I can string a bunch of MIDI devices together?
So I'm about to add some more MIDI controllers.
Right now it looks like it will be some m-audio keyboard along with a Korg pad kontrol and a behringer BCR2000. How would I hook all these up to my interface? (Motu 828 Mkii) |
The 828 has only 1 MIDI in and one MIDI out so you'll need to utilise the MIDI THRU ports on your gear to connect them serially (for example: M-audio OUT -> Korg Pad IN, Korg Pad Thru -> BCR2000 IN, BCR2000 OUT -> MOTU IN) You'll have a maximum of 16 channels to work with which may limit the flexibility of the BCR2000 or the pad controller (uncertain - I don't own one of these so I don't know if it is able to work on several channels at once). You will have to decide what channels each of the three bits of MIDI gear will operate with in order to prevent the wrong message being sent to the wrong piece of equipment. Example: BCR2000 Channels 1-12 Korg Pad Channel 13-15 M-audio Keyboard Channel 16 (or something like that) Or you could get a USB MIDI interface with multiple ports and have each piece of gear connected to its own port which will make setup & maintenance a hell of a lot easier! ![]() Dags
I have suffered for my music, now its your turn. |
You can connect the BCR2000 via USB and then use the MIDI in and out on that for an extra device
Awesome. |
Sweet fix, Gandalf! ![]() Dags
You don't want to daisy chain more than three midi devices, as you'll start to get delays. You'll also be more prone to dropouts like note offs being lost, that kind of thing.
Better to use a midi patchbay/interface as has been suggested.
http://www.misterpotts.com |
You can daisy chain sound modules for receiving midi but you can't daisy chain controllers unless the next controller in the chain will allow you to merge the Thru/Out. You either need an interface with multiple midi inputs or a Midi Merge box. |
| For the love of God, SOMEONE help me tune my 12 string guitar! | Mike Richardson | Guitars and Basses | 20 | 08-22-2007 11:09 |
| Completely MIDI CONFIG Illiterate | Outhabox | MIDI Mania | 4 | 03-10-2006 10:43 |
| Guitar intonation | mentil69 | Guitars and Basses | 30 | 03-30-2003 11:50 |
| seeking "perfect" intonation | pchorman | Guitars and Basses | 15 | 09-02-2000 12:15 |
| new studio need help.. fast!! | Readytodothis | Newbies | 8 | 04-06-2000 01:55 |
