Go Back   Home Recording > User Forums by Brand > Pro Tools Forum
Reply    Audiofanzine Digidesign Digidesign News Digidesign Medias Digidesign Tests Digidesign Articles Digidesign User Reviews Digidesign Classifieds Ads
Old 10-19-2007
Amped's Avatar
Amped Amped is offline
Senior Member
Amped has a reputation beyond reputeAmped has a reputation beyond reputeAmped has a reputation beyond reputeAmped has a reputation beyond reputeAmped has a reputation beyond reputeAmped has a reputation beyond reputeAmped has a reputation beyond reputeAmped has a reputation beyond reputeAmped has a reputation beyond reputeAmped has a reputation beyond reputeAmped has a reputation beyond repute
Click Track
Whats the best way to import a clean click into ProTools? I need to be able to see the spikes on the track to use for editing. So far Ive simply been recording an analog click through the PA then importing it to a track, there has to be a better way!
Old 10-19-2007
killthepixelnow killthepixelnow is offline
Do it right or dont do it
killthepixelnow has a reputation beyond reputekillthepixelnow has a reputation beyond reputekillthepixelnow has a reputation beyond reputekillthepixelnow has a reputation beyond reputekillthepixelnow has a reputation beyond reputekillthepixelnow has a reputation beyond reputekillthepixelnow has a reputation beyond reputekillthepixelnow has a reputation beyond reputekillthepixelnow has a reputation beyond reputekillthepixelnow has a reputation beyond reputekillthepixelnow has a reputation beyond repute
Well... I use the PT CLick to guide myself when recording. Check on the insert points in the channels... I'm not in my computer now and my memory is going bad (too much work)
"Do it right or don't fucking do it"
ProTools LE 8 - MBox 2
iMac 24" 2.66Ghz, 4GB RAM, 1TB HD
OS X 10.5.6
Old 10-19-2007
Amped's Avatar
Senior Member
Yeah but can you create a track using the PT click? So far I havent found a way.... Thanks for the reply.
Old 10-19-2007
drewz0r drewz0r is offline
Newbie
drewz0r has a reputation beyond reputedrewz0r has a reputation beyond reputedrewz0r has a reputation beyond reputedrewz0r has a reputation beyond reputedrewz0r has a reputation beyond reputedrewz0r has a reputation beyond reputedrewz0r has a reputation beyond reputedrewz0r has a reputation beyond reputedrewz0r has a reputation beyond reputedrewz0r has a reputation beyond reputedrewz0r has a reputation beyond repute
create a (mono) Aux Input track. Pull up your mixer and put on the Click plugin on that track. (It should be Instruments --> Click on the dropdown menu)
It gives you a few ticking sounds to choose from
Old 10-19-2007
jonnyc jonnyc is offline
2.5K Gold Member
jonnyc has a reputation beyond reputejonnyc has a reputation beyond reputejonnyc has a reputation beyond reputejonnyc has a reputation beyond reputejonnyc has a reputation beyond reputejonnyc has a reputation beyond reputejonnyc has a reputation beyond reputejonnyc has a reputation beyond reputejonnyc has a reputation beyond reputejonnyc has a reputation beyond reputejonnyc has a reputation beyond repute
I don't use a click often because most of the pieces of crap I record can't play to one but there should be some kind of grid the click lines up with. It's probably been 2 years but I seem to remember there being one. That band would only record the chorus' once then just copy and paste.
Old 10-20-2007
Amped's Avatar
Senior Member
Thanks, Ill give that a try and report back...
Old 11-07-2007
thebigcheese's Avatar
thebigcheese thebigcheese is offline
"Hi, I'm in Delaware."
thebigcheese has a reputation beyond reputethebigcheese has a reputation beyond reputethebigcheese has a reputation beyond reputethebigcheese has a reputation beyond reputethebigcheese has a reputation beyond reputethebigcheese has a reputation beyond reputethebigcheese has a reputation beyond reputethebigcheese has a reputation beyond reputethebigcheese has a reputation beyond reputethebigcheese has a reputation beyond reputethebigcheese has a reputation beyond repute
You should also be able to just make an instrument track and select click the same way. I don't know if you can record it that way, but like jonnyc said, the grid system in pro tools lines up with the tempo of the song, so as long as you've got the right tempo set, you can just snap to grid. The click works on the song tempo anyway, so you should have it set right to begin with.
My band.
Old 11-12-2007
midniteindicia midniteindicia is offline
Newbie
midniteindicia is a glorious beacon of lightmidniteindicia is a glorious beacon of lightmidniteindicia is a glorious beacon of lightmidniteindicia is a glorious beacon of lightmidniteindicia is a glorious beacon of lightmidniteindicia is a glorious beacon of light
If you set a click onto an instrument track, you could probably bus the instrument track to a new (mono) audio track. Put the audio track into record ready, and hit play - record on the transport and it should be able to record from the instrument track onto the audio track.
I Need Help With Editing. Key Rogue Cool Edit Pro / Adobe Audition Forum 14 11-30-2005 00:37
Click Track gwayms Recording Techniques 3 10-05-2005 21:39
using Click Track with a 424 MkII studiodrum TASCAM User Forum 5 09-02-2005 08:55
Tutorial: Dyad DXi BluesMeister Cakewalk / Sonar Forum 9 12-30-2003 19:04
click track...??? fenix Drums and Percussion 10 12-11-2001 10:25
