Go Back   Home Recording > User Forums by Brand > Don't Fear The Reaper
Old 10-04-2007
NashBackslash's Avatar
NashBackslash NashBackslash is offline
Senior Member
NashBackslash has a reputation beyond reputeNashBackslash has a reputation beyond reputeNashBackslash has a reputation beyond reputeNashBackslash has a reputation beyond reputeNashBackslash has a reputation beyond reputeNashBackslash has a reputation beyond reputeNashBackslash has a reputation beyond reputeNashBackslash has a reputation beyond reputeNashBackslash has a reputation beyond reputeNashBackslash has a reputation beyond reputeNashBackslash has a reputation beyond repute
Recording annoyance
In Sonar, there's this thing called "sound on sound recording" where I can basically overlap several clips on top of each other.
In Reaper, when I do that...
A) The previous takes on that track suddenly go silent
B) When I'm done recording, Reaper automatically crops the clips so no overlapping occurs
I CAN later edit the start and end times of the clips so that they overlap but this is very annoying.
How do I get sound on sound recording to behave like it does in Sonar?
Old 10-04-2007
pipelineaudio's Avatar
pipelineaudio pipelineaudio is offline
Official Shill as of 7/07
pipelineaudio has a reputation beyond reputepipelineaudio has a reputation beyond reputepipelineaudio has a reputation beyond reputepipelineaudio has a reputation beyond reputepipelineaudio has a reputation beyond reputepipelineaudio has a reputation beyond reputepipelineaudio has a reputation beyond reputepipelineaudio has a reputation beyond reputepipelineaudio has a reputation beyond reputepipelineaudio has a reputation beyond reputepipelineaudio has a reputation beyond repute
right click the items and chose: Itemslay all takes
Old 10-04-2007
beezelbubba's Avatar
beezelbubba beezelbubba is offline
Male Lesbian
beezelbubba has a reputation beyond reputebeezelbubba has a reputation beyond reputebeezelbubba has a reputation beyond reputebeezelbubba has a reputation beyond reputebeezelbubba has a reputation beyond reputebeezelbubba has a reputation beyond reputebeezelbubba has a reputation beyond reputebeezelbubba has a reputation beyond reputebeezelbubba has a reputation beyond reputebeezelbubba has a reputation beyond reputebeezelbubba has a reputation beyond repute
Does Reaper have the little guy with the tongue out?
Old 10-04-2007
Slowrider's Avatar
Slowrider Slowrider is offline
Dedicated Member
Slowrider has a reputation beyond reputeSlowrider has a reputation beyond reputeSlowrider has a reputation beyond reputeSlowrider has a reputation beyond reputeSlowrider has a reputation beyond reputeSlowrider has a reputation beyond reputeSlowrider has a reputation beyond reputeSlowrider has a reputation beyond reputeSlowrider has a reputation beyond reputeSlowrider has a reputation beyond reputeSlowrider has a reputation beyond repute
Yeah, when I first installed it, it was giving me the finger too.
[SIGPIC][/SIGPIC]Instant Karma tried to get me... and succeeded
Old 10-04-2007
Senior Member
Perhaps I didn't make my question clear enough. Let me try again...
In Sonar, when I'm recording, say, a rhythm electric guitar track; let's say I've laid down the first verse. Now, on the same track, I want to lay down the pre chorus or something, and I want it on the same track because I want it to sound continuous, like as if it was played in one attempt. Or maybe I want to do something fancy like a pick scrape before going into the pre chorus (and let's ignore the fact that normally people put that kind of thing on a separate track - let's just say I don't want to do that).
What I would do in Sonar is just move the Now time to maybe 2 measures before the pre chorus part and start recording there. Sonar will start recording, the verse that I laid down earlier will just continue to playback as per usual; I'll just stand by and wait before finally coming in. I do NOT use count-ins here because I actually want any sound that comes in before the pre chorus to be recorded (in the case of the pick scrape).
The result will be two overlapping recordings (clips as it's called in Sonar), hence the name "sound on sound recording"... the verse and pre chorus clips will overlap, and upon playback, both will be played. If I performed it well, it'll sound like a single take.
So I want to do the same thing in Reaper. Recorded the verse, now I want to record the pre chorus. I move the Now time to 2 measures before the pre chorus section. I hit record.
What's this? The verse that I recorded before suddenly goes silent. Nevermind, I think in that split second - I have the drum tracks to guide me so I know where the pre chorus is. So I play the pre chorus part... now it's time to playback to see how it turned out.
Oh noes, it looks like Reaper cut off the verse track from the point where I started recording (2 measures before pre chorus) and replaced that with the silence that comes from my pre chorus recording attempt!
So now I have to do the tedious job of actually dragging the end time of the verse item (I believe that's what it's called in Reaper, correct?) so that the sound doesn't cut off 2 measures before the pre chorus. But then Reaper does some strange things to overlapping items, it automatically cuts them into pieces and it's just confusing me. Basically, it's now a lot of work for me to do what I could originally do in Sonar... the only way for me to do it properly is to create a separate track for the pre chorus. But that's not a smart idea if my CPU isn't powerful and I need to conserve as many tracks as possible.
Hope you understand my problem now. Thanks in advance.
(PS: no "just play the guitar in one take you lazy bum" posts - if I wanted to do that, I shouldn't even bother with digital recording in the first place but that's clearly not the case here)
Old 10-04-2007
Ahh, you might have to crack the manual to find the mode most happy for you. REAPER's monitoring and punching had to take into account people coming from real, reel to reel recorders, autoinsert style Tape based modular digital multitracks and those raised strictly on DAWs
Therefore there are a few modes to deal with, which change the rules of what is shown vs what is selected.
The tip three choices under the Options menu are different "Record mode: "s
You will find generall that the majority of sonar and vegas users will chose Record Mode: Auto Punch Selected items
It might take a bit of doing, but youll find a way to record the way you want
Old 10-04-2007
Senior Member
Thanks. I'll peruse the manual and try the different recording modes.
Can I get advice from those who have a home studio? Chrisku13 Studio Building & Display 56 08-21-2006 23:20
Best Value Mic(s) for Recording Male Vocals/Martin Acoustics Aceboympk Microphones 20 02-14-2005 13:40
Recording set-up geeq Digital Recording & Computers 7 08-18-2003 10:33
Delta 44 vs. Windows Recording Mixer. God help me. Shepherd Digital Recording & Computers 2 06-09-2003 07:39
Inexperienced, need help recording my band sprynmr Recording Techniques 6 03-12-2003 05:40
