Too much for the laptop or is it Reaper
I've got a song that has 19 instrument/vocal tracks, and 4 tracks as busses. When I load it, Reaper freezes up, lags, takes too long to process, and won't play it.
But it let me get it this far without any problems (I started the project in v1.888, so maybe?...) What do I need to do to fix this? I suppose I should delete the Reaper file and reload the whole thing, huh? Not that much work, so I suppose I could do that. This song is one of the best I've tracked so far, so it's not effects heavy or not a lot of editing needed. I probably blabbed enough to answer my own question, too... ![]()
The hardest part of being a bartender is figuring out who is drunk, and who is just plain stupid. |
what kind of laptop and what type of soundcard and what type of drivers on the soundcard and what sort of lastency are you running?
DrummyQ VST New! Kompound Drums Vol 1 Sample Building Kit REAPER Merchandise REAPER Chat |
As far as the soundcard, it's a stock soundcard. It's not an audio interface. Like I said, I don't record into it. So did I overload the program or what? I didn't have a shitload of effects on it, only some reverb and some compression. I know they are time based, so maybe... But I didn't have it on every track either.... ![]()
when did things start freezing? after adding the last track or plugin? is this a project that your coming back to and now it's freezing things up? you said that you started the project in 1.8. does it run ok in 1.8? you're running 2.0 now?
btw, using a higher latency will ease the strain on your system. what is your latency? are you using asio4all? |
Did you switch out/disable the sound card since you last had Reaper open? (Before the problems started).
I've done this and in older versions it just crashed. Now, I think you have to go to Options -> Devices and reset it to use the correct device. |
As far as latency, I've never dealt with it, and I don't have clue how to check it. ![]()
Upper right corner, it will say something like 256 samples and X amount of milliseconds, what every it is double it see if all your problems are gone. Changing it is simple if you are using ASIO4all, just click the top reight corner where it says the samples, then a window will pop up with your ASIO configuration, ins, outs, well there is a button there labled configuration, click that, you will be taken to the ASIO4all config window, grab the sample slider and double whatever it is on now. Click exit, then I think apply, you will be all set.
In a letter to his daughter, the MCP expressed unhappiness over the eagle as the symbol of America, he wanted the Tron guy. Equipment G.F.C.G. # 000 035 |
When I loaded the 2.0, my Firepod quit working
![]() Then I had to reinstall the pod with disc, so far OK. ![]()
[SIGPIC][/SIGPIC]Instant Karma tried to get me... and succeeded |
I had to use one last nite and couldnt get the midi going. It said "enabled" in reaper, but I didnt get any input.
What tab do I go under to find the configuration???
#12
should look something like this :
![]() Somewhere on your PC you should have an asio control panel for your card. Or go to options\preferences\audio\device and you should see an asio control panel there
#13
rtfm rokket ![]() ![]() |
#14
I've been struggling with Reaper, and now I've given up and reverted back to logic. However I've lost all MIDI on my Firepods after I reset my PC and reistalled everything. I initially blamed the latest Firepod firmware - the updater just crashes all the time. But after reading this Thread I'm thinking perhaps Reaper had something to do with it!?!...as I installed Reaper around the same time.
I'm seriously pissed of that I have no MIDI as I need my BCF2000 back in action. |
#15
Firmware updates are risky - I am in the middle of boxing up my Yamaha i88x for repairs after one failed on me, and I'm now without sound at home. In my case it's the other way around though - I can still use MIDI but the audio part of the mLAN thing isn't happening at all.
[generic spam/complaint/troll response] |
#16
are you using an external hard drive? if not, your laptop hard drive is probably the culprit. it is most likely going at 5400 rpms when you need at least 7200 rpms to handle a decent track count. hope this helps.
tascam 1804 self-built amd 4000+ system gateway m285-e core 2 duo tablet pc m audio sp-5b's reaper v1.8x |
#17
This is what I came up with when I checked on it:
#18
oooh thats not good...is the firepod unplugged? Or some other app using the asio drivers?
#19
I had this problem with my laptop aswell. But when I loaded it into my desktop (which is a decent computer) there were absolutely no problems. I don't think it would be Reaper, but my laptop didn't handle recording well... maybe yours doesn't either? Hope this helps in some way.
#20
I don't know what else could be using the drivers. I'll have to check it out.
#21
I'm going to try to record on my laptop soon...gathering up gear and any mistakes you make, I hope to learn from.
So far.. I have a new Toshiba with Vista. I got it in November 2007 so it's pretty current. AMD Turion 64 X2 1.9 GHz with 2GB ram. I need to get a firewire interface, looking towards... http://www.musiciansfriend.com/produ...ace?sku=246031 I already have this mixing board.. http://www.musiciansfriend.com/produ...0V-?sku=630132 I downloaded Reaper with ASIO for all drivers. Been trying to learn reaper, the last multitracking I did was a few years ago with Cakewalk PA9 and Cool Edit Pro on my Windows98 machine.... ![]() I'll keep checking in for advice, Dae
CanalCam Time is never wasted if you're wasted all the time Florida, God's waiting room. |
#22
| Could be leaving Sonar for Reaper | therage! | Don't Fear The Reaper | 5 | 09-18-2007 20:36 |
| FS: Pioneer DJM-400 Professional DJ Mixer and more | sshantrail | Other Equipment and Reviews | 1 | 08-12-2007 19:43 |
| Laptop power supply, PCMCIA card and digital hash noise in new monitors | chikin | Digital Recording & Computers | 15 | 02-22-2007 01:57 |
| Reaper 0.999 | travelin travis | Digital Recording & Computers | 2 | 07-28-2006 06:48 |
| Which Laptop | laj35 | Digital Recording & Computers | 18 | 03-27-2002 00:51 |
