Cable marketing gone too far..?
http://www.musiciansfriend.com/produ...ed-?sku=331649
They're making cables supposedly matching a genre now.... Anyone else think this is marketing BS? /edit/ Oops, I guess its not a new thing looking at the dates of the reviews /edit/
I think the euphonix CS2000/3000 are the coolest consoles ever made... Blackbook 2.16/3GB/64GB SSD Profire Lightbridge 32 I/O |
I would venture a guess and say its crap.
But that's just a guess. You be the judge! Buy a Gibson L5 and a 59 Bassman 4x10, and try out some different cables ![]()
The jazz cable only has the ground attached on one end, where you plug into the guitar, to help quiet ground loops. The Rock cable has the ground connected to make it noisier, more "rock" sounding. And the Bass cable has a solid center wire for lower frequencies to travel faster on.
It may all be marketing, but if you cut the cables up you will see they are actually made differently. |
Monster jazz cables are pretty high capacitance, which rolls off the high end.Last edited by boingoman; 09-28-2007 at 16:00.. |
Can anyone tell me the best cable for rap under a dollar?
Yes, the best under $1 cable for rap is a peice of rope stolen from your neighbors garage tied in a noose.
Dealer for Peluso Microphones, Blue Microphones and CBI cables.... http://www.myspace.com/xstaticstudios |
They make pills that make you loose weight while you sit on your couch and eat donuts too!
oh the best is to rap them around your forearm and cinch them tight... who needs that pesky shield anyway...
37.8% of all statistics are made up on the spot... hey give a guy some room... people are trying to evolve here... for crying out loud... |
In the last year I've used Mogami, Planet Waves, Monster, George L and Quantum guitar cables. IMHO they all sound different.
I like Miles Davis and I like violins, but right now I need a Telecaster with Don Mare DonOcasters through a Deluxe Reverb turned up to 10 - almost a John Hiatt quote |
Whoever hears an audible difference between cables...I want your monitors. And your ears. (Or do I?
The shield is connected to the plug at the end you plug in to the instrument, but not connected to the end you plug in. Thats the reason there's an arrow on them. Its not because signal flows that way, its because its using a floating ground for the shield. They call it "semi balanced" using two conductors and a shield, the shield only terminating at the instrument side. |
#12
Thats it for me in this thread. I'll only eat the bait once .... voxxy |
#13
I bought one of those nice Monster cables and it did sound very clean and quiet but it's so freakin' stiff that it quickly ended up in my junk box. On the other hand, those cheap-ass 'Livewires' are noisier and have less clarity or focus but they're super flexible so that's what I mainly use. The audience sure can't tell the difference so all i care about is ease of use.
#14
#15
i settled on the Monster 500. like LtBob said, it's stiff......but it also doesn't knot up and it stays put on the floor. plus, it's insanely quiet (even in front of a CRT monitor) and i don't notice any high end rolloff at all. cheers, wade |
#16
#17
edit- I changed inner to second. |
#18
which is what I said even if I didn't spell it out completely. The shield is connected to the p'up but not at the other end. It's a shield but not a conductor.
You still have to have a second conductor of some kind that's connected at both ends to get signal to the amp. If you only have one wire running from the amp to the git you're not gonna get any sound. If that's not correct then I should be able to go cut the outer shield/conductor of my git cord and still have sound. But I'm pretty sure I won;t! ![]()
#19
My point is that this configuration is exactly the same as a regular cable. The noise still travels the same path as the audio. There is no reason this cable would be quieter than a regular one.
#20
I've wondered about that myself ...... since at one end or the other the shield is connected to ground .... that'd feed any noise in the shield to the conductor and thus, to the amp. Anyone know if a shield that's not connected at either end but is instead, basically a faraday cage would quiet things any?
| Cable Questions | cincy_kid | Newbies | 8 | 05-09-2006 14:14 |
| Cable length | pdadda | Mixing / Mastering | 8 | 11-07-2005 00:57 |
| I'm Really close on picking out my bulk cable, Your opinions | Mongoo | Other Equipment and Reviews | 10 | 12-01-2004 17:10 |
| Cable Basics - a primer for newbies | homerecor | Newbies | 1 | 03-04-2004 06:45 |
| The best quality cable? | Mongoo | Other Equipment and Reviews | 6 | 02-18-2004 08:53 |
