Reel to Reel Newbie
Hi all ,
Have just discovered this forum and have just become the proud owner of 2 decks. 1. TEAC A-2300SX 2. National RS-755S I have started cleaning and testing the TEAC however the left channel seems to be quite a bit muddy. Right channel is crystal clear but the left is lacking. When I change the output to Microphone both channels are loud and clear. but on tape playback left is muddy ? Can the heads wear out on only one channel ? Any advice will be gladly accepted plus any information on how to visually examine heads. Cheers J |
There's also a good possibility that there's a build-up of oxide on the heads that needs something more then a "polite" cleaning. Try cleaning the heads with a bit more pressure of the q-tip swab and using isopropyl alcohol. Also inspect the heads with a magnifying glass to see if the surface of the heads appear different in terms of wear and color. The color difference may be a strong clue that part of the head is clogged with dirt/oxide build up. If after a thorough cleaning and a retest with fresh new tape and the same issue is there, consider getting the machine checked out for head alignment issues or possible electronic ones within the internal pre-amp circuitry. Cheers! ![]() |
Thanks a heap GFM.
Have cleaned the heads again with a lot more pressure and head cleaner, Problem still persists in left channel with new tape. I have orded the Servicing Manual, so will have a good going over of the unit when that arrrives. If all fails I hope there is a tech place i my area. Thanks again J |
| Recording test tones on a reel. Newbie needs help. | Grenouille | Analog Only | 3 | 02-09-2005 10:55 |
| Beginner Question about Reel to Reel Multi-Track recording. | SwanSong | Analog Only | 5 | 05-26-2004 14:13 |
| Reel to Reel setup (please help!!) | cjacek | Analog Only | 20 | 03-01-2003 20:31 |
| reel to reel adventures -- help! | lilcapn | The Rack | 5 | 09-07-2002 15:32 |
| Cassette and Reel to Reel Recording Head Configurations? | Ron Schilling | Analog Only | 4 | 01-12-2002 10:54 |
