Old 09-29-2007
darc mind darc mind is offline
Newbie
darc mind has a reputation beyond reputedarc mind has a reputation beyond reputedarc mind has a reputation beyond reputedarc mind has a reputation beyond reputedarc mind has a reputation beyond reputedarc mind has a reputation beyond reputedarc mind has a reputation beyond reputedarc mind has a reputation beyond reputedarc mind has a reputation beyond reputedarc mind has a reputation beyond reputedarc mind has a reputation beyond repute
help!..RECORDING problem.
hi..
im having a problem with my recording now..this didn't happen before so juss need someone to point out my problem to me
my set up is
Behringer VX2000 UltraVoice Processor (preamp)
MXL V67G Condenser Mic
and then wires connecting it all together
now i have nudge around the mic cable a bit behind the preamp to get it working..it used to be fine after i got but now when i record the quality is horrible now..the volume of the recorded vocal is jumping around a lot (it would go really high and then low) and the recording is more staticy..can anyone plz help me out in whats wrong now..thnx
Old 09-29-2007
tmix tmix is offline
1K Silver Member
tmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond repute
It is a bad Mic cable or a bad xlr connection either in the preamp or on the cable itself.
First try a new cable.
If that does not work then it is probably a bad solder joint with the connector in the preamp.
Most times it is the cable.
Unless you have been wrenching the xlr plug hard getting it in and out on the pre.
Also try a dynamic mic instead of the condensor. If it works fine then there is a problem with the cable ground (not letting phantom power through ) or with phantom power of the unit.
Tom
Tom Menikos
T-Mix Studios
Mansfield Texas
WWW.tmixstudio.com
Old 09-29-2007
Newbie
ok thnx alot for your help...ill let u kno what worked and what didn't
Old 09-29-2007
Newbie
umm arite i tested a dynamic mic on it and it works fine..so im guessin it is the mic cable..im gonna try a new mic cable and see how that works out..what if the same thing occurs with the new mic cable..?...culd it also be the mic?
Old 09-29-2007
Track Rat's Avatar
Total Gear Slut
If you can wiggle it at the preamp side to tease the problem into happening with a condensor and it works good with the same cable and a dynamic mic, it sounds like a possible cold solder joint at the XLR out (where phantom power connects internally). Just a SWAG (Scientific Wild Ass Guess).
Mike
Old 09-29-2007
Newbie
lol nvm thnx for the help..my mic cable messed..i got a new one and it works fine now..well atleast i think it does..i recorded something little and it was going fine..thnx for all your help=)
Old 09-29-2007
chessrock's Avatar
chessrock chessrock is offline
Banned
chessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond repute
my set up is
Yes, I would agree.
That is a problem.
But it's not the end of the world.
Old 09-30-2007
Newbie
okk its still not working...
i got a new cable..but its still jumping around..i tried the dynamic mic..but i tried it in the insert (send) place...not in the mic cable..that worked fine..but the mic cable one..i put in a new cable and its still jumpnig..its weird..now im either thinking its either preamp itsself..or the mic..now u said its a bad solder joint..is there any way to fix this?
rack with legs so i can tilt back walters The Rack 43 08-17-2007 20:35
Problem recording - MR8 wattle Fostex Forum 4 09-08-2004 21:39
VOCAL RECORDING PROBLEM.. plz help knockdown Recording Techniques 8 02-23-2003 13:02
sonar recording problem Waysid Cakewalk / Sonar Forum 3 03-05-2002 16:03
recording problem - newbie Markod Newbies 2 12-05-2001 10:11
