Stuck with single track
I feel rather silly, but I am trying to record my drum kit as 8 seperate tracks, but I am stuck with just one track containing all the mics. I have a MOTU 8pre firewired into a expresscard to my laptop. I tried to open them seperatly in cakewalk music creator 3, but i can only import a MOTU mix left, right, or sterio. Is my problem something to do with my expresscard? Any and all help would be greatly appreciated.
What is the ExpressCard? A recording card or just a standard one that comes with computers?
The sound card (interface) will need to have 8 analog inputs in order for you to record all 8 mics as separate tracks. |
an expresscard is a card that adds firewire or usb connectivity to a computer. in my case firewire, which i need for my motu 8pre
I'm not sure if Music Creator supports more than two-channel input, that would seem to be the logical problem. If your software sees the Motu L and R, it should also see 1 thru 8, unless it's not supported.
"Who's that singing? That can't be me, I don't sound like that." |
hmm, sounds like a question for my local recording guy. makes sence though. thanks a bunch
Try reaper, if for nothing else, then to see if you can get all 8 inputs working.
http://www.reaper.fm If you do try it, go into Options -> Preferences -> Devices. Look in the Device range dropdown boxes, and select input 1 for first dropbox, and 8 for last one. Click OK. Then press CTRL+T 8 times to add 8 tracks. Set each track's input to one of the inputs on your interface. Arm them for recording and see if it works. |
| Single track recording | Rockhouse | Newbies | 9 | 09-27-2007 16:28 |
| Need help on recrding from my four track into my computer! | bornmad | Recording Techniques | 10 | 08-09-2006 16:57 |
| The Grammy's | bknot1 | DJ & Hip Hop Production | 2 | 02-09-2006 11:46 |
| Roland VS 1824CD | Davester | Roland, Boss, VS Series Forum | 36 | 09-18-2004 14:39 |
| Album Release Dates. | Change of POETS | DJ & Hip Hop Production | 1 | 02-11-2004 14:26 |
