Go Back   Home Recording > User Forums by Brand > Pro Tools Forum
Reply    Audiofanzine Digidesign Digidesign News Digidesign Medias Digidesign Tests Digidesign Articles Digidesign User Reviews Digidesign Classifieds Ads
Old 10-08-2007
steve.h's Avatar
steve.h steve.h is offline
Somewhere Out There...
steve.h has a reputation beyond reputesteve.h has a reputation beyond reputesteve.h has a reputation beyond reputesteve.h has a reputation beyond reputesteve.h has a reputation beyond reputesteve.h has a reputation beyond reputesteve.h has a reputation beyond reputesteve.h has a reputation beyond reputesteve.h has a reputation beyond reputesteve.h has a reputation beyond reputesteve.h has a reputation beyond repute
"Import Session Data" question (LE 7)
I believe I already know the answer to this question, but I figured I'd ask anyway in case I'm wrong! I'm mixing several songs for a band and I'd like to be able to transfer plugin settings from one session to the other, as for the most part they want their songs to all sound similar/the same. If I recall correctly, this can be done through the "Import Session Data" option in Pro Tools HD, but I believe this feature is blocked in LE? Either way, I'd like to know what peoples' work-arounds are if this is in fact true, as I would very much like to not have to write down the settings between sessions and meticulously copy them!
www.myspace.com/ironthrones - my sweet metal band
www.myspace.com/stevehenningsgard - my recordings
Old 10-08-2007
danny.guitar
Guest
Posts: n/a
Sorry if this is a dumb question, but does ProTools not allow you to save presets?
Old 10-08-2007
bennychico11's Avatar
bennychico11 bennychico11 is offline
bennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond repute
yes, you can save presets for the plugins
and yes you can use import session data in LE. File-->Import Session Data. This will be faster than having to redo all the plugs
You just can't import OMFs via this option (unless you have the addon)
www.redlabaudio.com
Old 10-08-2007
steve.h's Avatar
I'm 99% sure it does, but I'd rather not save 20+ presets for all of the different plugins I've got spanning the 16 or so channels! It'd definitely save some time over writing down the settings, but it's still meticulous...
Old 10-08-2007
steve.h's Avatar
When I go to import session data, do i import them as new tracks, then move the regions into the appropriate places? Call me crazy, but I believe I've tried importing session data and the only option it gave me in the drop-down menu next to the available tracks was "New Track"...?
Old 10-08-2007
so you've already recorded the band and just want to bring in the plugins? It would have been easier to just import session data before you started the new song...but no biggy.
You do have to import them as new tracks, but then just do a Alt+drag (option on mac?) and drag each plug to their respective track. This copies a plugin.
Or, you can do what you said and move all the regions down to the new track. Either way works.
www.redlabaudio.com
Old 10-08-2007
steve.h's Avatar
Yeah, I'm talkin' during mixdown, not tracking. I utilized the import function when tracking to copy i/o settings and it was great! But now that I'm mixing, I've got 5 separate sessions that all need to be mixed relatively similarly. I'll probably do as you suggested and copy the plugins from imported tracks to the current tracks. Kind of annoying, but it'll work! Thanks
And yes, it'd be the 'option' key (also labeled 'alt' on my MBP )
Old 10-08-2007
heroics321's Avatar
heroics321 heroics321 is offline
Gun-toting NRA Member
heroics321 has a reputation beyond reputeheroics321 has a reputation beyond reputeheroics321 has a reputation beyond reputeheroics321 has a reputation beyond reputeheroics321 has a reputation beyond reputeheroics321 has a reputation beyond reputeheroics321 has a reputation beyond reputeheroics321 has a reputation beyond reputeheroics321 has a reputation beyond reputeheroics321 has a reputation beyond reputeheroics321 has a reputation beyond repute
Why not just import the session data and drag the regions into the new tracks? Easier than dragging all the plugins over.
The Jungle... My diggs.
an mp3 question Rusty K Marketing Your Music / Publicity 3 10-06-2007 18:57
Question about monitoring. someguy211 Newbies 4 08-24-2006 21:48
Session Drummer question Paul881 Cakewalk / Sonar Forum 4 02-16-2003 11:12
HS02 newbie - session drummer questions rainday Cakewalk / Sonar Forum 1 01-21-2003 10:39
The Listening Sessions - Session 2 is online Dot Microphones 1 12-10-2002 04:23
