What's the best way to use a tube preamp with a Bass pod.
Actually I have more questions than just about the bass....
I just got a new inexpensive preamp that I ordered on line. I've heard people say that they can be used to add warmth to a Pod. I own a Line 6 bass pod and normally run a compressor (DOD R-825 Rack mount type) into the pod then to a mixer then the sound card. 1. How do I add the new tube amp to the chain? Please be specific about the out from and the into's I don't want to burn up any of my eqpt ![]() I've been using the "balanced" output (of the compressor) but it also has an "unbalanced" output I then run into the Pod input. 2. What chords would be best for this application, TRS, regular guitar type chords, patch chords etc? I've been using a stereo cable lol I need more chords :P I also own a Line 6 AX2 212 Guitar amp...Again, I run it into the stereo input of my mixer and then to the soundcard. 3. How would I use the tube amp with my AX2 212 and mixer? And yet again what type of chords would be best? I know these are probably basic questions but the tube preamp is a different application for me so go easy on me ![]() Here are some pics of the eqpt. I mentioned to give you more detail to what I am working with. New tube amp... http://www.musiciansfriend.com/produ...amp?sku=180581 Here's the compressor... http://vintageproaudio.com/photos/dod-r825a.jpg (Front) http://vintageproaudio.com/photos/dod-r825b.jpg (Back) And here is my mixer... http://www.soundonsound.com/sos/jun0...pv8front.l.jpg Bass Pod... http://www.chrisguitars.com/line6-basspod-040610.jpg And Guitar amp... http://images.google.com/imgres?imgu...icial%26sa%3DN I like to try to be clear and detailed ![]() Last edited by David J Sims; 09-27-2007 at 08:14.. Reason: grammatical error |
Well, the way I see it you've got one of two options:
1) If you want some distortion, or if you want it to sound *sort of* like it's being played through an amp ... then ditch the tube mp and use the POD. 2) If you want it to just sound like your bass; smooth, clean, no distortion, lots of bottom end ... then ditch that piece of shit bass POD, and just go direct using the Tube MP. Right now, I fail to see any logic whatsoever in using both together. Unless you just like running your bass through lots of unnecessary stuff. . |
I would try out an A major 7
Some of my music |
I'd vote for running the bass only through the preamp and then if you want, add in an amp sim or something after it. It seems to actually work pretty well, although I think a bass just DI'd usually sounds good enough with maybe some EQ/compression/reverb.
SimulAnalog makes some free amp sim and effects that are really good and I hate amp sims. |
That's an idea thanx ![]() |
| FS: Pedals, Bass Preamp, Cymbals | Timmylikedthing | Free Ads for Music / Recording Equipment | 0 | 08-07-2007 07:58 |
| Tube going bad in preamp? How to tell? | soundchaser59 | The Rack | 9 | 09-05-2006 11:03 |
| need help with using di-box & tube preamp w/ dig modeler & tube amp | MegaGoo | Recording Techniques | 5 | 02-26-2006 05:09 |
| Brick as Bass DI | mandocaster | The Rack | 5 | 05-26-2005 09:59 |
| preamp vs tube preamp : difference? | fadedstar | Newbies | 8 | 10-22-2001 11:41 |
