Recording MIDI Help!
Hey guys!
Ok heres my situation for yall... I'm doing a live recording of sorts... Well will have 8 mics, or DI's going into a firepod, and then we need to record midi from a keyboard... The downsides are... We will have pretty much no set up time, so theres no room for messing round, so I need to be able to set it up FAST! And we need to be able to monitor the midi, so we can play as if he was playing a piano... Ok thats confusing! To break it down, I need to know how to record a keyboard using the midi output... And monitor it, using the stock reaper stuff... Sorry, I know this is explained really really roughly! But if anyone can desypher it and give me an answer it would be MUCH appreciated!! |
describe the setup and Ill make you a template...Ive used the firepod with low latency for a free reaper projects
DrummyQ VST New! Kompound Drums Vol 1 Sample Building Kit REAPER Merchandise REAPER Chat |
Ok the set up is as follows...
5 mics and 3 line in's all going into the firepod, into reaper recording to 8 seperate tracks... Then a keyboard with a midi out going to the firepods midi in, into another track on reaper... I think thats all... Cheers man! |
what are those mics and lines going to be?
Oh sorry... Full lines sheet...
Ins 1 OH L 2 OH R 3 Kick 4 Percussion Mic 5 Gat Mic 6 Gat Di'd 7 Bass Di'd 8 Vox mic Outs 1 Channel 1 of headphone amp (Running in-ears) 2 Channel 2 of headphone amp (Running in-ears) 3 Channel 3 of headphone amp (Running in-ears) 4 Channel 4 of headphone amp (Running in-ears) 5 Power amp (Running monitor wedge) 6 Power amp (Running monitor wedge) Then hopefully midi in... Cheers! |
OK, here is a template
http://shup.com/Shup/5267/notsocoolguy.RPP Im assuming 7 and 8 are the master CR out You will notice on track 4 I have Chanmix 2 in the fx insert so that while you record and see both the DI and the mic, you only hear the mic as per this video: http://www.cockos.com/wiki/index.php..._Tricks_Part_1 You can delete that easily enough if you want. Next I have sent all recording channels to all the monitor outputs post fx/prefader so that you can make 6 individual monitor mixes, none of which go to master.
Wow thanks heaps man!! But you'll have to help me one more time...
When I open than file, it's just a whole bunch of txt... Not a reaper project file, which I assume it's meant to be... |
REAPER files are meant to be human readable, so that if you were crazy enough, you could mix a song just using notepad.
Save that file as *.rpp and reaper will open it
Actually no worries man! Got it all sorted! Thanks heaps!!
Ok, last question now... Will this allow us to monitor the keys as a piano sound? |
thats the tricky part...
thats just recording midi, assuming your keyboard's audio output is hooked up to a mixer or something...of course you could record its audio at the same time, OR, throw a VST-i on the midi track which then would let you hear it How strong of a PC is this?
It's a fairly strong PC... Not sure of exact specs, it's my mates pc. Ah, so just chuck a VST-i on it, sweet thanks heaps for all the help!!
#12
Oh hey, just looked at your file a bit closley... Just thought I would point out, the Di'd Gat and the Miced gat, are two different players\gats... Sorry if that wasn't made clear! It's no worries! I know a fair bit about reaper, actually I like to think I'm pretyt compitent when it comes to using it, it's just the midi side of things I have NO experience with... But this recording date leaves no time to mess round getting a feel for midi
| drum machine, Cakewalk, USB MIDI interface, argh | 55337 | Newbies | 14 | 03-09-2005 16:41 |
| Help recording midi | SergeD | Cakewalk / Sonar Forum | 2 | 06-08-2004 16:07 |
| problem recording midi data question | stingray | Cakewalk / Sonar Forum | 4 | 09-21-2003 20:05 |
| Portable HD or Computer-Based?? | pablo | Recording Techniques | 26 | 07-26-2001 15:33 |
