, if we are talking quality opamps, faders, PCB, enough pots and knobs for aux sends, EQ, etc. If you want transformers, that's even more. |
and you're gonna do it on breadboard???? 18 one -off designed boards are really gonna set you back.... ballsy but not very practicle.... easier to find a good old board and refurb it...
37.8% of all statistics are made up on the spot... hey give a guy some room... people are trying to evolve here... for crying out loud... |
Thanks a lot Jered |
I think you can get a 32 channel Mackie mixer with what you are going to spend, but then again if it's experience and experimentation what you are looking for, good luck!
![]() You could check out some similar sized consoles, get their manuals (you can get many in pdf) and take a look at the "block diagram". There it tells you which circuit is connected to where and where the signal comes through... mainly everything you need to know about how to assamble a mixer. However there are some specific icons in block diagrams, that you should know if you are trying to build a console, and if you don't, you should. I don't know where you can get a list of those, if someone knows post it, I want it too. |
The other route is to buy channel strips that have been pulled from another console. You can find those for sale without too much trouble. BUT the problem is you have a case you are trying to fit. Thus, if there is a channel strip out there, somehow you have to bang that into the case you have. If the pot holes don't line up, then you have to wire all the pots point-to-point, and find a way to mount the board. Then you still have to pull together a master section and power supply from somewhere. The best course to proceed if you are set on your existing case is to find pieces of schematics you like (pre, EQ, compressor) and pull them together. If they come with PCB designs, that might give you a starting point for yours. The PCB design is really going to be killer. Knowing how to solder is a long way from knowing how to layout a PCB, much less designing the circuit that goes on it. If you take a modular approach, and build a power supply and pre section, and a very simple master section (say a stereo bus with headphone, maybe), you will be able to use published projects pretty much without much modification, and get your fingers wet. You can then add EQ, compression, and more routing as you get experience and money. Ultimately, that is more expensive than doing it all at once (the PCB costs add up quickly), but you are much more likely to succeed, and also have a useful project along the way. |
I've been looking at some EQ circuits, and I found a 5 band and a 7 band:
electronic-circuits-diagrams.com/audioimages/12.gif geofex.com/Article_Folders/EQs/greq.gif The 5 band looks easier to do 'cause it relies on a chip (not to mention 2 less channels) The channels on the 5 band are: 100Hz 300Hz 1kHz 3kHz 10kHz any more ideas? Edit I found a 3 band one, electronics-lab.com/projects/audio/025/ I might try this one. Anyone know where I can get an op amp which is: .....7 2 |+ \ --| -6 3 |- / .....4 (sorry about the crude ascii) A tl061 Last edited by Jered; 10-29-2007 at 01:15.. Reason: Found another schematic |
| Building new desk | W.S. Walcott | Studio Building & Display | 13 | 09-16-2004 12:25 |
| outputs of a mixing desk | drummersteve | Newbies | 11 | 07-04-2004 15:23 |
| Building Studio in Remote location | Garak | Studio Building & Display | 0 | 10-22-2001 19:47 |
| Suggestions on building a console desk or... | darr | Studio Building & Display | 17 | 05-01-2001 05:57 |
| Thinking of building a studio, need some opinions... | Mip | Newbies | 2 | 11-10-2000 21:47 |
