mic problems
my mic is only recording on the left channel
how can i change this in cooledit? and when i test the mic it only shows the left channel reciving sound! =[ |
Sikter is right. I'll expand on that a little more for clarity.
If you set the track input source to be Stereo 1-2 (for example) then the track expects to receive two inputs, (one from channel 1 and one from channel 2.) The software then records the two channels side-by-side on the same track and outputs them to separate main channels as well, (L and R.) If you set the track input source to Mono 1 the track expects a single input (from input 1,) and during playback sends the same identical signal out through both L and R main channels. In stereo mode, having only one mic plugged in fulfills the left side but not the right. Hope this helps, RD |
lol yall make it sound so easy
but im not to sure how u change the settings to that in cooledit |
I cannot recall how the older versions were laid out but, if you are able to find that, it will all start to make sense then. |
done problem sovled!! =D
thanks guys!! |
is there anyway i can get that as a default insted of having to do it on every single layer?
On mine, you can save the workspace or as they call it, "Save Session as Default." That means that you can start up a fresh "empty" session, change everything to the way you like it, and then after saving as default, it will remember those settings for all new sessions in the future. I think you will find this option under the FILE menu, at upper left. Or if there is a SESSION menu, check there. |
| Major problems with mixer mic.. | studiowebx | The Rack | 16 | 09-07-2006 14:19 |
| phantom powering non-phantom mics | karambos2 | Microphones | 8 | 03-03-2006 20:29 |
| How bad is Studio Projects quality control | DJL | Microphones | 218 | 12-29-2003 14:53 |
| Wireless mic problems | MikeA | Microphones | 1 | 05-27-2002 00:45 |
| mic problems with MC012 and SM81 on overhead drums | ruebarb | Microphones | 2 | 11-29-2000 17:46 |
