Play The New Game!! What's My Wattage?!
Ok, here's the setup! I've two amp head, both rated at 300 wts, but one(Trace Elliot AH-300) is 300 at 4ohms, the other,(Sunn Bass Coliseum 300) 300 at 2 ohms. I run the Trace with a 4x10 and a 1x15, both 8ohm cabs. I want to run the Sunn, but, with these two cabs, is not as powerful as the Trace. However, I recently had a cab repaired that is 4 ohms. I'm thinking of running 1x15 and this 4 ohm 2x10 together. I believe the Sunn will then see a 2.6ohm load. But, what will be the resulting wattage available, in this config? Will the result be creamy?
Qwack, Qwack!!! Quote:
The available wattage will be....a little under 300W.
How much under is hard to tell. If you knew the 4ohm rating for the amp you could get a bit closer maybe...Unless you need the maximum power you can get, it's not something to worry about. |
I'm gonna guess 1.21 jigawatts.
...or something around 230 watts.
Zaphod B Two-Headed President of the Galaxy (in exile) Tunes at http://www.soundclick.com/cowtowntommyboy "I have educated. I know what asshole is. "
That should be good.
Correct - actually, 225 watts. The 8 ohm will put out 75 watts, and the 4 ohm 150 watts. As for the sound, you'll just have to try it.
I'm going through a difficult period - it's called life |
It works out to -1.2db from 300W. Hope you can live with that much loss.
bump.
| forn sale Play station 2...$150usd | harry_eliz28 | Alesis Forum | 2 | 04-16-2007 21:05 |
| Play Me A Country Song | Irwin abrigo | MP3 Mixing Clinic | 4 | 03-07-2007 11:20 |
| Let's play a guessing game... | PhilGood | Microphones | 17 | 02-13-2007 15:27 |
| Get guitar to play synth sounds? | applesmasher | Guitars and Basses | 1 | 11-20-2003 02:24 |
| Let's PLAY a stupid game... | AJ_Cantos | Songwriting, Singing & Vocals | 5 | 11-10-2003 18:27 |
